- GAZA62
MOT today and she passed 1 advisory front offside brake pad wear which can be sorted later this year when serviced
Was a relief as i start jury service Monday so would have been a real pain trying to get the car sorted and re tested had she failed.
T.SILVER 2004 3.0SE AUTO
IF IT WAS NOT FOR BAD LUCK I'D HAVE NO LUCK AT ALL
- ben g
Started it up and let it run for a bit with the heater on full blast, as the inside of the windscreen had tons of condensation. Then mopped up the water in the boot again really need to sort out where the leak is.
Can't do much else as the clutch is fried, so although it runs fine, it can't be moved without a push
Needs a wash, hoover and a cover on it for now. It's taking up valuable driveway space aswell, so I'll need to figure out what I want to do with it soon.
- Reamesy
Have you check your roof motor. Water will make its way into the cabin and boot if its blocked? Could explain the condensation.ben g wrote: ↑Fri Jan 22, 2021 8:15 pm Started it up and let it run for a bit with the heater on full blast, as the inside of the windscreen had tons of condensation. Then mopped up the water in the boot again really need to sort out where the leak is.
Currently; 2011 E89 23i SDrive M Sport Highline Titan Silver
Previously;
2014 SLK250CDI AMG Sport
2012 E89 SDrive 2.0 M Sport. White
2011 Audi TT Quattro
2006 Z4 2.5 Sport
2013 420D coupe
2002 Z3 2.2 Sport
1996 Z3 1.9
Previously;
2006 Z4 2.5 Sport
2013 420D coupe
2002 Z3 2.2 Sport
1996 Z3 1.9
- ben g
It probably is the drain holes that are blocked, causing the drains to fill up and overflow into the boot, as on both sides of my boot, those little pocket areas were full with waterReamesy wrote: ↑Fri Jan 22, 2021 11:30 pmHave you check your roof motor. Water will make its way into the cabin and boot if its blocked? Could explain the condensation.ben g wrote: ↑Fri Jan 22, 2021 8:15 pm Started it up and let it run for a bit with the heater on full blast, as the inside of the windscreen had tons of condensation. Then mopped up the water in the boot again really need to sort out where the leak is.
I'll have to move the car away from the bushes so I can access both sides and clear the drain holes and hope that sorts it. If not, I don't really know
- sw4nny
If this isnt the problem check the 3rd brake light for cracks or chips and that the seal is good.water gets in here runs down the underside of the boot lid and drips out in the sides where the little cubby holes are.ben g wrote: ↑Sat Jan 23, 2021 5:18 pmIt probably is the drain holes that are blocked, causing the drains to fill up and overflow into the boot, as on both sides of my boot, those little pocket areas were full with waterReamesy wrote: ↑Fri Jan 22, 2021 11:30 pmHave you check your roof motor. Water will make its way into the cabin and boot if its blocked? Could explain the condensation.ben g wrote: ↑Fri Jan 22, 2021 8:15 pm Started it up and let it run for a bit with the heater on full blast, as the inside of the windscreen had tons of condensation. Then mopped up the water in the boot again really need to sort out where the leak is.
- Phoenixboy
Washed and cleaned before the snow
E89 s drive 30i manual/gone
space grey
Carbon interior trim
19" Veeman FS 25`s
cruise control
m sport seats
stubby
led halo bulbs
OEM wind deflector
Gone, E85 Ruby Black.
space grey
19" Veeman FS 25`s
cruise control
m sport seats
stubby
led halo bulbs
OEM wind deflector
Finally got round to fitting a Dash Cam that I recived for Christmas.
Took slightly longer as I lost a bolt thart managed to work its way down into the speaker trim!
- Dash Cam.jpg (123.86 KiB) Viewed 680 times
2005 E85 - Merlot - Appropriately named 'Ron Burgandy'...
Washed and cleaned it in the freezing cold.
Not washed it for a few months. Looks like New again. Lol.
- IMG_20210124_144257.jpg (150.24 KiB) Viewed 621 times
- IMG_20210124_144320.jpg (107.4 KiB) Viewed 621 times
- IMG_20210124_145850.jpg (113.73 KiB) Viewed 621 times
Looking tasty mate! Remind was black an option for the wheels originally? If not how much was it to get them done?
2006 Sapphire Black E86
Onlinepatriot66
That looks bloody fabulous Red and black is a great combination
- Robtp10
Having a full back axle refurb at RBM
- NB04BUZ6.jpeg (203.17 KiB) Viewed 545 times
- NB04BUZ5.jpeg (203.17 KiB) Viewed 545 times
- NB04BUZ4.jpg (188.06 KiB) Viewed 545 times
- NB04BUZ3.jpg (212.59 KiB) Viewed 545 times
- NB04BUZ2.jpg (220.01 KiB) Viewed 545 times
- NB04BUZ1.jpg (188.06 KiB) Viewed 545 times
Put on my cal reps
- DDFA7BED-E237-4330-AC53-74DE724D2325.jpeg (285.75 KiB) Viewed 514 times
Will be doing the steering wheel silver parts to match, along with recovering.
Anyone got them in satin or matt black I can see? Think gloss will show fingerprints too much
