PDF Owner's Manuals, Retrofit Instructions and Links
- PawnSacrifice
Re: PDF Owner's Manuals, Retrofit Instructions and Links
It seems BMW USA had the idea already. The link below is great! Click on the year, select your car and then you can download the manual. There are also some videos on there as well, e.g. Bluetooth pairing.
BMW USA Owner's Manuals
2003 2.5i. Info: Winter Tyres | PDF Manuals, Retrofit Instructions and Links | Modifications | YouTube | #Project924
Hey, wet-pants! This isn't the Womens Auxiliary Balloon Corps.
- Taz
i can not open files down loaded from here
does any body have wiring diagrams for the business cd?
- PawnSacrifice
What do you need Taz? I'll have a look for you, but I'm not sure it's something you can download though.
If you can't see any of the images and you're on a Windows machine try installing the Adobe SVG plugin.
EDIT: See you've tried that already - PM replied.
- PawnSacrifice
If you search for N9. Fuse R 47 should be the switched supply.
Plug connector overview
Number X-pin, colour Description
X13342 1-pin Cable shoe Radio
X18126 16-pin, black Plug connector Radio
X13598 12-pin, grey Plug connector Radio
X13321 12-pin, natural Plug connector Radio
X18805 8-pin, black Plug connector Radio
Assignments at cable shoe X13342
Pin Type Description / Signal type Connection /
Measuring notes
1 E Signal, aerial reception Aerial amplifier or aerial diversity
Pin assignments at plug connector X18126
Measuring notes
1 Not used
2 Not used
3 Not used
4 Not used
5 Not used
6 Not used
7 Not used
8 Not used
9 E/A K-bus signal K-bus connector
10 E Telephone mute circuit Cellular telephone
11 E Signal Telephone on Cellular telephone
12 M Ground Ground point
13 E Aerial switching signal Aerial amplifier or aerial diversity
14 E Activation, left bi-xenon headlight Light switch cluster
15 E Terminal 30 Fuse F50
16 E Terminal R Fuse F47
Pin assignments at plug connector X13598
Measuring notes
1 Not used
2 Not used
3 Not used
4 Not used
5 A Navigation signal Positive activation Navigation system or Video module
6 E Signal, telephone AF + Cellular telephone
7 Not used
8 Not used
9 Not used
10 Not used
11 A Navigation signal Negative activation Navigation system or Video module
12 E Signal, terminal 50 via vehicle immoblizer Cellular telephone
Pin assignments at plug connector X13321
Measuring notes
1 Not used
2 E Signal, CD changer AF - CD changer
3 Not used
4 Not used
5 Not used
6 Not used
7 Not used
8 E Signal, CD changer AF +, left CD changer
9 E Signal, CD changer AF +, right CD changer
10 Not used
11 Not used
12 Not used
Pin assignments at plug connector X18805
Measuring notes
1 A Signal, AF radio, rear right + Amplifier
2 A Signal, AF radio, front right + Amplifier or Speaker
3 A Signal, terminal 50 via vehicle immoblizer Amplifier or Speaker
4 A Signal, AF radio, rear left + Amplifier or Speaker
5 A Signal, AF radio, rear right - Amplifier or Speaker
6 A Signal, AF radio, front right - Amplifier or Speaker
7 A Signal, AF radio, front left - Amplifier or Speaker
8 A Signal, AF radio, rear left - Amplifier or Speaker
Hope that helps. I'm sure you will, but test to make sure the connections are what they should be.
Measuring notes
Measuring notes
1 Not used
2 Not used
3 Not used
4 Not used
5 Not used
6 Not used
7 Not used
8 Not used
Measuring notes
1 Not used
2 Not used
3 Not used
4 Not used
7 Not used
8 Not used
9 Not used
10 Not used
Measuring notes
1 Not used
3 Not used
4 Not used
5 Not used
6 Not used
7 Not used
10 Not used
11 Not used
12 Not used
Measuring notes
- Taz
wow, excellent, thanks for that
- Ped_78
TIS doesn't work for me...
- mac27040
3.0i SMG Supercharged,19" CSL, AvinUSA android 10.25” screen,DSP,M6 gearknob,Coilovers,Aero F-bumper,M r-bumper,Aero skirts,Facelift front & rear lights,M sports seats,Carbon Steering wheel,Intravee,Rervese cam,Hydrographics
- Ped_78
- Terryvision
- mac27040
Service manual see 2005 E86
http://www.bmwsections.com/docs/z4/
Sent from my iPhone 5 using Tapatalk pro
- SUUNTOBOB
Brill thanks
Z4 Roadster 3.0Si gone
325 SE Auto Steptronic E90 gone
