Brakes - Again
Brakes - Again
Morning All,
I'm looking to upgrade my brakes ready for a track day in November. So I've done a lot of reading on here about pads and fluid being the main things to get right, but I thought as I'm doing that I may as well upgrade a bit more.
I have read that the M performance callipers from F series cars will fit on the front with 325mm discs, but what about the rears. looking the M performance rears I'm not sure if they will fit and the discs I've seen are 345mm for them.
I've also looked that the Megane Brembos from K System
Am I better just doing the fronts?
- TheDan
Brakes - Again
I don't know much about fitting the M performance calipers from an F series car, but surely it will require additional adapter brackets as most modern performance calipers are axially mounted to the knuckle?
I personally went for the Megane 3 RS Brembos as they weren't too pricey, came with everything I need and have quite a common pad shape (Megane, Lancer EVO, Alfa 159). They do everything I need them to and have yet to fade them at 3 track days I've done since fitting them.
In terms of fronts vs front + rear, I was told that the rear does barely 20% of the braking during track days on the Z4 and so I didn't upgrade them and bought refurbed calipers (sprayed red) and put yellowstuffs in them. The car is pretty stable slamming the brakes on in a straight line, but the rear end does tend to step out if you are trail braking or braking hard on entry into a turn.
Hope this helps
Hope this helps
- TheDan
Brakes - Again
Oh and I forgot to mention, if you go for the Brembos I'd advise asking for the brackets which fit the 325x28 discs instead of 325x25 discs as there are more options with the former for 2 piece / floating discs.
Brakes - Again
Thanks Dan - all very useful info
I have been looking at the Megane Brembos more and will probably go for those.
I saw a you tube vid of a guy putting 440 callipers on his e46 330i - bolt straight on. which is why I thought of that route.
I saw you needed a 12mm spacer on yours to clear, so will need to factor that in too
- TheDan
Brakes - Again
You're absolutely right!
I've just looked on realoem and they use standard mounts. Sorry!
Also remembered that Jakg did this to his Z4 here (F30 calipers): https://www.pistonheads.com/gassing/top ... 55842&i=40. But I also remember reading a thread a while ago saying that he had to shave down the pads to stop them fouling the rotor hat (see here: viewtopic.php?t=118810).
- Ed Doe
Brakes - Again
To be fair Dan you are half-correct in that the older 135i Brembo/M Performance 6-pot calipers do require an adapter as they are designed to bolt axially. I had these fitted to my 3.0si along with CSL discs - the only issue I found is that with the Style 224 (M Wheels) they fouled the spokes so I had to fit 10mm spacers to accommodate the calipers. This was no big issue, but just something to be aware of if the OP was to go this route - sounds like similar would be required with the M135i 4-pots anyway!TheDan wrote: ↑Mon Sep 13, 2021 12:42 pm You're absolutely right!
Carbon Black '07 M Coupe: Intrax 1k2 Coilovers, AP-Racing, Raybestos ST45s, Tillets, Schroth, Vibratechnic, Apex EC7, Strongstrut, Eventuri, H&S, RTD, 4.1FD
Silver Grey '06 3.0si Coupe - SOLD
- Liam22
Brakes - Again
Yes, the F20 M135i or i8 calipers will bolt straight on the front. If you want to run 345mm discs, and *BIG* wheel spacers.
I've yet to find a nice, easy bolt-on option for the rears, but the car doesn't really need them. I do plan to see if E88 rear calipers will bolt on at some point (+6mm larger rear discs).
Z4M rear axle swap is another option.
Brakes - Again
Thanks Liam. What would you call big spacers?
Brakes - Again
About to order from K system and wondered if I’ll get hit with any customs charge? Anyone ordered since brexit?
- TheDan
Brakes - Again
Yes I had actually forgotten about this until you mentioned it. I was hit with £60.05 of import fees.Weston Matt wrote: ↑Wed Sep 22, 2021 2:57 pm About to order from K system and wondered if I’ll get hit with any customs charge? Anyone ordered since brexit?
You'll have to factor this into your costs as I think it is caused by additional admin due to brexit. I don't know if there is a way around it, maybe buying it from their ebay page instead?
Brakes - Again
Thanks Dan. As long as I’m not paying vat on top of the €759 that’s ok
- TheDan
Brakes - Again
Nope, I didn't have to. I just paid the €649 or whatever it was using Monzo so I didn't get any non-sterling transaction fees.Weston Matt wrote: ↑Wed Sep 22, 2021 4:06 pm Thanks Dan. As long as I’m not paying vat on top of the €759 that’s ok
Out of curiosity, which ones are you going for? Megane/Clio, pads/no pads, 25/28mm thickness?
Brakes - Again
I was looking at the Megane 28mm with the ds performance pads. Where did you get you pads from?
- TheDan
Brakes - Again
I went with the Megane 25mm and wish I'd got the 28mm as there are far more aftermarket options available (including 2 piece discs).
My pads are Carbotech XP8 which I ordered direct from CT. They were not cheap though at £215 for a front set!
Brakes - Again
Looking at the description on the website site it says;
The kit is designed to work with 2 types of standard BMW brake discs:
1) 325 x 28 M3 E46 brake discs
or:
2) 325 x 25 330ci/330d E46 brake discs with 1.5mm spacers between the bracket and the car knuckle
The kit contains:
K-SYSTEM.pro caliper brackets with optional 1.5mm spacers
brand new, genuine red Brembo calipers with pad pins
brake pads to choose: Ferodo DS Performance/Ferodo DS2500/Ferodo DS3000/Ferodo DS UNO or NO brake pads
all necessary bolts
Fitment:
BMW E36 all version except M-Power
BWM E46 all version except M-Power
BMW Z3 all version except M-Power
BMW Z4 all version except M-Power
So i thought I could get either 25mm or 28mm thick discs?
or:
The kit contains:
all necessary bolts
Fitment:
