dodged a bullet - DISA valve disintegrated
- ranski
I think the new one is slightly different? well at least the part number is
Z4 3.0 / Mods done... too many to mention
- Bing
Re: dodged a bullet - DISA valve disintegrated
The facelift is different - no metal pin, green rubber seals, and appears to be motorised / electronically operated as it isn't possible to move the valve by hand.ranski wrote:I think the new one is slightly different? well at least the part number is
Current... Silver Grey ///M Roadster, non-flimper spec, Imola Red nappa, permanent ear-to-ear grin
- markeg
Have you done it on yours Stuart (Being that ours are the M52 (S52B32) version) ? Haven't got any rattles (yet) but may just do a sanity check at the weekend.... wondering if there are any gotchas.Stuart Truman wrote:Unfortunately yes, there are a couple of threads on here. Bing recently posted a pic laden post here on checking them http://www.z4-forum.com/forum/viewtopic ... SA#p497974
Glad you caught it before it got really nasty
previous: Alpina Roadster S, #108: gone
current: MB C-class
"veni, vidi, velcro - I came, I saw, I stuck around..."
current: MB C-class
- andysat
PHEW that was close!!!!
Gone but not forgotten.
New ride silver e93.
- IvanDobskey
Yikes, very lucky escape indeed! Got mine checked as part of my last service. No problems found and mine has done 78k.
2.5i Roadster Maldives blue with 108's and a stubby
- Stuart Truman
God alone knows what I've got with the mashup N52 B32 engine in an Alpina. I need a specsavers type ad. "Should have bought an M"Stromtech wrote:Only 1 wiring connector, 2 torx bolts and about 10 minutes time...not much to figure out. It's easily assessable.
And from everything I have read the only changes made to the DISA were for the N52 engine. The M54 still uses the original DISA design and should be inspected at 50K. My new one on my 3.0i M54 (2 months ago) still had the same design with the same metal pin.
Add yourself to the Z4 Map HERE! Instructions HERE!
Z4M Roadster, Imola Red, with Stubby and Intravee II. Low Miles per Gallon, High Smiles per Gallon
Previously Alpina Roadster S #69 Alpina Blue
- bigshurv
Mine had done about 50 k when it started rattling. I changed it straight away, took me about 10 mins.Could have driven it for a few more miles but decided it wasn'y worth it.Don't change it if it's not rattling.
- EdsTTer
Hi guys, even though it doesn't seem to be rattling, I just checked my DISA whilst I was investigating my "ghost whistle" (yep, there's a split in the concertina part of the lower inlet boot)
The metal pin seems to be secure but the flap has about 5mm of rotational slack before it stiffens up against the actuator piston. Is this normal? The YouTube vids seem to show no slack when turning the flap by hand...
The cars a 2003 2.5i and done 66K. Would you advise replacing it?
'03 Silver 2.5i with black leather and aftermarket xenons (what a difference)
now
'04 Black Sapphire 3.0i SE with red leather sports pack and... sapphire black hard top
now
- bigshurv
A new one has no slack, so yours is showing some signs of wear.Mine had started rattling a bit which drew me to investigate it and did indeed have similar movement to yours. If it was mine,I'd replace it.
- EdsTTer
Thanks bigshurv.
I'm collecting a new one at 1:30 today £124.65 + vat from the Stealers... and a new rubber inlet boot.
now
now
Do the Alpinas have DISA valves? Saw some discussion but no conclusion!
Current:
E85 Alpina Roadster S Lux, E64 650i, E65 740i, E31 840ci Sport Individual Estoril
History:
E85 3.0si sport individual, E31 850Ci, E32 730i, E87 120d SE, E61 520d SE, E85 Z4 2.0i Sport, E82 118d Sport Coupe, E53 X5 3.0d Individual, E85 Z4 2.5i
History:
- kis
Quite an old thread you've revived there buddy!
If you've got an Alpina it will be easy to check? Just pop the bonnet. I'd be surprised if they don't have one if I'm honest.
My E85 Z4 3.0i SMG
1 Series - E87
4 Series - F36, F82 M4
5 Series - E34 (x2), E39
7 Series - E32
X5 - E53, E70
X6 - E71
1 Series - E87
7 Series - E32
X5 - E53, E70
X6 - E71
- Jembo
Yup & for any pre facelift E85 owners, I previously found a full quality aluminum replacement on eBay, though on 60k my old one was still as good as new - Perry may be able to advise further given Q is now about Alpinas
It's also good to see people using the search function..
Lifer 54
Lifer 54
- BeeEmm
You drove 300 miles with the engine warning light on? 300 miles? Just noticed it was an old post, but 300 miles.nickoneone wrote: ↑Wed May 02, 2012 8:40 pm Then the orange engine warning light came on. Continued for 300 miles with the intention of taking the car into the garage when I got to Lincoln.
I used to have two boys and a girl. Now I have two Men and a Woman.
Dont think the pin can drop into the engine as its held captively. I believe they have been known to drop into the engine when removing the DISA as a whole. So if you are removing the DISA be very careful when removing the unit.
