- bigwinn
Busy day today
New wishbones and lollipop bushes
Arb bushes
New discs and pads
Thanks to PDJ for being on call to tell me to hit it harder when a ball joint got stuck!
Only thing that failed was one of the disc retaining screws got stuck- back to that tomorrow to drill the b’stard out
Looking at the bushes that came off, especially the lollipops, they were a bit flaky- deffo expecting a change in handling
Arb bushes
New discs and pads
EWS Delete PM me
Coding- airbags etc PM me
EWS Delete PM me
- LittleZ4
Fitted some new grills as mine were flakey and needed constant attention
- PXL_20200924_162733486.jpg (212.34 KiB) Viewed 779 times
3.0i Maldives blue, Coilovers, Bola B1's, Buckley06 Gear knob, Handbrake & Indicator badges, Backbox delete, CDV delete, cupra r splitter, RAM air filter, Bigger Brakes, M3 ARB, SMF.
- patriot66
Wow ! A very busy day there Stuartbigwinn wrote: ↑Thu Sep 24, 2020 5:39 pm Busy day today
Arb bushes
New discs and pads
Has the disc retaining screw rounded-out ? If it's still intact then the following couple of tools will usually do the trick
- bigwinn
Tried the impact driver- no dicepatriot66 wrote: ↑Thu Sep 24, 2020 7:08 pmWow ! A very busy day there Stuartbigwinn wrote: ↑Thu Sep 24, 2020 5:39 pm Busy day today
Arb bushes
New discs and pads
Has the disc retaining screw rounded-out ? If it's still intact then the following couple of tools will usually do the trick 90581-1.jpg43245.jpg
Think tomorrow I’m going to try to drill it out- then get some mole grips on the stem once off
Enjoyed it all- still going to sort the rear brake pipes and CDV delete
Surprised how easy these cars are to work on-
EWS Delete PM me
EWS Delete PM me
- patriot66
The trouble with the disc retaining screw is it protrudes through the back of the hub flange and corrodes from the back. A blow torch usually breaks the bond. Smother the new screw in Copperslipbigwinn wrote: ↑Thu Sep 24, 2020 7:22 pmTried the impact driver- no dicepatriot66 wrote: ↑Thu Sep 24, 2020 7:08 pmWow ! A very busy day there Stuartbigwinn wrote: ↑Thu Sep 24, 2020 5:39 pm Busy day today
Arb bushes
New discs and pads
- Z4C_er
2006.5 E86 Z4C si SE Phoenix Yellow
Discovered how to change a headlight bulb.
Open a flap, pull a spring etc etc...........
in the WHEEL ARCH
What a ridiculous design.
Lets put a silly flap in the wettest place on a car.... no wonder the lights corrode inside.
in the WHEEL ARCH
Z3 2.2 sport tit silver
Z4 coupe 3.0si sport montego blue
728i oxford green
Opinions are like arseholes, everybody has one.
728i oxford green
- Jamie-innes
Finished off my install of carbon fibre trim
Looks very nice. 2 questions?
How do you get your plastic trim to look so good and do you have any issues with the vents heating the back of the screen?
- Jamie-innes
Thanks mateWeston Matt wrote: ↑Fri Sep 25, 2020 6:58 pmLooks very nice. 2 questions?
And to be honest it had a full valet about 2 months back and i haven't touched it since so I can't help you there, must be some sort of plastic conditioner maybe?
And RE the vents, unless it's blowing cold I just have those vents turned off usually don't want to overheat the screen lol
- Jakg
On my Z4 I used a chisel at an angle to tap it round.
On my E91 that didn't work so I ended up hammering a torx socket in
Both likely easier than drilling.
Both times I was using proper tools - never had this on other cars and it's happened to both my BMWs!
- bigwinn
Tried using centre punch etc- no joy and they are proper mashed now- drill time tomorrow
EWS Delete PM me
EWS Delete PM me
Made it levitate....
Previous Z4’s :E89 30i, E89 20i, E85 3.0Si (X4) E85 3.0i, E86 3.0 Si, E85 2.5si, E85 2.5i
- Nictrix
Looks good, is it wrapped or carbon fibre skinned?Jamie-innes wrote: ↑Fri Sep 25, 2020 1:12 pm Finished off my install of carbon fibre trim
- Jamie-innes
Carbon fibre skinned mate got a pretty good deal on ebay for itNictrix wrote: ↑Fri Sep 25, 2020 10:11 pmLooks good, is it wrapped or carbon fibre skinned?Jamie-innes wrote: ↑Fri Sep 25, 2020 1:12 pm Finished off my install of carbon fibre trim
