I ordered the bluemusic flat head pin from Germany 39euro all in.
I spoke to Jehnert so the speaker system only requires 2 channel amplifier as the 3x each side door speakers use a 3 way crossover, if using a 4 or 6 channel you would have to wire the speakers and cause problems passing through the door to body.
So currently trying to work out if the crossovers are still there he sent me a photo of the rubber parts connecting body to door but they are solid and didn’t want to use more force but look the same rubber as he has on his car.
They recommend audiosystem.de and the x-330 which is £600 and pretty huge 58cm I asked if smaller recommendation and gave the x-150.d £300 although seen eBay new £230 but their equipment look great and going to go for one after I measure free space at battery in boot.
So getting closer to achieving my goals haha
The first is Audio Systems guy car with the crossovers mine is all sealed and didn’t want to force.
Advice on OEM Head Unit & Bluemusic
- 240EDFBC-8E0D-4BD4-926B-DDA64700A8E3.png (506.84 KiB) Viewed 113 times
- C5DD8CD4-14E6-4ED5-8E3F-86A196A89FC4.png (318.7 KiB) Viewed 113 times
- veryverydarkblue
I presume you’ve removed the bolt….? Should be pretty easy to remove after that
2006 E85 3.0 SI Sport Manual
Midnight Blue IND / Extended Black Leather / MV2s
Prev: 2005 E85 2.0i SE Manual. Sapphire Black. poverty spec.
No not yet I didn’t have tools on me but will do in day light tomorrow I never done before and figured check out what needs removed and how to put back
