Lets more noise from the engine into the cabin,domsz4 wrote:what do you mean by foam removed from sound generator? what does that do?
the foam is just a noise baffle, and with them removed you get a noticbly louder engine sound inside
ah right, where is this bit? i find with my 3.0l i get an annoying sound at certain revs. it really resonates in your ear and can be a little unpleasant. not sure i want more noise but maybe the lack of foam will change it a bit. cheerssam1832 wrote:Lets more noise from the engine into the cabin,domsz4 wrote:what do you mean by foam removed from sound generator? what does that do?
Open the bonnet, left hand side, follow up from the air boxdomsz4 wrote:ah right, where is this bit? i find with my 3.0l i get an annoying sound at certain revs. it really resonates in your ear and can be a little unpleasant. not sure i want more noise but maybe the lack of foam will change it a bit. cheerssam1832 wrote:Lets more noise from the engine into the cabin,domsz4 wrote:what do you mean by foam removed from sound generator? what does that do?
Thanksbs0u0118 wrote:What did you use to revamp the door gab handles? Looks great!
Nice one, a link would be great, I need to do my drivers side trim.sam1832 wrote:Thanksbs0u0118 wrote:What did you use to revamp the door gab handles? Looks great!
I used 3m vinyl
I will find a link for ebay when in not on my phone mate
Make sure you get 3m tho the cheaper stuff is just that and is real hard work
Sent from my GT-I9300 using Tapatalk 2
Here you gobs0u0118 wrote:Nice one, a link would be great, I need to do my drivers side trim.sam1832 wrote:Thanksbs0u0118 wrote:What did you use to revamp the door gab handles? Looks great!
I used 3m vinyl
1st 1,a well documented topic on here..as adamski would say/its been done to death,lol..alot of ppl do it,but some(like myself)dont see the need. each to their own.domsz4 wrote:what do you mean by foam removed from sound generator? what does that do?
still trying to figure out what the CDV. putting it into the search gives me no resopnces
I've read on a number of boards that the CDV can simply be removed at the hoses connected directly, without a modified valve. What's the benefit to modding the valve instead of removing it?craig3.0 wrote:As for th cdv..its the CLUTCH DELAY VALVE.
You can get a modified one of these,or modify it yourself. available from the likes of zeckhausen,which improves/gets rid of the jerky change you can get between 1st/2nd gears.
BMW over-engineered the car with this being fitted,as it cures a problem that doesnt exist/ie makes bad drivers able to change gear,haha.
It causes jerkiness in lower gearchanges,almost making the car die on you inbetween gears at times...SO A MODIFIED CDV IS A GOOD MOD(Basically a blanked off cdv)and easy to install
A modified valve is only for if you still have a bmw warenty,Mitch89 wrote:I've read on a number of boards that the CDV can simply be removed at the hoses connected directly, without a modified valve. What's the benefit to modding the valve instead of removing it?craig3.0 wrote:As for th cdv..its the CLUTCH DELAY VALVE.
