Cruise Control - WHICH PIN? ** UPDATE** - coding?
- srhutch
- Moderator
Re: Cruise Control - WHICH PIN? ** UPDATE** - coding?
Jamie - Message stuck in outbox just means they havent been collected yet.
Looking at the PDF gannet put up the DME X60002 is a 26 pin black plug and you need to connect to pin 4, but it is easy to read wrong and read it as pin 26 is the one to connect to.
- srhutch
- Moderator
glastoveteran wrote:Oh and Steve have you started this yet? And did you get your tappets sorted?
I did indeed, but BMW arent replacing the heads anymore just the HVA's
http://www.z4-forum.com/forum/viewtopic ... rs#p161535
you having the same issue?
Interesting Mr Bond, Interesting - i want to go and try this now!!!!!!!!!!!!!!srhutch wrote:Jamie - Message stuck in outbox just means they havent been collected yet.
Might give it a blast before i head home from work.....
Z4MC | Midnight Blue | OEM CSL's + MPSS | Extended Light Sepang Leather | Folding Mirrors | Stubby| BT | Prof Nav | DSP HiFi | Intravee | Privacy | Illuminated ZHP…
- glastoveteran
You're right indeed - didn't have those instructions to hand. But don't get too excited J - pin 4 has something in it as well!srhutch wrote:Looking at the PDF gannet put up the DME X60002 is a 26 pin black plug and you need to connect to pin 4, but it is easy to read wrong and read it as pin 26 is the one to connect to.
Z4MC Silver Grey / Light Sepang / Nav / Logic7 DSP / Intravee / Bluetooth / Cruise / PDC / SPG / Electric folding and dimming mirrors / 19" E46 M3 wheels / Vreds
baaaa humbug!glastoveteran wrote:You're right indeed - didn't have those instructions to hand. But don't get too excited J - pin 4 has something in it as well!srhutch wrote:Looking at the PDF gannet put up the DME X60002 is a 26 pin black plug and you need to connect to pin 4, but it is easy to read wrong and read it as pin 26 is the one to connect to.
- srhutch
- Moderator
Just phoned an Indi near work and they have quoted around £35+vat for coding. He didnt confirm either way 100% if it is required, but I have a feeling we havent got a choice.
srhutch wrote:Just phoned an Indi near work and they have quoted around £35+vat for coding. He didnt confirm either way 100% if it is required, but I have a feeling we havent got a choice.
Humm - i think we need to be 100% on the wiring 1st
- srhutch
- Moderator
I agree, but with so many failing to get it working, 100% failure rate so far I think it doesnt look good.jamiez wrote:srhutch wrote:Just phoned an Indi near work and they have quoted around £35+vat for coding. He didnt confirm either way 100% if it is required, but I have a feeling we havent got a choice.
- glastoveteran
You've reminded me that one member was successful - rich291:srhutch wrote:I agree, but with so many failing to get it working, 100% failure rate so far I think it doesnt look good.
http://www.z4-forum.com/forum/viewtopic ... 04#p188604
We should be asking him...
- srhutch
- Moderator
have you contacted him yet?
Probably be a 3.0i M54 or a 2.0i, the N52's seem to be the problem.
Hope this is of some help. The dealer finished off my cruise some time ago and fitted the famous blue wire for me.
I have just had a look at where he put it; It is fitted to pin out 10 on a black 26 pin plug on my ECU. Photos wont really help much i'm afraid and dont have a manual so not sure what the name of the plug is though.
- srhutch
- Moderator
peartreeproductions wrote:Hope this is of some help. The dealer finished off my cruise some time ago and fitted the famous blue wire for me.
Can you take a picture please so we can see where it is attached (which plug).
Can you also confirm which engine you have.
thanks
Not keen on pulling it to pieces again as in the middle of moving and dont have the time. The plug was at the bottom of the ECU but i dont suppose that helps as they could easily be mounted either way up.
2.5si which I believe is a N52. From memory when I looked before there were not any duplicates in terms of number of pins and colour - correct me if i am wrong.
Ta
Ta
- srhutch
- Moderator
Peartree, thanks for the confirmation on the engine, indeed you have the N52, and that helps me also having the 2.5si, although I guess and hope the 3.0si are the same being N52's also.
If I get change on Monda I will remove the cover and have a look as I want to try this over the xmas break.
- srhutch
- Moderator
Some more info, my source has contacted somebody in the Netherlands who has confirmed the following
blue wire on plug x60002 under the bonnet on pin 4
I need to confirm what engine, but looking at the instructions it was either a N52 or N46
