MOT’d the car
New front discs and pads
New rear tyres
So an expensive weekend for me, but all worth it
New rear tyres
BMW E36 Compact “Dakar Yellow” (sold to make way for Z4 Coupe)
BMW E36 M3 Evo Vert (sold due to hit & run)
BMW E36 M3 Evo Vert (stolen written off)
BMW E36 M3 Evo Saloon (sold to buy Vert)
BMW E36 318is Coupe (sold to buy M3)
- paulc_bkk
Cup holders
Swapped the factory Xenon projectors for a set of Morimoto Mini D2S 4.0s, it feels like I've strapped floodlights to the front of the car! The difference is insane, even using the same bulbs and electronics. So much more light and a razor sharp cutoff
- srhutch
- Moderator
Not the zed, but started to take the gearbox out of this to change the clutch.
- F3B077F2-9821-4F5A-8957-687928C801AA.jpeg (452.23 KiB) Viewed 986 times
- srhutch
- Moderator
- Spaniarduk
Are you based in Europe and is it road legal? If that's the case Id love to hear more about that conversion!mjennings23 wrote: ↑Sun Oct 21, 2018 1:32 pm Swapped the factory Xenon projectors for a set of Morimoto Mini D2S 4.0s, it feels like I've strapped floodlights to the front of the car! The difference is insane, even using the same bulbs and electronics. So much more light and a razor sharp cutoff
Volando voy
Volando vengo
Volando voy
Volando vengo, -engo
Y por el camino
Yo me entretengo
Volando vengo
Volando voy
Y por el camino
Yo me entretengo
Roof down drive to Cirencester about 120 mile round trip, topless
Toyota MR2 NA 1995
Triumph GT6 1972 (project)
Mini 1000 1981
Toyota MR2 NA 1995
Mini 1000 1981
- ZedConvert
Maybe the last decent clean of the year.... (maybe not)
UK, and everything is legal yes. Literally just replacing the factory xenon projectors with a different unit. Available in both LHD and RHD format, in fact LHD is much easier due to direct replacements being available rather than requiring brackets.Spaniarduk wrote: ↑Sun Oct 21, 2018 3:25 pmAre you based in Europe and is it road legal? If that's the case Id love to hear more about that conversion!mjennings23 wrote: ↑Sun Oct 21, 2018 1:32 pm Swapped the factory Xenon projectors for a set of Morimoto Mini D2S 4.0s, it feels like I've strapped floodlights to the front of the car! The difference is insane, even using the same bulbs and electronics. So much more light and a razor sharp cutoff
Are you in the UK/Ireland or the continent?
- LittleZ4
Do you have a link or something for the units and the brackets?? I could be tempted if I decide to keep the zedmjennings23 wrote: ↑Sun Oct 21, 2018 6:05 pmUK, and everything is legal yes. Literally just replacing the factory xenon projectors with a different unit. Available in both LHD and RHD format, in fact LHD is much easier due to direct replacements being available rather than requiring brackets.Spaniarduk wrote: ↑Sun Oct 21, 2018 3:25 pmAre you based in Europe and is it road legal? If that's the case Id love to hear more about that conversion!mjennings23 wrote: ↑Sun Oct 21, 2018 1:32 pm Swapped the factory Xenon projectors for a set of Morimoto Mini D2S 4.0s, it feels like I've strapped floodlights to the front of the car! The difference is insane, even using the same bulbs and electronics. So much more light and a razor sharp cutoff
3.0i Maldives blue, Coilovers, Bola B1's, Buckley06 Gear knob, Handbrake & Indicator badges, Backbox delete, CDV delete, cupra r splitter, RAM air filter, Bigger Brakes, M3 ARB, SMF.
I bought mine in the UK from EM tuning, some of the parts aren't listed so I spoke to them. However I wouldn't use their brackets again, they needed extensive modification so no point paying for them, rather get the TRS ones imported.
It's the E55 Hella "RETRO-QUIK" set you'll want from TRS, which includes projectors and brackets. You'll also want the optional bulb holders if you want to maintain the factory ignitors
- srhutch
- Moderator
Easy enough, but lots of parts to remove to get to things.mjennings23 wrote: ↑Sun Oct 21, 2018 2:40 pmHow's the Mini to work on? Looking at getting an R53 for the other half and I know well I'll end up being the one looking after it!
Subframe now on the floor so nearly there getting the box out. Starter motor also needs to come out.
- 0C3DA23D-8327-4415-893B-0672425EC9DE.jpeg (460.81 KiB) Viewed 882 times
Good on you for doing it yourselfsrhutch wrote: ↑Sun Oct 21, 2018 8:05 pmEasy enough, but lots of parts to remove to get to things.mjennings23 wrote: ↑Sun Oct 21, 2018 2:40 pmHow's the Mini to work on? Looking at getting an R53 for the other half and I know well I'll end up being the one looking after it!
Toyota MR2 NA 1995
Mini 1000 1981
Toyota MR2 NA 1995
Mini 1000 1981
Seems to be a symptom of small cars, everything stacked up on top of everything. Had a DS3 before the Z4 and replacing the oil filter involved taking off most of the intake system!srhutch wrote: ↑Sun Oct 21, 2018 8:05 pmEasy enough, but lots of parts to remove to get to things.mjennings23 wrote: ↑Sun Oct 21, 2018 2:40 pmHow's the Mini to work on? Looking at getting an R53 for the other half and I know well I'll end up being the one looking after it!
