Ordered clips to fix my D/S wiper which decided to fall off today on the coupe!! First day of rain and pain!
Z in da Head.
3.0i Z3 sport,sapphire black,3.0i Z4 roadster Sterling grey,auto,Z4 3.0si Coupe Titanium silver,Stubby &B06 Plus some other German beauties!!
Yes, Try the reset. Sport mode amplifies the problem, in my experience.wonkydonkey wrote: ↑Thu Jun 14, 2018 7:35 pmMine can be a bit of a pig in first/second gear coming back on the throttle from zero throttle. It's as though I'm stamping my foot down with the finesse of a donkey's hind hoof sometimes, kangarooing around (worst in Sport mode). I must try this reset.ionofchios wrote: ↑Thu Jun 14, 2018 3:57 pmThen I read about adaptive throttle reset. Did that this morning and lurching seems to be gone, plus no more waiting for the CDV to engage, and things are smoother and faster in lower gears.
Basically, CDV and adaptive throttle are 2 systems that should never have been in the car in the first place. Anyone know how to turn off adaptive throttle permanently? Can it be coded off?
- ph001
Can't be coded out but could be re-mapped out on the ECU with an experienced tuner. 99% of people don't have an issue with adaptive throttle though I suspect.ionofchios wrote: ↑Thu Jun 14, 2018 8:05 pm Basically, CDV and adaptive throttle are 2 systems that should never have been in the car in the first place. Anyone know how to turn off adaptive throttle permanently? Can it be coded off?
I've got into the habit of using sport mode now, which uses a much more linear throttle map and doesnt adapt itself, much better feeling of control.
Yeah, that makes sense. After the throttle reset it was much better the following day. Then, this morning, a bit lurchy again, but not as bad. Then cleared itself up after a few miles. Seems to be fine in sport mode and normal mode at the moment. Maybe there is something else that needs attention - I had no issues for the first 6 months. Wonder if refreshing clutch fluid would help.mjennings23 wrote: ↑Fri Jun 15, 2018 12:07 pm I've got into the habit of using sport mode now, which uses a much more linear throttle map and doesnt adapt itself, much better feeling of control.
Certainly wouldn't hurt, I'd advise you just do the brakes with it, seeing as they share the same reservoir. 2 birds one stone and all that
- mac27040
New mirror casing gloss black and refurbished alloys from shadow chrome to gloss black. New alloy bolts, Centre caps etc
Tidied up seats, removed red pipping on dash
- B3A6F00C-3C13-43C7-A5EF-295ED644458E.jpeg (415.96 KiB) Viewed 954 times
- 968950F7-DEB2-4B76-AC81-6B324D21A5D0.jpeg (305.29 KiB) Viewed 954 times
- B72B3C93-CB50-46B3-9219-213B0A70F68F.jpeg (241.71 KiB) Viewed 954 times
- 6D1946F5-D072-4319-9020-52B6F17E1324.jpeg (423.08 KiB) Viewed 1040 times
- 53C18867-A170-4185-B139-85B270B0202D.jpeg (479.16 KiB) Viewed 1040 times
3.0i SMG Supercharged,19" CSL, AvinUSA android 10.25” screen,DSP,M6 gearknob,Coilovers,Aero F-bumper,M r-bumper,Aero skirts,Facelift front & rear lights,M sports seats,Carbon Steering wheel,Intravee,Rervese cam,Hydrographics
- ben g
Absolutely beautiful
Do you have a hardtop for it?
looks mint mac looking forward to seeing your impressive zed again at zed fest mods look great
2004 z4 30i auto Toledo blue stubby Areo front back sideskirts and rear spoiler M/// MFSW DLV exhaust mod mma tips vanos overhaul 108s refurbed ram air scoop E46 M3 heated seats clear rear lights M/// sport black grills
- mac27040
Yes I do have a hardtop
- mr wilks
Its a beautiful creation in every way but i would have to extend the bonnet stripes through front bumper & bootlid all or nothing
3 ZMRs
3 E89s
5 Si coupes
5 Si roadsters
997 C4
TTRS
F82 M4
MK7 Golf Gti
current Bmw 6 Gran Turismo
3 E89s
5 Si coupes
5 Si roadsters
997 C4
TTRS
F82 M4
MK7 Golf Gti
Just drained all the coolant so I can replace the radiator which was deformed at the top and leaking. I have taken a few picks so when I figure out how to get them up I will post. Wasn't too bad a job. The new rad is in and everything is connected. The drain plug for the block did not get removed as I could just not get anything on to it.
Wipers fixed. Best £3.98 I could spend on eBay. Can recommend i6 to anyone. They also do the DISA repair kits which I had done on the roadster last year.
Z in da Head.
- Iggy
Fitted an Eventuri intake bought from mr.tourette in my 3.0si today. Preliminary results are excellent. It will get a proper test tomorrow on a trip to Wales
Before After
Before After
zedless
Past
'06 Z4 3.0si Sport Coupe - Silbergrau
'06 Z4MC - Silbergrau & Imola Leather
Past
- wonkydonkey
Iggy looks like you got your feather duster out at the same time
Previous:
~2006 Z4MR in Silver Grey
~2003 3.0i E85 in Sterling Grey
Click here for the Sticky Steering thread
<My name is James>
<My name is James>
