Roof motor REPAIRS & RELOCATION for members...
Discount codes and service & product offerings from forum members
Ducklakeview
Post by Ducklakeview » Sun Apr 03, 2016 9:19 pm
So first tasks of the day;
Get roof motor out without removing roof, or any interior trim
Try and bring motor back to life, as it stopped working a few days ago, although was fine when I bought car.
Relocate to boot.
Time permitting, fit GapTech RCH+ module.
So, I reckoned there was no need to remove any interior trim.
Removed shelf under hood storage area, and also the left hand mount for same (one 10mm bolt, one torx screw and one plastic rivet)
Could then see the motor :)
Started to give it a good push/pull and then I heard water, climbs out of boot for about the 10th of 100 times, and sees this under car..
That's the drain unblocked then...
Housing had clearly been wet for some time.
And the insulation was like a wet sponge, silly idea.
Hmm..
Why they don't wrap them in a sealed bag I do not know, instead of this stuff.
IT would help prevent this!
I feared the worst for the motor
And the other side was worse.
I decided to use a shampoo bottle to protect the motor and connections, I also washed and dried the original pad from the bottom, and the motor insulation wrap, before gaffer taping that to to the bottle, no pic of the refitted insulation.
Made a small cut into the plastic of the shelf mount, to pass the cables through, and refitted it all. Carpet could do with a little more fettling, but I was in a rush to get out, so just used some spray adhesive for now, as I'm going to have to top up the oil I think. The white is the adhesive drying.
GapTech module fitted by soldering, and all good - So off out for a play!!
I think the oil level is low, as when opening the roof, it needs a hand to get it moving, but closing is perfect. Does anyone know the top up procedure, ie which way up should the motor be held, and is it done with roof up or down?
Hope this helps people, took me about 3hrs all in, and save me a good few ££!!
Mike
Darkangelv2
Roof motor brought back to life and relocated into boot, with pics.
Post by Darkangelv2 » Sun Apr 03, 2016 9:24 pm
Great job. The less £££ BMW get from us for their shoddy engineering the better!
BMW Z4 2006 2.5SI - BBS OEM 216 Wheels - Strut Brace
3.0si Brake Conversion - Custom Nappa Sport Interior - Soon Fitting -
BC Racing BR Coilovers - Stainless Exhaust Bypass - Ram Air Scoop
Number5
Post by Number5 » Sun Apr 03, 2016 9:28 pm
Mark the fluid level then cycle the roof. Watch if the level is highest or lowest with the roof up or down and then only top it up from the highest mark, otherwise it will overflow if you top it from the lowest point, when you cycle the roof.
Silver Alpina Roadster S Lux (#019)
2007 Sapphire Black 3.0si
Daily: F11 520d M Sport Auto
Previous
Z4 Roadsters:- i) 2004, 2.5SE, ii) 2003, 3.0SE, iii) 2006, 2.5SE
iv) 2004 3.0SE. v) 2005 2.5SE, vi) 2007 3.0si
andy.c
Post by andy.c » Sun Apr 03, 2016 9:28 pm
Great write up and top work :thumbsup: ,
barneybear
Post by barneybear » Sun Apr 03, 2016 9:31 pm
Great to know that the motor can be removed without taking the roof off, I will definetly have a go at this when the time comes :thumbsup:
Ducklakeview
Post by Ducklakeview » Sun Apr 03, 2016 9:32 pm
Number5 wrote:Excellent Job. well done.
I take it the fluid reservoir needs to be at the top to feed the pump? If so, do you then invert it, remove the circlip and reservoir and top up?
Mike
Ducklakeview
Post by Ducklakeview » Sun Apr 03, 2016 9:43 pm
Just had a thought, after reading a couple of threads. I wonder if my bowden cable is partially seized at the pump end, causing the slow opening, thinking about it, if it was low on fluid, then surely it wouldn't close properly, as the reservoir would run out as the fluid moved into the extending rams... I think I'll check that tomorrow, seeing as I can now access the whole assembly in seconds :)
Mike
Marlon
Moderator
Moderator
Post by Marlon » Sun Apr 03, 2016 9:48 pm
Can't believe you managed to resurrect that rusty lump of metal - top job and excellent write up and pics :thumbsup:
3.0si 2008 | Remap | M seats | M wheel
Cruise | Style 32 alloys | DLV back box
biggeoff
Post by biggeoff » Sun Apr 03, 2016 10:04 pm
great post well done
Number5
Post by Number5 » Sun Apr 03, 2016 10:04 pm
Leave the resevoir at the top, motor below. Undo the fat grub screw on the top and pour a drop in gently. :thumbsup:
Previous
Ducklakeview
Post by Ducklakeview » Sun Apr 03, 2016 10:06 pm
Number5 wrote:Leave the resevoir at the top, motor below. Undo the fat grub screw on the top and pour a drop in gently. :thumbsup:
Grub screw? Didn't notice one, I take it that it's on the pump body?
Mike
Ant
Post by Ant » Sun Apr 03, 2016 10:52 pm
i replaced my motor when i bought the car nearly two years ago now...
tempted to try get it relocated during the summer now ya can see it can be done without removing the roof (which is what put me off)
touring_style
Post by touring_style » Sun Apr 03, 2016 11:18 pm
Really good work and very useful to know this can be done without removing the roof. :thumbsup:
Question - when you removed the motor did you have to disturb the hydraulic lines at all , or can the motor "cylinder" be removed from the bulky square section and oil reservoir that houses the hydraulics without complications?
Also can you elaborate on "ultrasonic bath in deionised water" - what is this?? :?
2004 2.2i SE
jabber
Post by jabber » Mon Apr 04, 2016 5:49 am
great job how is the motor secured in position?
10 E89 Z4 3.0 Black auto
15 F23 220d lux convertible silver auto
Ducklakeview
Post by Ducklakeview » Mon Apr 04, 2016 9:31 am
There is a large earth connection just behind the carpet in that area, the stud was long enough for me to fit a cable tie base and another nut, the motor is held to it with 2 thick cable ties.
Mike
Who is online
Users browsing this forum: No registered users and 3 guests
