Busy week.
Rear and Back windows tinted today. Reflector sorted (horrible job, lots of swear words) new back for a leaky headlight.
Midweek new front window and rubber. (I broke it when trying to replace the rubber window surround)
Last weekend- plugged a few leaks. New oil caps, valve gaskets, valvetronic and eccentric shaft gaskets.
Other than new wheels I am pretty much where I want to be with the Z now.
- PXL_20201105_132105265.jpg (275.89 KiB) Viewed 1126 times
- PXL_20201102_144816944.jpg (188.48 KiB) Viewed 1126 times
- PXL_20201114_162108285.jpg (203.94 KiB) Viewed 1126 times
- PXL_20201114_150210374.jpg (280.62 KiB) Viewed 1126 times
- PXL_20201114_144356484.jpg (240.03 KiB) Viewed 1126 times
Finally fitted my cruise control today. Thanks to SRHUTCH for the loom and instructions. Being a relative novice, I didn’t find anything easy about this job, but did have a great sense of satisfaction when I reconnected the battery and the car didn’t explode. Just need a break in the weather before I can test it.
- FDAA790B-0D56-4EE5-A215-EF20782D4241.jpeg (115.22 KiB) Viewed 1107 times
2003 Maldives Blue 3.0i auto
- TheDan
Good job! Looks like you've done a nice neat cut on the steering column cowl or did you buy a new one with the cut out? I had to hack at mine as the dremel died... ended up filing it to a decent finish though.Zedebee wrote: ↑Sat Nov 14, 2020 9:42 pm Finally fitted my cruise control today. Thanks to SRHUTCH for the loom and instructions. Being a relative novice, I didn’t find anything easy about this job, but did have a great sense of satisfaction when I reconnected the battery and the car didn’t explode. Just need a break in the weather before I can test it.
Where did you get your headlight covers from, and how much did you pay? Need to do the same job myselfmgrlane wrote: ↑Sat Nov 14, 2020 8:16 pm Busy week.
Thanks! Funnily enough, that was the easy bit. I put the cowl in a vice (lots of cloth padding) and used a jigsaw for the cut-out, then filed down the edges. Really pleased with how it fit back together.TheDan wrote: ↑Sat Nov 14, 2020 11:21 pmGood job! Looks like you've done a nice neat cut on the steering column cowl or did you buy a new one with the cut out? I had to hack at mine as the dremel died... ended up filing it to a decent finish though.Zedebee wrote: ↑Sat Nov 14, 2020 9:42 pm Finally fitted my cruise control today. Thanks to SRHUTCH for the loom and instructions. Being a relative novice, I didn’t find anything easy about this job, but did have a great sense of satisfaction when I reconnected the battery and the car didn’t explode. Just need a break in the weather before I can test it.
Soper Lincoln BMW. They have a forum discount.Jameszy wrote: ↑Sat Nov 14, 2020 11:39 pmWhere did you get your headlight covers from, and how much did you pay? Need to do the same job myselfmgrlane wrote: ↑Sat Nov 14, 2020 8:16 pm Busy week.
I believe they were just under 14 quid each.
I found these guys gave a decent quote to when I emailed them but I had ready spoken with Soper and put in an order.
[email protected]
Managed a test drive today while the sun was out briefly. Cruise control works perfectly, definitely no programming required. If anyone is nervous about doing this retrofit themselves, don’t be. The hardest part is “routing the blue wire through to the black box”, nothing technical!Zedebee wrote: ↑Sat Nov 14, 2020 9:42 pm Finally fitted my cruise control today. Thanks to SRHUTCH for the loom and instructions. Being a relative novice, I didn’t find anything easy about this job, but did have a great sense of satisfaction when I reconnected the battery and the car didn’t explode. Just need a break in the weather before I can test it.
Fitted some winter wheels today, picked these up on eBay, style 388 from a 2 series. they’re a squared set up which I’m not convinced about but as I hardly use the car in the winter and they’re mainly to sit it on until I can get my 108’s fixed, they’ll do.
- 432C2AAB-B068-4735-8C21-15A9B876327E.jpeg (268.14 KiB) Viewed 975 times
sbryantgb wrote: ↑Fri Nov 13, 2020 9:07 pmEbay
https://www.ebay.co.uk/itm/Gear-Handbra ... %3A2334524
They do not come with any kind of retaining clip (plastic, you have to reuse the original). They are way thicker than the original. (which you have to peel and scrape off.) Mines a base level car and the quality is superior to the original, but maybe not so on other models. I still have to do the handbrake, which I know is going to take even longer. I haven't driven the car since installing and the clips are quite stressed and the boot may pop out. If it does a few small tapping screws around the the outer shell and the plastic insert will probably sort this without any other major modification, and which will be hidden from view.
Hope this helps.
Cheers Kev.
2005 Titan Silver BMW Z4 E85 2.0SE
2013 Graphite BMW 120d Sport
1972 Pimento Red Triumph TR6 2.5 Pi
1979 Azzurro Blue Lancia Beta Coupe 1.6
- Big Andra
Another update from the paint shop. Should have it back for the end of the week.
- 20201116-120046_WhatsApp.jpg (126.02 KiB) Viewed 916 times
2009 E89 2.5 Alpine white.
Removed rear bumper and crash bracket behind for powder coating
- TheDan
Done a few aesthetic ones this week:
- Bought some refurbed black powder coated MV2s and fitted to the car.
- Wrapped them in Goodyear Eagle F1 Asymmetric 5 tyres yesterday.
- Fitted some matte black grilles this morn (but unfortunately my front left headlight has gone misty).
Finally got round to changing both drive belts. The longer belt was in a poor state, which I noticed when I sorted the vanos. Good feeling to have the new belts on.
- colb
Quick wash then fitted the Z4 forum.com sticker to the rear window, bit of a pain getting it in place needed warming up to get it to transfer onto the inside of the glass.
- Z4forum window sticker.JPG (139.68 KiB) Viewed 773 times
Z Shed Cymru member
1999 1.8 Z3
2003 2.5 Z4
1998 Honda Deauville 650
1999 1.8 Z3
2003 2.5 Z4
- Big Andra
Picked it up from the paint shop today. The guy has done an excellent job.
- 20201121_124922.jpg (229.52 KiB) Viewed 708 times
