Changing M54 to S54...
GuidoK
Post by GuidoK » Sun Jan 29, 2017 2:50 pm
robbansson wrote: need another differential as well, preferably with ratio 3.85 and LSD
If you're staying with the stock rear axle/rear subframe (and thus are bound to a 188k diff) the shortest ratio you can get is a 3.73:1.
That is fitted on the US only 3.0i facelift automatic (so the US only downtuned n52 engine).
I dont know if there's an lsd for that ratio (different ratio's sometimes need different lsd's because of the different offset of the crown gear flange)
robbansson
Post by robbansson » Wed Feb 15, 2017 11:29 pm
Just got this back from surface treatment Nice....
DSC_1226 (1).JPG (86.54 KiB) Viewed 957 times
2003 S54 Roadster, M- exhaust, Powerflex, Eibach B12 Pro-Kit, Brembo 4p 348mm floating front / 336mm rear, Recaro seats,
GuidoK
Post by GuidoK » Thu Feb 16, 2017 2:02 am
What surface treatment is that? Looks like some kind of passivation? (like CrIII like they do on zinc etc)
kis
Post by kis » Thu Feb 16, 2017 9:25 am
Smartbear wrote:Lovely shiny pieces :)
Subscribed! Good to see some nice shiny engine pieces pics! And look forward to updates! :D
My E85 Z4 3.0i SMG
1 Series - E87
4 Series - F36, F82 M4
5 Series - E34 (x2), E39
7 Series - E32
X5 - E53, E70
X6 - E71
robbansson
Post by robbansson » Sun Feb 19, 2017 3:58 pm
Surface treatment is something called NEDOX, gives a hard surface with very low friction, it's used a lot by scania and volvo in there truck engines.
Smartbear
Post by Smartbear » Sun Feb 19, 2017 4:18 pm
robbansson wrote:Surface treatment is something called NEDOX, gives a hard surface with very low friction, it's used a lot by scania and volvo in there truck engines.
Is that similar to shot peening?
e85 3.0si sold
robbansson
Post by robbansson » Sun Feb 19, 2017 10:31 pm
No, It' coated with chemical nickel and PTFE
http://www.magnaplate.com/coatings/nedox
LittleZ4
Post by LittleZ4 » Sun Sep 10, 2017 12:51 pm
Following this, Is there any further updates? :)
3.0i Maldives blue, Coilovers, Bola B1's, Buckley06 Gear knob, Handbrake & Indicator badges, Backbox delete, CDV delete, cupra r splitter, RAM air filter, Bigger Brakes, M3 ARB, SMF.
robbansson
Post by robbansson » Thu Jul 12, 2018 12:56 am
some update!
Copy of IMG_20180225_163803.jpg (251.44 KiB) Viewed 679 times
robbansson
Post by robbansson » Thu Jul 12, 2018 12:57 am
emty....
Copy of IMG_20180414_141056.jpg (219.39 KiB) Viewed 679 times
robbansson
Post by robbansson » Thu Jul 12, 2018 12:58 am
and... :D
Copy of IMG_20180630_125643.jpg (181.89 KiB) Viewed 680 times
Copy of IMG_20180630_133317.jpg (200.87 KiB) Viewed 680 times
robbansson
Post by robbansson » Thu Jul 12, 2018 1:00 am
and some more...
Copy of IMG_20180630_133312.jpg (198.03 KiB) Viewed 680 times
Copy of IMG_20180630_184846.jpg (157.99 KiB) Viewed 680 times
In Place !!!
:driving: :driving: :driving:
Copy of IMG_20180630_184852.jpg (192.41 KiB) Viewed 680 times
robbansson
Post by robbansson » Thu Jul 12, 2018 1:06 am
also working on an LSD in the original casing...
from a M3 E39 i think...
Copy of IMG_20180408_221328.jpg (179.19 KiB) Viewed 680 times
had to make a new piece, the old one was broken,
Copy of IMG_20180608_171420.jpg (118.39 KiB) Viewed 680 times
Copy of IMG_20180513_141519.jpg (121.93 KiB) Viewed 680 times
robbansson
Post by robbansson » Thu Jul 12, 2018 1:16 am
broken vs new..
robbansson
Post by robbansson » Thu Jul 12, 2018 1:18 am
some small bits that found there place...
Lollipop bearing.jpg (100.56 KiB) Viewed 680 times
