Yupp. A couple of weeks for a Trolley jack to be delivered, then the weather either put me off getting wet, or lured me into a hoon instead. Next week is work free so I'll be doing a mix of hooning and fettling.Bing wrote:By gum it has taken you a long time to get your car jacked upStuart Truman wrote:Just bought one of these in an attempt to minimise potential damage caused by jacking...
Jacking Points/Trolley Jack recommendations
- Stuart Truman
Re: Jacking Points/Trolley Jack recommendations
Add yourself to the Z4 Map HERE! Instructions HERE!
Z4M Roadster, Imola Red, with Stubby and Intravee II. Low Miles per Gallon, High Smiles per Gallon
Previously Alpina Roadster S #69 Alpina Blue
- ben g
those adaptors are definitely needed. mine are buggered now after jacking the car up a few times. one of the jacking point blocks has also gone missing
- Beedub
think ill order one of those jack pads, awesome idea...
OP are you happy with it?? decent quality?? no drawbacks to this??
- Bing
Been meaning to get one for ages - no drawbacks, the jacking points are designed for one of these IIRCBeedub wrote:think ill order one of those jack pads, awesome idea...
Current... Silver Grey ///M Roadster, non-flimper spec, Imola Red nappa, permanent ear-to-ear grin
- TINO
4 Jacking points about hinge point on the front six inch in front of rear wheel on the back, all loo like a square box. just take the jack from the e46 no probs.
- TINO
sorry hinge point on the doors.
- Stuart Truman
Only ordered it today. A lot seem to be made of metal, this one is vulcanised rubber so little chance of it damaging the paintwork underneath the carBeedub wrote:think ill order one of those jack pads, awesome idea...
- Beedub
also picked one up...... let hope its worth it!!!
- bcworkz
Facelifts are the same as M for jacking points. I use some folded shop rags to pad the jack so as not to mung up the bolts at the rear jack point, and not mung up the bottom cover at the front. Couldn't say for pre-facelifts, but should be something similar available.
For the side points, some sort of insert is definitely highly desirable. I just use a small block of wood with a screw jammed into it which drops into a hole on both my jack and axle stands.
"The cause of most problems are solutions" (06 3.0si, sport pkg)
- ranski
I picked up one of these when I first got the Z.
It works well, although you will need to remove the cap from your jack, as it will need flat surface for the pad.
Z4 3.0 / Mods done... too many to mention
- bigshurv
Another vote for the Costco jack. A real meaty thing that goes straight under the Z.£ 70 I think.
Stu,
The Alpina does NOT have the central jacking points as per M.
Andy
Alpina Roadster S LUX #339 (Alpina Blue) - Fully Loaded, inc electric toothbrush and digital TV
- Stuart Truman
Cheers! When the rubber bung appears I'll take a look. For now the trolley jack remains in its boxWobblewing wrote:Stu,
I've got a halfords jack. I have had it go straight under, but last time I had to drive the wheels onto some wood to get it high enough. Only needs lifting about 1cm. With one of these adapter thingybobs you may have to raise it further... although they do look a good idea.
Andy
I have a low profile jack from machine mart does the job also have a jack pad mine has a cut out too so can use it on the oem jack points on the mrs focus and parents megane
Gone.....Z4 2.3 sDrive, Black, Black Leather, I drive, Sound upgrade and a couple more bits..6 cylinder symphony
Now 520d, Beige Leather, I drive, VDC, BMW Individual Wood trim, Memory Seats, Powered Boot...55mpg!
