LED Reverse Lights - any links to buy them online
Sky-drive
Post by Sky-drive » Thu Jan 12, 2017 9:32 pm
LED reverse light arrived today, will fit tomorrow and report back hopefully with photos over the weekend of the standard bulb illumination and LED replacement
Royal | ZHP | CDV delete | AUX | DISA upgrade | cruise | MV2s | roof motor > boot | door spkrs | doors sound-deadened | K&N | sound gen | aero wipers | interior LEDs | heated seats |interior update in progress...
Chris_D
Post by Chris_D » Thu Jan 12, 2017 9:57 pm
Sky-drive wrote:LED reverse light arrived today, will fit tomorrow and report back hopefully with photos over the weekend of the standard bulb illumination and LED replacement
What type did u get?
Image Image Image
Now: E85 3.0iSE roadster (03) 'Bruiser'. E93 320d M-Sport Cabrio (11) 'Bob'.
Past: E36 323i (96) 'Benny' 18yrs/260k RIP. E46 M3coupe (03) 'Pongo' RIP. Ariel Atom 2(shared).
JINGLE
Post by JINGLE » Thu Jan 12, 2017 11:00 pm
Scooba_Steve wrote:No one can say they didn't see you reversing!
I had a set of CREE and while very bright, they just projected the light of one thousand suns horizontally with little useful illumination close to the car.
Shouldn't be a problem for me as I back in my drive along a fence to the side and rear so will light up the fence enough for me to see it :)
Hopefully anyway :rofl:
Rally
Post by Rally » Fri Jan 13, 2017 12:16 am
Watching with interest and waiting for feedback I have to reverse park very close to a kerb and would love more light.
Online
markplant
Post by markplant » Fri Jan 13, 2017 11:43 am
I find it OK as reverse in to unlit garage, an try to keep close on passenger side
Sky-drive
Post by Sky-drive » Fri Jan 13, 2017 4:07 pm
As per a previous post on this thread:
on Amazon search this: sourcingmap® Vehicle Car 1156 BA15S 30W White 6LEDs Turn Reverse Light Lamp Bulb
Removed the original reverse bulb and plugged in the LED light this afternoon ... and blimey its well bright!!!! Certainly the light of a thousand suns but not cheap: £13.68 + delivery ...
Chris_D
Post by Chris_D » Fri Jan 13, 2017 4:16 pm
Ah right, not too dissimilar to the first set I ordered:
http://www.ebay.ie/itm/2x-CREE-XBD-100W ... 2721451981?
bit cheaper at just under 7 quid however
do you reckon the aperture in the light housing is big enough to accept the diameter of the second type i ordered?
diameter at widest part is 20mm.
Image Image Image
Sky-drive
Post by Sky-drive » Fri Jan 13, 2017 4:45 pm
whats the diameter of an old school standard tail light bulb? If its more than 20mm then Im guessing you should be good to go with the 20mm LED.
Noticed the first set you purchased off Ebay aren't suitable for BMW:
"100% Integrated Design, Plug and Play. (Some vehicles may require resistor to stop flickering). The led bulb is not suitable for the Germany Car Without Resistor, for example: BMW, AUDI, Volkswagen, Mercedes-Benz ect."
Chris_D
Post by Chris_D » Fri Jan 13, 2017 5:11 pm
Sky-drive wrote:whats the diameter of an old school standard tail light bulb? If its more than 20mm then Im guessing you should be good to go with the 20mm LED.
Both sets cheap enough to just suck and see....
if they flicker i'll bang a resistor on it :thumbsup:
Image Image Image
Sky-drive
Post by Sky-drive » Fri Jan 20, 2017 12:28 am
So here are some images of the new reverse led bulb ...
LED Reverse Light Illumination.JPG (62.68 KiB) Viewed 186 times
LED Reverse lamp.JPG (19.22 KiB) Viewed 186 times
Chris_D
Post by Chris_D » Sat Jan 21, 2017 5:47 pm
Sky-drive wrote:So here are some images of the new reverse led bulb ...
Looks good :thumbsup:
A whole plethoraof led's arrived in the post today so popped out to put the reverse one in.
I couldnt remove the halogen bulb from the plastic bulb holder however. The bulb isnt soldered in is it? I thought they were just supposed to pop out?
Didnt want to pull harder for fear of busting the bulb and mashing my fingers on broken glass!
Did u manage to remove ur existing bulb?
Image Image Image
G600
Post by G600 » Sat Jan 21, 2017 7:04 pm
Did you twist the bulb or just pull? They definitely aren't soldered in, assuming it's a pre facelift, I don't know about post as I don't have one.
E85 3.0
Sky-drive
Post by Sky-drive » Mon Jan 23, 2017 1:59 am
G600 wrote:Did you twist the bulb or just pull? They definitely aren't soldered in, assuming it's a pre facelift, I don't know about post as I don't have one.
Mine is a 53 plate E85 - I just took hold of the glass, pushed slightly down and then twisted and rotated out, its a bayonet fitting, my old reverse bulb just twisted very easily and came straight out.
Chris_D
Post by Chris_D » Mon Jan 23, 2017 2:10 am
yep. push in, twist anticlockwise. but sadly the led ones dont fit the plastic bulb holder. a smidge too wide where it steps out sadly.
might have a go at hacking away at the holder just for shits n giggles. determinedtomakeitfit.com
Image Image Image
Who is online
Users browsing this forum: 1000rr, HyperGrade, ionofchios, Mighty1, patrickbateman, PerryGunn, PhilinZ4, Smartbear and 20 guests
