Have you removed the bungs from the end of the drain tubes? Only takes five minutes and reduces the risk of them getting clogged up.tomrdy wrote: ↑Mon Jan 07, 2019 1:22 amThanks! I was worried about how it would look when I finally got it out. This was one of those jobs that was on the list but just too lazy until the other day my RHS drain clogged for the first time after... some over-enthusiasm with the power washer. My wife came home and asked me why there was a small slow dripping puddle near my rear right....
Stuck a coat hanging down the area and WOOOOOSH. Tonnes of water flushed out.
Figured that was a sign I should probably sort out the relocate
- MrPT
It does, but it also means more tyre roar comes into the cabin, especially on the motorway. It's not terrible, but I'd recommend a before/after test.andyf1140 wrote: ↑Mon Jan 07, 2019 6:24 pmHave you removed the bungs from the end of the drain tubes? Only takes five minutes and reduces the risk of them getting clogged up.tomrdy wrote: ↑Mon Jan 07, 2019 1:22 amThanks! I was worried about how it would look when I finally got it out. This was one of those jobs that was on the list but just too lazy until the other day my RHS drain clogged for the first time after... some over-enthusiasm with the power washer. My wife came home and asked me why there was a small slow dripping puddle near my rear right....
2006 Z4 2.5si: gone
2006 Z4 2.5si: gone
- Smartbear
Hi, this only improves the tail end of the drainage system, the problem is often at the top end where leaves/dead cats etc end up covering the drain entry pointMrPT wrote: ↑Mon Jan 07, 2019 6:40 pmIt does, but it also means more tyre roar comes into the cabin, especially on the motorway. It's not terrible, but I'd recommend a before/after test.andyf1140 wrote: ↑Mon Jan 07, 2019 6:24 pmHave you removed the bungs from the end of the drain tubes? Only takes five minutes and reduces the risk of them getting clogged up.tomrdy wrote: ↑Mon Jan 07, 2019 1:22 am Thanks! I was worried about how it would look when I finally got it out. This was one of those jobs that was on the list but just too lazy until the other day my RHS drain clogged for the first time after... some over-enthusiasm with the power washer. My wife came home and asked me why there was a small slow dripping puddle near my rear right....
e85 3.0si sold
- tomrdy
I found these bungs while I was vinyl wrapping earlier in the year when my side skirts were off. Didn't think to remove them. Not concerned anymore tho because the motor is sat safely in my boot
Need to grab some interior carpet to cover it up.
(if anyone is wondering, the banana clips are there becuase i usually have a net clipped that way haha very classsy )
-SOLD- Nardo grey 2004 Z4 3.0i E85
-SOLD- 2016 Long Beach Blue M2 DCT
-Wishing- Z4MC Interlagos blue...
___
Australia
Just bagged an z4m steering wheel at last full refurb when I get it merry Christmas me
2004 z4 30i auto Toledo blue stubby Areo front back sideskirts and rear spoiler M/// MFSW DLV exhaust mod mma tips vanos overhaul 108s refurbed ram air scoop E46 M3 heated seats clear rear lights M/// sport black grills
New front discs, pads and replacement of a binding front brake calliper
My wallet
My wallet
- MalNCH
Replaced the expansion tank that had split, those clips/hoses at the bottom are a real PITA!
Replaced the passenger headlight unit with a good secondhand one, my car had been in a shunt at some point (previous owner) and they put a black one in instead of silver.
2004 E85 3.0i, Titan Silver Metallic.
- Big Andra
Not quite done anything to it, but the set of 224's I bought arrived today, also a zhp gear knob and a couple of sets of poly bushes. Hopefully get time to remove the gm5 to send away for repair this week too.
2009 E89 2.5 Alpine white.
- paddy wright
Got him home after a new starter motor done under warranty.
- MrPT
Quite the house you’ve got there.paddy wright wrote: ↑Tue Jan 08, 2019 10:49 pm 1A43BD97-E95B-47AE-B175-E3ED69E78762.jpeg
2006 Z4 2.5si: gone
2006 Z4 2.5si: gone
- paddy wright
MrPT wrote: ↑Tue Jan 08, 2019 11:22 pmI wish! This was at BMW collection. My garage is a lot less grand!paddy wright wrote: ↑Tue Jan 08, 2019 10:49 pm 1A43BD97-E95B-47AE-B175-E3ED69E78762.jpeg
MOT done today. No advisories
Just saying that I will need new rare pads at some point.
- Spaniarduk
I've started to buy to bits I'll need in the spring to do the valve clearance check and replacement of the necessary shims in my S54. Today I got the camshaft cover rubber gasket. Next, the 32mm 1/2" socket, set of gauges and magnetic tool to remove and refit the shims.
Volando voy
Volando vengo
Volando voy
Volando vengo, -engo
Y por el camino
Yo me entretengo
Volando vengo
Volando voy
Y por el camino
Yo me entretengo
- ben g
Thought I'd check my Z4 over before it's MOT next week. Lucky I did as I found this:
Ordered a new part from BMW on ebay for £18. Shouldn't be too difficult to fit.
- Spaniarduk
Yikes... How the hell did that bracket fail?!
Volando voy
Volando vengo
Volando voy
Y por el camino
Yo me entretengo
Volando vengo
Volando voy
Y por el camino
Yo me entretengo
