Upgraded to MPerformance wheel
- tug
Have you stuck that to the wheel Or is it photo shopped Either way. not my cup of tea. Soz.
E85 N46 2.0i SE BLACK SAPPHIRE
- enuff_zed
Is it April 1st already?
- enuff_zed
- TheDan
Change the DISA using the X8R kit. Probably the most straight forward car job I have ever done.
- steve_naive
'Ok little Johnny, these are called spring compressors. I'm going for a cup of tea now... good luck'enuff_zed wrote: ↑Sat Sep 18, 2021 6:09 pm Changed the front shocks and top mounts on the 2.2i. Took me all day, but well worth it as I had a little helper. 7-y-o lad from across the road. Kept him busy doing up all the nuts and bolts but he couldn't budge the knuckle bolts.
I am sitting here now feeling I've achieved more than just fettling the car.
I fitted the correct clip for my smaller new battery. Small job, much satisfaction.
- enuff_zed
In actual fact, he helped remove and refit the struts, drop links etc, but I sent him home while I swapped the springs over.steve_naive wrote: ↑Sun Sep 19, 2021 10:59 am'Ok little Johnny, these are called spring compressors. I'm going for a cup of tea now... good luck'enuff_zed wrote: ↑Sat Sep 18, 2021 6:09 pm Changed the front shocks and top mounts on the 2.2i. Took me all day, but well worth it as I had a little helper. 7-y-o lad from across the road. Kept him busy doing up all the nuts and bolts but he couldn't budge the knuckle bolts.
The kit I use is safe and I do it in a safe direction, jut in case, but if something went wrong I would never forgive myself!
He came back and told me all about the lovely ham rolls he'd had for lunch while I was wrestling with springs. Did I see any of said rolls? Not a crumb! Methinks we need to go back to apprentice basics.
Tried out the quick lift on the Zed,impressed with it
- 62D3D01C-825A-46CD-BCE9-402DC9DF1322.jpeg (278.27 KiB) Viewed 748 times
- 8D44C1C6-0224-45A1-BECC-D10DD49B2763.jpeg (208 KiB) Viewed 748 times
- F9652536-D3B5-4373-B098-2DA5AFC3F588.jpeg (228.65 KiB) Viewed 748 times
2007 M Coupe
Interlagos Blue,Sepang leather,carbon leather trim
Just about to buy one of these. Where did you get yours from?
I hit a big pothole the other day so took her in four wheel alignment and all wheel balanced (£154) I'm glad I did as the tracking was all over the place.
Also clocked up 33333 miles
2007 2.0i S E85 Monaco Blue Beige roof and interior
Costco,ordered last Sunday,delivered FridayWeston Matt wrote: ↑Sun Sep 19, 2021 1:24 pm Just about to buy one of these. Where did you get yours from?
2007 M Coupe
Thanks Jon. Will have a look nowJon2215 wrote: ↑Sun Sep 19, 2021 2:04 pmCostco,ordered last Sunday,delivered FridayWeston Matt wrote: ↑Sun Sep 19, 2021 1:24 pm Just about to buy one of these. Where did you get yours from?
- Andrews.Rick
Changed old rusty and worn out discs for Zimmermann Coat-Z. Much better!
- DBE62E11-F955-4052-B529-6C13B0FE0CCC.jpeg (203.4 KiB) Viewed 670 times
- EC0C15E9-B811-4999-9B02-39B75EB08DEF.jpeg (192.62 KiB) Viewed 670 times
- 1C7C7FFC-8F91-4EF6-8ABE-C71AFB41A333.jpeg (217.14 KiB) Viewed 670 times
Red E85 2.5i M-Sport, manual. Upgrades: cruise control retrofit & LED fogs. Next: Stormwerks nob & DAB/Bluetooth.
I've spent almost a whole day changing out a wheel speed sensor. The bolt was totally rounded and wouldn't budge. I ended up using a Dremel to cut the sensor away from the bolt and left the bolt in the hub. Even the sensor itself took some persuasion to get away with 120,000 miles of dirt holding it in. After changing it I've found that the problem still exists... I'm starting to think reluctor ring needs changing as it looked pretty rusty in there. Does anyone know what size socket the rear axle nut needs on a 2.0? I think its a 12 point 36mm but if anyone can confirm I'd appreciate it.
Cheers.
Cheers.
Scouser living in Scotland
RAF Lossiemouth
RAF Lossiemouth
