I'd say you got your money's worth out of both tires and clutch then.ben g wrote: ↑Fri Jan 10, 2020 8:59 pm Checked the tyres... Fronts are showing cords in the insides. Yep, they're being changed tomorrow
Also vacuumed the interior as it was absolutely Filthy.
Currently trying to nurse the clutch through to next month when I can finally get the clutch and flywheel replaced. The noises being made are awful I assume its the flywheel making wheezing noises, as when I put it in neutral whilst driving, it doesn't make a sound.
And yes, it's slipping rather badly
- scootr
E89 3.0L 6 MT gone
Michelin P4s
Bilstein struts & shocks
Luxon tower brace
Michelin P4s
Luxon tower brace
- g3org3y
What kind of noises?
2007 Z4 3.0Si Sport. Manual, Montego Blue
- Singapore stag
Tuesday, done the front discs, front and rear pads also fitted 20mm rear spacers and 15mm front. New tyres.
The discs took a lot of effort to remove, were really rusty felt as if they were welded on.
Looks really good with the spacers, now just waiting for the roll bar links and spark plugs.
Will post pics of how it looks with spacers.
Rgds
P.s Washed, clay bar, waxed, sealed and polished. Also took out some swirl marks. Mcguires Ultimate wax used, Halfords polish must be one of the best I have used so far. Got good reviews on many "Which" sites. Really easy to apply and take off, buffs to an excellent finish.
Rgds
I polished the headlight; rain stopped play so I only managed to do the passenger side, still came up a treat compared to what it was originally like!
- Z4 Light.JPG (84.89 KiB) Viewed 712 times
Change me for f**k sake
2005 merlot 2.5 auto.313s.e46 m3 front brakes.Strut brace,poly bush’s front, m front bumper,modified grilles,bc racing coilovers,facelift lights all round,modified rear bumper,s/wheel retrimmed, Merc slk seats. scorpion exhaust, many interior mods.
- colb
Replaced the sensor inside the AUC sensor located on top of radiator cowl, it sniffs the air for polloutants and closes the fresh air intake flaps to stop fumes entering the interior of the cabin. Had a fault code come up for this, tiny sensor inside the plastic housing is replacable, it is a tight push fit. See how to post viewtopic.php?f=34&t=119411
Also fitted a couple of DRL's to the lower grill to make the car easier to see, its silver and blends in to the road surface making it easy for other drivers to miss seeing you. Ran a ignition controlled feed from the fuse box to power the lamps. Will be fitting an auto switch to switch them off or dim them when side or headlights are powered up. Already have them on the Z3 so thought it wise to fit them to the Z4. Cheap Chinese led types which so far have lasted well on the Z3, having said that I have just spotted one led has gone out on one of the units on the Z3.
Z Shed Cymru member
1999 1.8 Z3
2003 2.5 Z4
1998 Honda Deauville 650
1999 1.8 Z3
2003 2.5 Z4
- MrPT
Exciting wing mirror day! Replaced a cracked cap on the golf and split glass on the ///M.
2006 Z4 2.5si: gone
2006 Z4 2.5si: gone
Replaced the battery as it failed. Turned out it was original to the car, 15 years old!
- D9BE6B0C-7115-445E-9903-4BDAED4686A5.jpeg (372.06 KiB) Viewed 671 times
2005 e85 z4, 2.5
- Danz4coupe
Washed for first time in about a month and took it for a blast up to the petrol station.
- MrPT
That is pretty good going. I think mine is original too (2008) and it makes me nervous.
2006 Z4 2.5si: gone
2006 Z4 2.5si: gone
- Singapore stag
Replaced mine as well, factory fitted I think.
- 20200111_174321.jpg (145.16 KiB) Viewed 646 times
- DMike
While the wheels were off for a brake job, detailed the wheel wells and suspension...
- 6F4F9743-B670-4206-BA86-DA307F6C9A3C.jpeg (196.45 KiB) Viewed 621 times
2005 Z4 3.0i Sterling grey
- scootr
Finished the smart top module install, programming and all. Works a charm
For an old guy ~ I feel like a computer programmer
E89 3.0L 6 MT gone
Michelin P4s
Luxon tower brace
Michelin P4s
Luxon tower brace
- ben g
it's making jingling noises. Almost like something rattling around in there. I can't get it changed until I can get access to my other half's car next month
I hadn’t used my Z for a month, so started her up, checked the tyre pressures and took her for a short blast ready for a 180 mile round trip to a run event Sunday morning. Sunday morning came... rain... 1/2 mile down the road and the wipers failed
Back home and jumped into the M135 but really wanted to take the Z
2006 Silver BMW E85 2.5Si Sport - 18” Veemann FS23, Buckley06 gearknob, stubby aerial.
