- LittleZ4
Had a new windscreen fitted.....didn't realise just how pitted the original 14 year old screen was!
3.0i Maldives blue, Coilovers, Bola B1's, Buckley06 Gear knob, Handbrake & Indicator badges, Backbox delete, CDV delete, cupra r splitter, RAM air filter, Bigger Brakes, M3 ARB, SMF.
- Coffee331
Didn’t actually do something to the car today but bagged this on eBay for €31
- 748B6790-B8A8-494C-8CA5-5616A4717122.png (748.51 KiB) Viewed 927 times
- Spaniarduk
That was a bargain!! Well done!
Volando voy
Volando vengo
Volando voy
Volando vengo, -engo
Y por el camino
Yo me entretengo
Volando vengo
Volando voy
Y por el camino
Yo me entretengo
- JINGLE
- enzed4
Just noticed that after reading your postwyshyvanuk wrote: ↑Mon Dec 03, 2018 3:51 pm companycardriver: carpet segments on the walls = brilliant. Thanks!!
Gone: 2010 35i DCT
Gone: 2008 2.5Si Sport
Washed her yesterday in between blowing a hooley and as soon as I finished it started pi$$ing down.
Ice this morning, so winters here .
- B69143B6-16BA-4CFB-A014-FF4269FEABE4.jpeg (432.86 KiB) Viewed 839 times
- D9BF69FD-B440-43B7-A8A7-26AF0B91B89E.jpeg (401.14 KiB) Viewed 839 times
Cheers Kev.
2005 Titan Silver BMW Z4 E85 2.0SE
2013 Graphite BMW 120d Sport
1972 Pimento Red Triumph TR6 2.5 Pi
1979 Azzurro Blue Lancia Beta Coupe 1.6
Thank you sir. The carpet is glued on to some thin board then screwed to the wall. Makes getting in and out much easier.wyshyvanuk wrote: ↑Mon Dec 03, 2018 3:51 pm companycardriver: carpet segments on the walls = brilliant. Thanks!!
Imola ///MR
- Nictrix
Along the same lines as this, I have glued a couple of carpet tiles to our garage wall where the door would be likely to hit.companycardriver wrote: ↑Tue Dec 04, 2018 5:28 pmThank you sir. The carpet is glued on to some thin board then screwed to the wall. Makes getting in and out much easier.wyshyvanuk wrote: ↑Mon Dec 03, 2018 3:51 pm companycardriver: carpet segments on the walls = brilliant. Thanks!!
Your right it does make it easier getting in and out as if needed the door can be rested on the carpet tile instead of the concrete wall.
- Big Andra
I went down the pvc route.Nictrix wrote: ↑Tue Dec 04, 2018 6:38 pmAlong the same lines as this, I have glued a couple of carpet tiles to our garage wall where the door would be likely to hit.companycardriver wrote: ↑Tue Dec 04, 2018 5:28 pmThank you sir. The carpet is glued on to some thin board then screwed to the wall. Makes getting in and out much easier.wyshyvanuk wrote: ↑Mon Dec 03, 2018 3:51 pm companycardriver: carpet segments on the walls = brilliant. Thanks!!
- 20181204_181727.jpg (309.4 KiB) Viewed 781 times
- 20181204_181748.jpg (399.37 KiB) Viewed 781 times
2009 E89 2.5 Alpine white.
- BigAlC
Broke the splitter
Mine was along them lines, old car matsNictrix wrote: ↑Tue Dec 04, 2018 6:38 pmAlong the same lines as this, I have glued a couple of carpet tiles to our garage wall where the door would be likely to hit.companycardriver wrote: ↑Tue Dec 04, 2018 5:28 pmThank you sir. The carpet is glued on to some thin board then screwed to the wall. Makes getting in and out much easier.wyshyvanuk wrote: ↑Mon Dec 03, 2018 3:51 pm companycardriver: carpet segments on the walls = brilliant. Thanks!!
Been thinking about getting my screen replaced due to pitting and really bad etching on the passenger side. Did you do it privately? If so do you mind sharing who you got to do it?
Gave it a good carnauba waxing and then went for a drive to take some Photo's.
Attempted to fix my leaky headlight
- 37785CDC-197F-491B-B2BB-AE40C9C7CFF1.jpeg (442.3 KiB) Viewed 736 times
- Coffee331
you robbed that
Was the fitting of it ok?
