85genius wrote:May have even gone in the wrong hole looks like there's 2 of them lol. Might have to post a photo tomorrow if I still can't find it
Can't wait to see the pics!
This may help85genius wrote:May have even gone in the wrong hole looks like there's 2 of them lol. Might have to post a photo tomorrow if I still can't find it
Only way to be certain is to run water through. Anything else just checks the lower end of the drain pipe, not the constructions higher up. (Unless you used a 2' zip tie)firebobby wrote:I flicked a cable tie around in my drains and it was clean and dry on both.
Yes, but I was never brave enough because if they're blocked from above the drain holes then you are simply drowning your roof motorbrazenskies wrote:Glad I found this thread. Will try this tomorrow.
Once their out can I test them pipes by just pouring some water on the side of the roof?
I check mine by the pouring water method, you only need to pour a little in to ensure the drains aren't blocked-if they happen to be blocked you'd get more water than that going in the next time it rained anyhowbrazenskies wrote:Ha! That's definitely a concern.
These bungs surely must serve some other purpose than just noise deadening? I don't imagine water or other crud would track back up the pipe
