Hey thanks!, I bought the spacers from amazon as they had good reviews and so far they feel very solid. Proper installation is key to spacers for safety. The fronts came with extended bolts (12mm) and the rears don't use extended bolts as they are an adapter set. They bolt directly onto the rotor/discs and then your wheel bolts onto the new spacer.CHIMV8 wrote: ↑Wed Jul 11, 2018 3:42 pmHimattyman22 wrote: ↑Mon Jul 09, 2018 11:06 pm Well, today was a fun and productive day for the Batmobile. First up I went ahead and fit spacers all around her to widen that stance and fix the weird fitment of the stock wheels so far inside the fenders. On the front I fit 12mm and on the rear I fit 1" adapters. Here are some before and after photos:
Before/After Rear:
Before/After Front:
Also, I went ahead and fit in some experimental product I had never heard of before called "Sugru." My hardtop in the front on both sides had the smallest little opening where air would come in even though it was fit as well as I could get it using the toolkit. It would actually create a helluva noise at high speeds (which my car often sits at ) SO I decided to basically seal it up using Sugru. It's like a moldable glue compound which does an excellent job at closing up little gaps just like mine between the hardtop and the windscreen. Works like a charm and no more road noise! Once it's fully cured it has a very rubber-like consistency and looks right at home with the rubber already there, so it was great!
She's ready for some other mods down the line, but for today it was an excellent run!
Mods still planned:
LED conversion for interior lights
Leather seat restoration (cracks, scuffs, and dings) I'm considering buying seat covers but I liek my heated seats...
Removal of Hardtop Spoiler (maybe)
Eyebrows Mod (see my post on recreating a specific mod look I saw online)
Thanks for reading folks!
Stance looks well
Where have you bought your spaces and did they come with the extended bolts
- wonkydonkey
Sounds like a fruitful trip!CHIMV8 wrote: ↑Wed Jul 11, 2018 3:50 pm First works on the car since we were paired up a few weeks
Over at Mikes Z SHED
CDV Valve removed
Roof motor moved inside the boot,lucky Mike not vertically challenged
The notchey steering in hot weather was sorted also
He makes all look so easy he does the work so quick
Previous:
~2006 Z4MR in Silver Grey
~2003 3.0i E85 in Sterling Grey
Click here for the Sticky Steering thread
<My name is James>
<My name is James>
- MACK
Simon 3.2M wrote: ↑Wed Jul 11, 2018 9:43 pm Dynamated the doors, removed the CDV and relocated the iPod connection to the ashtray
Simon I'm curious, why did you feel the need to Dynamat the doors? Obviously with yours being an M its a post facelift, so they've got sound deadening in all ready.
Silver 05 3.0i SE
White E89 20i M Sport
- Beemer233
Took the Z to the insurer's approved bodyshop/garage for photographic condition record.....normal thing here in Greece! Then fitted a new (OEM not aftermarket) BMW boot-lid latch motif (the original had a little internal white 'corrosion') and 4 new 56mm diameter logos for the Borbet wheels (sourced via eBay....Croatia (!)....looks a lot better now .......
- IMG_20180712_080401.jpg (265.9 KiB) Viewed 1150 times
- IMG_20180709_103012.jpg (304.67 KiB) Viewed 1150 times
- IMG_20180709_094834.jpg (212.25 KiB) Viewed 1150 times
Jan 2007 E86 Z4 3.0si Coupe high spec in Monaco Blue Metallic/Champagne/Piano currently on 18 inch CW4 Sterling Silver Borbets....
I intend to live forever.....or at least die trying!......Groucho Marx
There was none in there mate - much to my surprise. My SI was the same!MACK wrote: ↑Thu Jul 12, 2018 9:07 amSimon 3.2M wrote: ↑Wed Jul 11, 2018 9:43 pm Dynamated the doors, removed the CDV and relocated the iPod connection to the ashtray
Sepang Coupe
Imola Roadster - For sale
Interlagos Coupe - For sale
Previous:
Stratus Grey Coupe
Titan Silver 3.0 Roadster
Carbon Black Coupe
Silver Grey MR
Silver Grey 3.0si Roadster
Maldives Blue 2.5
Sterling Silver 3.0 - twice
Previous:
Stratus Grey Coupe
Carbon Black Coupe
Silver Grey MR
Maldives Blue 2.5
- MACK
Simon 3.2M wrote: ↑Thu Jul 12, 2018 10:35 amThere was none in there mate - much to my surprise. My SI was the same!MACK wrote: ↑Thu Jul 12, 2018 9:07 amSimon 3.2M wrote: ↑Wed Jul 11, 2018 9:43 pm Dynamated the doors, removed the CDV and relocated the iPod connection to the ashtray
That's interesting. Mines a Pre but I'd always been lead to believe the sound deadening was part of the Post face lift changes.Simon 3.2M wrote: ↑Thu Jul 12, 2018 10:35 amThere was none in there mate - much to my surprise. My SI was the same!MACK wrote: ↑Thu Jul 12, 2018 9:07 amSimon 3.2M wrote: ↑Wed Jul 11, 2018 9:43 pm Dynamated the doors, removed the CDV and relocated the iPod connection to the ashtray
Silver 05 3.0i SE
- paullyjay
Well, yesterday, the starter sounded a bit laboured, and seeing as I hadn't driven the car for a week, (been driving the e23) I arrived at work wielding my battery charger, plugged in and left it juicing up for the morning...
Went out at lunch time - nothing, completely dead... Grabbed the multi-meter and battery looks fine... Call RAC, who told me after a number of checks that it must be the starter motor...
New unit ordered... Fitted in my lunch break today... Fixed... All is right in the world again!
- Beemer233
Nice one paul! Must be a readily available generic part ? Amazed how certain aspects of these otherwise complex cars are straightforward when trouble strikes......how old was the battery ? Lifespan here in Greece is an average of 4 years on most cars with the wild temperature fluctuations etc....paullyjay wrote: ↑Thu Jul 12, 2018 2:46 pm Well, yesterday, the starter sounded a bit laboured, and seeing as I hadn't driven the car for a week, (been driving the e23) I arrived at work wielding my battery charger, plugged in and left it juicing up for the morning...
- paullyjay
Yep - I went for a Lucas unit from eurocarparts rather than the original OEM Denso from BMW... I think the battery is only a year old or thereabouts - Batteries seem to last me about 3-4 years here in the UK too, I have 4 cars and seem to be forever disconnecting, connecting and charging them!!Beemer233 wrote: ↑Thu Jul 12, 2018 3:34 pmNice one paul! Must be a readily available generic part ? Amazed how certain aspects of these otherwise complex cars are straightforward when trouble strikes......how old was the battery ? Lifespan here in Greece is an average of 4 years on most cars with the wild temperature fluctuations etc....paullyjay wrote: ↑Thu Jul 12, 2018 2:46 pm Well, yesterday, the starter sounded a bit laboured, and seeing as I hadn't driven the car for a week, (been driving the e23) I arrived at work wielding my battery charger, plugged in and left it juicing up for the morning...
- Magicarcher
Z4 3.0L 2005. Titan Silver. Audio Upgrade Second Stereo Pioneer X8700DAB, Sony Xplode 4 x 70W Amp, 6.5" Reckhorn Subs in rear cubby, Focal AS165-3 in fronts.
- Beemer233
Mightily impressive work!....can relate to the lack of mid-range even in the so called Prof hi-fi OEM set up......you must get blown away by the upgraded system?Magicarcher wrote: ↑Thu Jul 12, 2018 6:14 pm Pretty major audio upgrade see:
viewtopic.php?f=2&t=107638
- CHIMV8
Thankyou for the contact he’s Mikes a great bloke who cracks on with the job in hand while you waitwonkydonkey wrote: ↑Thu Jul 12, 2018 8:19 amSounds like a fruitful trip!CHIMV8 wrote: ↑Wed Jul 11, 2018 3:50 pm First works on the car since we were paired up a few weeks
CDV Valve removed
Sterling Grey 3.0
- wonkydonkey
No problem I get a good impression of the work he does from the comments around the forum. Better that he gets your pennies rather than the tax man getting the money for all your petrol to come down here! Enjoy your upgrades
Previous:
<My name is James>
<My name is James>
And gave the coupe a lovely soapy hand wash.
D
Z in da Head.
3.0i Z3 sport,sapphire black,3.0i Z4 roadster Sterling grey,auto,Z4 3.0si Coupe Titanium silver,Stubby &B06 Plus some other German beauties!!
Get a ctek charger with a reconditioning cycle I've used one on the marlin because the battery wouldn't hold charge. Since I gave it a recondition cycle it's been a lot better.paullyjay wrote: ↑Thu Jul 12, 2018 3:46 pmYep - I went for a Lucas unit from eurocarparts rather than the original OEM Denso from BMW... I think the battery is only a year old or thereabouts - Batteries seem to last me about 3-4 years here in the UK too, I have 4 cars and seem to be forever disconnecting, connecting and charging them!!Beemer233 wrote: ↑Thu Jul 12, 2018 3:34 pmNice one paul! Must be a readily available generic part ? Amazed how certain aspects of these otherwise complex cars are straightforward when trouble strikes......how old was the battery ? Lifespan here in Greece is an average of 4 years on most cars with the wild temperature fluctuations etc....paullyjay wrote: ↑Thu Jul 12, 2018 2:46 pm Well, yesterday, the starter sounded a bit laboured, and seeing as I hadn't driven the car for a week, (been driving the e23) I arrived at work wielding my battery charger, plugged in and left it juicing up for the morning...
