Post
by bcworkz » Fri Aug 03, 2012 6:27 pm
If you want big power gains for your existing engine for anything close to a reasonable price, a bolt on engineered product is really the best alternative (ESS etc.). You spend your money, spend a few days for installation, and you're up and running with big power.
Converting an M54 to an N54 would be an interesting project, but it's a project. Your car will be out of commission for weeks, if not months. There's a lot of unknowns to research. Even if you think you've researched everything, things will still come up which were not anticipated, requiring creative solutions and likely additional expenditures. It may look like an affordable approach by adding up the parts costs, but that's only part of the picture. Does anyone know if the parts are really bolt for bolt compatible? All it takes is one bolt hole being changed a mm to cause lots of expensive custom machining. How do you handle fundamental differences like direct vs. port injection? And there's one of your original questions, are the electronics a problem? YES! Not insurmountable, but something you'll have to deal with, costing more time and money.
Will the N54 maps even be proper for your solution? It may run, but may not be ideal, remapping = more time and money. The N54 ECU will run the engine, but will it interface with the car? Maybe, but probably not plug and play. More time and money. It's not just the engine ECU, you also have the immobiliser module to interface. There's seemingly endless interface issues to deal with, mechanical and electronic.
What do you really want? A project? Or just more power?
"The cause of most problems are solutions" (06 3.0si, sport pkg)
