Bad_Pritt's Black Pearl II - Z4QP 3.0si
- Bad_Pritt
- Bad_Pritt
- Bad_Pritt
Re: Bad_Pritts Zed
I am also considering to replace my headlight bulbs with xenon-look bulbs. Does anyone know which bulbs or type of bulbs I need?
Re: Bad_Pritts Zed
I have changed mine approx 1hr ago! I purchased some fairly cheap xenon "look" ones off eBay for a few £. Brightness seems to have improved slightly. I also raised the alignment using the adjuster screws under the bonnet to achieve a further distance as they were pretty low beforehand. Much safer nowBad_Pritt wrote:I am also considering to replace my headlight bulbs with xenon-look bulbs. Does anyone know which bulbs or type of bulbs I need?
- Bad_Pritt
Re: Bad_Pritts Zed
cool! which ones did you buy, do you have a link?greenson wrote:I have changed mine approx 1hr ago! I purchased some fairly cheap xenon "look" ones off eBay for a few £. Brightness seems to have improved slightly. I also raised the alignment using the adjuster screws under the bonnet to achieve a further distance as they were pretty low beforehand. Much safer nowBad_Pritt wrote:I am also considering to replace my headlight bulbs with xenon-look bulbs. Does anyone know which bulbs or type of bulbs I need?
- Bad_Pritt
- Stuart Truman
Re: Bad_Pritts Zed
Awesome!Bad_Pritt wrote:(small) update: just mounted fog leds. Now I have led DRL's
Add yourself to the Z4 Map HERE! Instructions HERE!
Z4M Roadster, Imola Red, with Stubby and Intravee II. Low Miles per Gallon, High Smiles per Gallon
Previously Alpina Roadster S #69 Alpina Blue
- Bad_Pritt
- Woody
Re: Bad_Pritts Zed
Looks MUCH better, all nice and symmetrical now
- Bad_Pritt
- Bad_Pritt
- VENDAR
Re: Bad_Pritts Zed
Is it easy to install the cruise control on your own? How much did the actual kit cost you?
- Mau
Re: Bad_Pritts Zed
That is verry easy; on the pre fl wiring is already there. You just need the control stick from the dealer (in the Netherlands roughly EUR 65), some handtools and 45 minutes of your own time...
More on the '03 roadster and '08 coupe:click me.
