I have been running this thread about the problemwonkydonkey wrote: ↑Fri May 18, 2018 8:29 pmHappy days. Just thought I'd ask if it was linked to sticky steering. Evidently not
viewtopic.php?f=3&t=105626
Thanks mate. Mine look quite similar to yours before you treated them. I'll get some Scratch Doctor and follow your instructions. Cheers, Siwonkydonkey wrote: ↑Fri May 18, 2018 8:10 pmThanks, I'm really happy with the results. Process was as follows:
1. Dodo Juice Supernatural leather cleaner applied using a microfibre cloth.
2. Damp microfibre used to wipe away any residue.
3. Scratch Doctor Leather Colour Restorer applied using a microfibre cloth.
4. Colour restorer buffed off after 5 mins.
5. Leather conditioner applied using a microfibre cloth.
6. Conditioner buffed off after 15 mins.
Good good! It was £10.95 on eBay from "thescratchdoctor". It's important that a leather cleaner is used first to strip everything away before applying the colour restorer. The cleaner I went for cost £12.75.
As requested.
I did it for the same reason. Mine was already hardwired, so I just moved it. I pulled out the fag holder and popped out the illumination window, leaving a hole just big enough to pass through the PCB of the dismantled connector.MACK wrote: ↑Wed May 16, 2018 10:40 pm I've got my parrot mki9100 screen permanently mounted in the same place. I mounted the controller to the back of power socket/lighter blank plug. I store it in the glove box when not in use and then slot it in to the lighter socket when I'm in the car. It looks neat and the best bit is with the controller stowed in the glovebox and the ashtray flap hiding the screen, nothing is on display
Were the failures on the EPS motor, if so, did you get it repaired at ecu testing or just get 2nd hand one ?
The motor failed both times once 2 1/2 years ago and again 2 weeks ago. i had it repaired the first timemjennings23 wrote: ↑Sat May 19, 2018 1:42 pm Were the failures on the EPS motor, if so, did you get it repaired at ecu testing or just get 2nd hand one ?
