Oil service on the son’s roadster today. What a simple but very satisfying job. The car just seemed to run so much better afterwards.
We also unblocked the drain hole at the bottom of the roof motor cavity (the motor itself has been relocated) which was full of water. The mouldings around the drain hole seem to be all chewed up, or even melted (second pic). Anyone know why this might be?
Also, where the drain hole comes out in the cavity in front of the rear wheel arch, there’s a black plastic box with a blue thing in it (first pic). Anyone know what this is?
- 9F546B63-0FAF-4D71-8DC5-BBCD96F686FC.jpeg (53.22 KiB) Viewed 746 times
- E72E4FCF-6404-4EBB-AF49-E2170FFF4A1E.jpeg (67.73 KiB) Viewed 746 times
2003 Maldives Blue 3.0i auto
- AndyBeech
If it's just the camber pin which i presume it is I just left it out, not needed. Check that's what it is though first.
Z4MR - Gruppe M, Bilstein PSS10, CSL's + 18" CSL reps with semi's, RTAB Limiters, Powerflex’d, PF Camber Arms, K-Sport BBK / RSL-29, GC Camber Plates, Strut Brace, Exhaust valves, custom brake cooling, complete underside refresh!
I believe that's the connector for the wheel speed sensor.
2006 Z4 2.0i Ruby Black
Jfgoldfish wrote: ↑Sun Nov 22, 2020 11:07 pmThought it is the brake wear sensor. I changed one of them out when I put new disks on the front.
Thanks guys, learn something every day.mgrlane wrote: ↑Sun Nov 22, 2020 11:13 pmJfgoldfish wrote: ↑Sun Nov 22, 2020 11:07 pmThought it is the brake wear sensor. I changed one of them out when I put new disks on the front.
- ProfCJJ
Washed the tree sap and bird poo off the car and tidied up inside. Finished just as the sun was setting. Car now covered against more bird crap!!
The brake wear sensors do have a very similar connector.
Had mine serviced at BMW, always feel that I've had my pants pulled down, but it's got full history and still under extended warranty so reluctant to go elsewhere.
- buzyg
Finally got the Ramp for an hour and helped my Zed man fix the exhaust that had dropped on the right bank, after the original cast clamp broke. It turns out I was just the perfect height to hold it up on my shoulder whilst he was tightening a loosening the bracket to get it just spot on. The kit to fix it came with two replacement clamps, so I now have a spare I will probably never use.
The down side was my new battery had gone completely flat after 5 weeks and my trickle charger was not charging it. Took two cars to jump start it this morning. Happily no other issues, but my new battery may be a dud.
- TheDan
Put the brand new front struts (with springs) and drop links on the car today. Front left was a PITA as the old shock wouldn't come out the knuckle clamp!!!
Hopefully doing the rest tomorrow (LCA and Tie Rods):
- Big Andra
Fitted a front splitter and side skirts tonight. Also turned the seals around on the headlight covers as there was a small bit of condensation starting.
- 20201123_195934.jpg (157.42 KiB) Viewed 603 times
2003 E85 3.0i titanium silver
Bilstein B4's & Eibach pro's
Poly bushes
Cruise control
Cup holders
Gaptech
Stubby
Poly bushes
Cruise control
Cup holders
Gaptech
Stubby
Looks good. Are those Maxton design?
Made some progress on my aero side skirts
- Big Andra
Yes, maxton design. Pretty straight forward to fit too.
Poly bushes
Cruise control
Cup holders
Gaptech
Stubby
Poly bushes
Cruise control
Cup holders
Gaptech
Stubby
- buzyg
The side skirt is a really nice little addition.
Interested to learn how robust it will be.
