Its very leggy for the price.Shaz79 wrote: ↑Tue Jun 22, 2021 11:41 am https://www.ebay.co.uk/itm/294211298393 ... SwjV9ft72O
Does anybody know this car as I am going to view and make a deal on it
Wheels will be changed on the same day as I can’t stand black wheels.
Z4 3.0 Coupe market watch
Could be a good buy depending on the service history and what price you can agree (e.g. closer to £8k) as the spec (midnight blue?) with champagne is quite nice.bg1 wrote: ↑Tue Jun 22, 2021 11:54 amIts very leggy for the price.Shaz79 wrote: ↑Tue Jun 22, 2021 11:41 am https://www.ebay.co.uk/itm/294211298393 ... SwjV9ft72O
Key really is the service history and what has been done in terms of maintenance at that mileage. I see from the MOT there have been reports of play in the suspension, at that milage it is likely due for a refresh if it hasn't had it already? Then the usual suspects of water pump, ABS motor, gaskets etc.
If the on paper history checked out, if I were looking it I'd see if I could bring an OBD II computer to plug in (discretely) to see any logged errors. If I were to buy it, I'd probably take it to an Indy to have it checked over (potentially as part of replacing the wheels) and make use of that 3 month warranty for any issues they reveal.
Good luck!
Agree with all of the above and the car doesn’t seem to have been driven since the last MOT in October (114,422). MOT history says “blue”, so this is likely to be Monaco Blue which often looks quite black in photos. The black wheels are a bit much.Jameszy wrote: ↑Tue Jun 22, 2021 12:07 pmCould be a good buy depending on the service history and what price you can agree (e.g. closer to £8k) as the spec (midnight blue?) with champagne is quite nice.bg1 wrote: ↑Tue Jun 22, 2021 11:54 amIts very leggy for the price.Shaz79 wrote: ↑Tue Jun 22, 2021 11:41 am https://www.ebay.co.uk/itm/294211298393 ... SwjV9ft72O
Good luck!
2003 Maldives Blue 3.0i auto
Ok thank you for the feedback
I was thinking the same, 8k ish
It’s full loaded and has dsp Audio, cruise control and has FSH and will be serviced prior to sale. I think the suspension will need a refresh, abs and water pump.
I would buy @8k
I would buy @8k
Sounds a good option then to be honest, especially if that service is an Inspection II (e.g. spark plugs etc).
If I were taking the keys, the first thing I’d do is still take it to a reputable Indy for a once over and make use of that 3 month warranty.
Yes I will do. Probably going to buy it
Already down to 8600 without seeing it
Get them to change the rear brake lines to clear the MOT advisory
E86 In sapphire black
Is it a big job,
Replacing brake lines ?
- Mr Tidy
If it's the metal brake pipes the driver's side one has to go across the car between the bulkhead and the petrol tank.
BMW pipes are pre-shaped so fitting them involves dropping the tank, but if replacing in copper/kunifer it can be threaded through the support mounts with the tank in place then shaped to fit.
Coupes because stunning!
Gone - Montego Blue
Gone - Ruby Black
Gone - Montego Blue
Gone - Ruby Black
How do I find out if it had dsp audio
How do I know if it has dsp audio ?
He said it has upgraded hifi
Thank youMr Tidy wrote: ↑Tue Jun 22, 2021 9:49 pm If it's the metal brake pipes the driver's side one has to go across the car between the bulkhead and the petrol tank.
- Mr Tidy
It won't have storage cubbies in the bulkhead behind the seats as they will have speakers in them!
Gone - Montego Blue
Gone - Ruby Black
Gone - Montego Blue
Gone - Ruby Black
Ok will check
Ok he’s agreed to do water pump, new springs, full service including spark plugs delivered to me. For 8200.
Mileage is 118k
Should I go for it and what what springs and water pump should I request for
Mileage is 118k
