- Mau
Sure, but do you mean for the cup spoiler or for the rubber stripping? (I can do for both of course) For the splitter / cup spoiler: that will ONLY fit Aero bumpers. That is because Aero bumpers have two additional pieces of plastic at the corners and this splitter is shaped around these.
More on the '03 roadster and '08 coupe:click me.
- HU51A_FU
For the Cup Spoiler.
- Mau
Sure, no problem: here: https://www.ebay.co.uk/itm/Cup-Spoiler- ... 2749.l2649 it is.
However, as per the above, will ONLY fit Aero bumpers.
CSR does offer splitters for other bumper varieties however, such as this one: https://www.ebay.co.uk/itm/CSR-Cupspoil ... SwzrBap5B9.
- zriha
I hope, I fixed the air vent rattle - viewtopic.php?f=3&t=127426
Current fleet
BMW Z4 (E85) 2.5i 5-speed manual
Mini Cooper S JCW F56
Royal Enfield Classic 350 Signals (Marsh Grey)
Fitted genuine 437M’s in Ferric Grey...
Previous Z4’s :E89 30i, E89 20i, E85 3.0Si (X4) E85 3.0i, E86 3.0 Si, E85 2.5si, E85 2.5i
- zriha
Perfect weather, used this morning to clean it.
Current fleet
- kis
Did you dig out the channel of orange rubber before you installed? Seems like the rubber o ring is just sitting on top?
My E85 Z4 3.0i SMG
1 Series - E87
4 Series - F36, F82 M4
5 Series - E34 (x2), E39
7 Series - E32
X5 - E53, E70
X6 - E71
1 Series - E87
7 Series - E32
X5 - E53, E70
X6 - E71
- kis
What was your conclusion? Was there any draw?davidmudley12 wrote: ↑Sun Feb 21, 2021 8:31 am I checked the fuses for any parasitic draw from the battery with a thermal imaging camera.
My E85 Z4 3.0i SMG
1 Series - E87
7 Series - E32
X5 - E53, E70
X6 - E71
1 Series - E87
7 Series - E32
X5 - E53, E70
X6 - E71
No thankfully there wasn't, quite a fun way to look at it (also used a multi-meter to double check).kis wrote: ↑Thu Feb 25, 2021 3:36 pmWhat was your conclusion? Was there any draw?davidmudley12 wrote: ↑Sun Feb 21, 2021 8:31 am I checked the fuses for any parasitic draw from the battery with a thermal imaging camera.
Current cars: 2006 3.0si E85 Sapphire Black, cruise, MFSW.
BMW 535d Touring (F11)
Skoda Fabia 1.2
BMW S1000XR
Skoda Fabia 1.2
BMW S1000XR
- Darkangelv2
Depending on your previous wheel/tyre set up that will yield you some nice weight savings in your unsprung mass
BMW Z4 2006 2.5SI - 437M Wheels - Strut Brace - H&R ARBs
3.0si Brake Conversion - Custom Nappa Sport Interior - Z4M Bumper+Bonnet -
BC Racing BR Coilovers - AFE Stage 2
- Wyldie85
Took it out, washed the grime and filth off. Put some more Gtechniq C5 top up coating on. Put it back in the garage. Next doors car was parked quite close, so I didn’t even take a photo. What a poor existence for a Zed.
Darkangelv2 wrote: ↑Thu Feb 25, 2021 7:21 pmDepending on your previous wheel/tyre set up that will yield you some nice weight savings in your unsprung mass
Yes, they felt lighter than the 18’s that came off, they’re a beautifully made wheel too... very high quality close up.
Realistically, I’ll probably downsize on the tires at some point too, which will further reduce unsprung weight. I like the look, but it’s borderline ‘Carlos fandango’ with 255’s on the front and 275’s on the rear
- kis
Okay well that's good! I wasn't sure if I was interpreting the photo correctly, the faint red is the constant live? If it were brighter then it would be an indication of parasitic draw?davidmudley12 wrote: ↑Thu Feb 25, 2021 3:43 pmNo thankfully there wasn't, quite a fun way to look at it (also used a multi-meter to double check).kis wrote: ↑Thu Feb 25, 2021 3:36 pmWhat was your conclusion? Was there any draw?davidmudley12 wrote: ↑Sun Feb 21, 2021 8:31 am I checked the fuses for any parasitic draw from the battery with a thermal imaging camera.
My E85 Z4 3.0i SMG
1 Series - E87
7 Series - E32
X5 - E53, E70
X6 - E71
1 Series - E87
7 Series - E32
X5 - E53, E70
X6 - E71
Fitted my hand brake gaiter and new bit of bling. Not sure on the suede but I’ll leave it for now
- 70FB97B1-9413-4282-86E4-BA31E1165FB4.jpeg (145.1 KiB) Viewed 395 times
- 86A0943D-EB3A-4737-8E8A-3FF68EDC64B5.jpeg (168.17 KiB) Viewed 395 times
- Trav
I went to move the Z today to give it a clean. Did I not go and forget to remove my 20W solar charger. I ran over it. Completely smashed it. I am so cheesed off as it has been brilliant all winter. Ah well it will be back on the road on Monday so that will keep it charged.
Z4MR A.W.
