Rear end Quad Conversion Progress.
- cj10jeeper
Re: Z4 M Front Project Begins.......Mmmmmmm(and now rear too).
Neat installation, but not convinced they look quite right. To me they detract from the great shut lines that come down the bonnet/light and up the brake vent in the bumper. The widened 'X' shape.
As always each to their own and I'm sure I'll be in the minority.
- jakblade
Re: Z4M Front Project Endeth....Mmmm(and now rear too with Quad Conversion(maybe)).
Continuing with rear end enhancements. Need a Quad zorst to go with modded bumper....and so it begins....
Start with one of these..........
And chop the top off....what do you find??? Not a lot!!!! Not what I was expecting.......
Going to attempt to turn the bottom pipe in the last pic to the left and exit it out of the side of box. Then take it across behind bumper to a twin outlet......just need to source some stainless pipe now...
Hhmm,Hhmm. As the mighty MM has pointed out to me my initial plan may cause some unwanted noise/backpressure issues so a re-think is called for. Another plan filed under b1n.....
2004 2.5,clear fronts,sides,rears,stubby.Self quad conv+rear bumper, Aero's,108's,spacers, cruise, mfsw, 3.0l brake conv,m-tec discs.Modded Z4M bumper
- hopz121
Re: Z4M Front Endeth...(and now onto rear end with Quad Conversion(maybe)).
Jakblade a few questions for you mate.
Did you fit any of the airduct brackets or a new m undertray for the install?
Does the bumper flex a lot of not?
Do you have any pictures underneath where the bumper meets the old undertray?
Ash
Ash
2004 BMW E46 M3 Coupe - Manual - Silver Grey
2017 BMW F31 318d M-Sport - Auto - Glacier Silver
2007 Porsche Cayman 2.7 - Manual - Arctic Silver
2003 Renault Clio 172 Cup - Blue
2003 BMW E85 Z4 3.0i - Gone
2008 BMW E90 330i SE - Gone
- cj10jeeper
Glad you've had a rethink on the backbox. I was worried that simply turning one pipe and exiting the right hand side would create one pipe some 1-2m longer and invariable increase in pressure, probably exhaust note change and maybe even decreased performance.jakblade wrote:Continuing with rear end enhancements. Need a Quad zorst to go with modded bumper....and so it begins....
It's for these reasons I went custom pipework from mid car to twin boxes at the rear, creating the right note and no change in performance.
- jakblade
After some re-thinking and discussion with MM decided that this is probably the way to go..........cj10jeeper wrote:Glad you've had a rethink on the backbox. I was worried that simply turning one pipe and exiting the right hand side would create one pipe some 1-2m longer and invariable increase in pressure, probably exhaust note change and maybe even decreased performance.jakblade wrote:Continuing with rear end enhancements. Need a Quad zorst to go with modded bumper....and so it begins....
- jakblade
Now then Ash, No I didn't fit any airduct brackets but still to do is to put the ducting actually on to the brakes, so will probably just mount to the wheelarch liner.hopz121 wrote:Jakblade a few questions for you mate.
Ash
the bumper doesn't appear to flex too much and at the moment I only have some temporary fixings to the original undertray. This will be resolved once I have finished the centre piece splitter, which will sit just a little bit higher than the protruding fang protectors and attach to bumper and pick up existing undertray mounts....
No pics as yet, waiting until the splitter is complete.
- cj10jeeper
That looks much better as you're just adding an extra exit to the backbox, rather than diverting 50% of the flow along a new pipe. Hope all the exhaust doesn't choose to follow the original route.jakblade wrote:After some re-thinking and discussion with MM decided that this is probably the way to go..........cj10jeeper wrote:Glad you've had a rethink on the backbox. I was worried that simply turning one pipe and exiting the right hand side would create one pipe some 1-2m longer and invariable increase in pressure, probably exhaust note change and maybe even decreased performance.jakblade wrote:Continuing with rear end enhancements. Need a Quad zorst to go with modded bumper....and so it begins....
Call me pedantic on this but I want all 4 pipes to steam equally on a cold day.
Of course you can always go back and partially restrict one of the original exits..
- jakblade
Just a little update... Mocked a few parts together for the quad exhaust now all my parcels have arrived. Probability of some adjusts need for the finished article but you get the idea.........I think......
- Steve84N
That's quite clearly not going to work as the original tips stop at the edge of the table and the new ones don't even start until well beyond it... Looks like you need to take a feed from the side of the box rather than the back.
C63 AMG Estate 6208cc
- jakblade
Point taken. That's why I mentioned some final adjustments necessary. Just got excited with all the new bits and wanted to see how they would fit together. Got some more bends coming to allow me to put a set in the straight pipe to gain the room needed...hopefully.Steve84N wrote:That's quite clearly not going to work as the original tips stop at the edge of the table and the new ones don't even start until well beyond it... Looks like you need to take a feed from the side of the box rather than the back.
Just waiting for the weather to turn really crap so I can remove the rear off the zed and get existing box chopped off and start a dry fit to see how stuff fits on the car........Wish me luck.....
- Yorkie Z
What's your plans to improve the sound. That's just going to sound stock as it is..??
I joined the pipes up inside my back box
viewtopic.php?f=2&t=62691&p=999219&hili ... nd#p999219
A Dirty M///
- Steve84N
An angle in the pipe might give you the room as long as there's clearance under the car. Fair play for doing it yourself and good luck.
- jakblade
Thanks for that Yorkie. Just read your thread, lots of info in there. I just wanted a quad set-up and if I freed up any noise...bonus. But you have me thinking now.....mainly how to make a 2 into 3 inside the box????Yorkie Z wrote:What's your plans to improve the sound. That's just going to sound stock as it is..??
How did you get on and how did it end up ???
- jakblade
Not done yet. Been waiting for it to warm up a bit my workshop is like a bleedin fridge in winter.spic wrote:How did you get on and how did it end up ???
Progress is about to continue shortly so updates will be forthcoming.
