Updating Sat Nav software
Hi,
I've just come across a sat nav software upgrade CD on eBay. Are they safe? Has anyone had a go yet?
If you search for 'bmw v29.1' on eBay UK you'll come across a whole load of them.
- pvr
You can download the same from Here
Current:
911-50 Black - unique spec
X5M - 575 hp of fun in a V8
Abarth 595 Comp.
Z4 3.0si Black Sapphire
VW ID.3
Previous:
Z4 3.0 Toledo
Abarth 595 Comp.
VW ID.3
Previous:
Z4 3.0 Toledo
- sp3ctre
- Site Admin
Be careful with it... if you get a corrupt disk you could knacker your unit...
- davidpfitz
Don't waste your money buying it from eBay!
If you don't want to get it from your dealer, and don't mind the shady legalities of it (although no shadier than buying from someone on eBay) you can find it elsewhere and burn it to a CD yourself.
The chaps at X5World's Navigation Forum will have details of everything you need.
D.
D.
- pvr
It is safe as long as you verify the cd before you load it. Using Alcohol to burn it at the slowest speed, no issues.
I updated both my units without issues.
Current:
Abarth 595 Comp.
VW ID.3
Previous:
Z4 3.0 Toledo
Abarth 595 Comp.
VW ID.3
Previous:
Z4 3.0 Toledo
- pvr
- sp3ctre
- Site Admin
yeah, I know that... just warning, as it's not a download from an official site that's all.
- davidpfitz
Apparently this is on the disc:
(C) 1999, VDO Car Communication Germany GmbH
All rights reserved. No part of this work may be reproduced
or copied in any form or by any means (graphic, electronic,
or mechanical, including photocopying, recording, recording
taping, or information and retrieval systems) without the
written permission of the copyright owner.
- tehdarkstar
- davidpfitz
Depends from which version you are upgrading from. But apparently has more 'aggressive' routing algorithms. Which is odd, because mine *still* routes me from the A40, to the M4, to the M25 to the M40 (London to somewhere west) when it is clearly a hell of a lot quicker to just stay on the A40 until it meets the M40.
Bananas!
I'd like a SatNav which learned that when I repeatedly override a route portion with a route of my own I mean I know better than it does, and it should switch to guiding that way from then on. I should probably patent that.
D.
Bananas!
D.
- pvr
Can you also patent that if you take a particular route on the way to a location, that you want to go back via the same route and not via yet another one ...
Current:
Abarth 595 Comp.
VW ID.3
Previous:
Z4 3.0 Toledo
Abarth 595 Comp.
VW ID.3
Previous:
Z4 3.0 Toledo
- davidpfitz
- Shunt
Email [email protected] I got mine with speedcameras and traffic rerouting. no problems at all.
Aston V8V
- RCNet
You can also update your splash screen
If you update the Nav firmware yourself it also allows the opportunity to personalize your Z4 a little bit more. The instructions on how to update the firmware can be found here on Z4-Forum in this thread.
I updated my splash screen to this when I updated my firmware:
2006 Ti Silver Z4 M Coupe
2009 Deep Sea Blue 535i xDrive Sports Wagon
