She's not insured for that very reason, but suppose mechanic is plausible.abar121 wrote:Yes, or your other half drove it, went for the brake and also hit the loud pedal! Or a mechanic!
Heel and toe...
Re: Heel and toe...
Simon's Ruby Black Z4 MC Journal
viewtopic.php?t=70563
E36 M3 Evolution - Individual Journal
http://www.bmwowner.com/forum/viewtopic ... 6&t=209427
The closer you are to death, the more alive you feel!
- BMWZ4MC
Re: Heel and toe...
The way I've fitted mine it can pivot out of the way minimising the chance of a mechanic stamping on both pedals whilst going for the brake. An alternative would be to fit a fixed metal extension to the pedal which would be less ugly but lack the adjustability for different footwear and for other drivers.
S2000 GT - gone
- BMWZ4MC
Re: Heel and toe...
Cheers - it's the rounded end of a 300mm steel rule. I cut off the last 100mm or so and attached the foot from an old amplifier through the existing hole in the rule. I slipped the cut end under the pedal cover before final tightening of the pedal cover mounting screws. All very simple and cheap to makeMachine monkey wrote:I have learnt to do it on the zed. Its not easy with normal road driving but its perfect on track with harder braking.
BMWZ4MC i love that and i will be adding to mine shortly
S2000 GT - gone
- Machine monkey
Re: Heel and toe...
Looks great I will get keeping an eye out for the appropriate rubber bung! Or something with aluminium and o rings?!?
Heel and toe...
OP - maybe the name heel and toe can be taken too literally. . . In my M I use more of a roll of the foot using the inside of the right sole for the brake and the outside of the sole on the throttle with my right foot at a slight angle to cover both pedals. I've found it also helps to have the Sport button on as a dab of the throttle brings more revs when working at the higher rev range rather than having to push the throttle much further when driving without the sport button on. I've found it's a vital technique for driving the M fast on tighter roads as any downshift will upset rear if not rev matched. Piloti driving shoes have a wider sole across the ball of the foot which makes them useful for (so-called) heel and toeing.
(Like other posts have mentioned - there's nothing like having to deal with a car that won't run at low revs or has a dodgy handbrake to help you polish your technique - guess it's more something to do with 'older' cars (and older members?) )
Heel and toe...
I seem to be in the minority here in saying I find the pedal box ideal for heel and toe, but the car has to be in Sport mode or the throttle is far too slow to pick up
- buzyg
Heel and toe...
I can take a hint.paulgs1000 wrote: ↑Wed Jun 20, 2018 1:24 pm I've found it's a vital technique for driving the M fast on tighter roads as any downshift will upset rear if not rev matched.
- BMWZ4MC
Heel and toe...
I think I’ve posted this before. This is how to drive a Holden Barina on a twisty road in the far north of Queensland
S2000 GT - gone
Heel and toe...
Totally agree, near impossible without the perked up throttle response in Sport mode!mjennings23 wrote: ↑Wed Jun 20, 2018 3:35 pm I seem to be in the minority here in saying I find the pedal box ideal for heel and toe, but the car has to be in Sport mode or the throttle is far too slow to pick up
08 Z4 3.0si Sport Coupe in Montego Blue
