E85 Phone Charger and Amazon Echo Auto Mounts
Conrod
Didcot, Oxfordshire
For several months I've been experimenting with various designs for a mount for my mobile phone. I use a navigation app (Scenic), and this can quickly run down the phone's battery on long tours - so what I actually need is a mount for a wireless phone charger.
My original approach was a large round mount that I secured to the top of the dashboard with 3M double sided tape. This seemed to work OK, but on long journeys, especially on hot days, the weight of the charger and phone, coupled with the stippled effect on the dashboard, resulted in the mount falling off quite regularly.
I therefore started looking at alternatives, and came across this thread, which in turn referenced a phone mount design that fitted around the instrument binnacle. Although this is a very neat approach, I could see two main issues with this design. Firstly it requires the use of supports to print it. With PETG or similar filaments these can be very difficult to remove, and you inevitably end up with damaged surfaces. Secondly, It relies solely on friction to hold it in place, and is unlikely to handle the combined weight of a charger and phone - especially with the leverage effect of the phone protuding further into the car. However, it's a very neat design, so I set about redesigning it - resulting in this:
The mount extends over the top of the aluminium dash, with the correct profile for a snug fit. So as well as being wedged into the gap around the instrument binnacle, it is supported by the top of the dash, and is also secured to the dash using double sided tape. It's in two parts, which eliminates the need for supports. The two are then joined with countersink head M4 bolts.
I separated the threaded ball joint from the mount supplied with the Auckly Qi charger and this then screws into the hole at the top of the new bracket using an M5 threaded insert.
The wedge part also neatly covers the USB cable required for the charger - it's routed around the instrument binnacle, and then concealed by the mount when it's pushed into place.
I had originally intended to use the "wedge" design for the Amazon Echo Auto I purchased recently. The advantage of this device is its very clever microphone array. It constantly monitors the sounds from each of the eight microphones, measuring the audio delays between each. Using noise cancellation technology, it can then separate voice commands from the background noise - which is perfect for an open top car!
Its magnetic mount normally clips to an air vent, but I wanted something less obtrusive - and ideally concealed so that I could leave the device in the car without it being stolen. I experimented with various orientations and positions, and finally decided upon mounting it in the instrument binnacle, between the speedo and the rev counter. So I designed this slide-in mount:
It's in three parts - the magnet holder (two parts joined by four small screws), and the slide-in bracket. The bracket is attached upside down to the top of the instrument binnacle using double sided tape. The Echo Auto is then attached to the holder by magnetic force, and this then slides into the bracket. The USB cable is routed around the speedo and the binnacle, and again is hidden by the phone charger mount "wedge".
I did some testing yesterday, and with the top down and the windows up I was able to successfully give Alexa voice commands at speeds of up to 60 mph. I've yet to test the quality of the microphone at the other end of a hands-free voice call in this configuration. However, previous experiments with it mounted to the dash resulted in really good quality voice reception with very little wind noise - much better than using the microphone supplied with my Connects2 bluetooth module. With it being located directly in front of me and recessed into the binncale and thus sheltered from air turbulence, it should now be even better.
Here are some photos of the mounts in place.
The blue line in the instrument binnacle is the status display on the Echo Auto.
If anyone is interested in printing these mounts, I'll post the files and details up on Thingiverse. Note that as the phone charger mount is in two parts, the dashboard bracket could be used in isolation as a generic mount. For example, you could deisgn a holder for your specific phone, and then either glue it to the bracket, or incorporate two holes 20mm apart in your design for M4 threaded inserts and joining the two with M4 countersink head bolts.
This looks like a great idea. Always wanted something the sits in that position. I have a brodit clip but that seems too far away and out of line of sight (plus my passengers sometimes knock it).
I would like to be able to fit the quadlock wireless holder, not sure how that would work.
Looking at the Quadlock desktop and car mounts, they incorporate a ball joint that could be removed and instead bolted to the above mount. I see that these are £40 each - as much as the charger itself. That's daylight robbery! :D
It has indeed - and it only had 4200 miles on the clock when I bought it just over a year ago! :wink:
Basically it was a collector's car that had been professionally stored and driven only a couple of times each year, and at one point was off the road completely for seven years. It's had frequent oil changes, and as you can imagine is in immaculate condition. It was a real one-off, and I gladly paid a premium price for it. But it's no longer a garage queen, as although it's not my daily driver, I intend to do many UK and European tours in it once the world's gone back to something near normal.
Not cheap for sure. I have the arm band for when I'm out running, easy to take the phone off for that quick photo opportunity. Would like to integrate it into the car too.
I could certainly do that for you. The best approach would be for you to order the Quadlock mount, and then send it to me so that I can remove the balljoint and modify my design with the correct threaded insert for it. I could then print both halves, bolt them together, attach the ball joint, add the double sided tape and sent it all back to you. That way, it would be ready for you to fit.
I could even add a little BMW badge! :wink:
How does £25 plus postage sound?
Sounds like a plan Conrod. You'll have to bear with me as I don't have the quadlock charger so will need to order one and wait for delivery etc.
Very well done indeed Conrod. That is impressive work. :thumbsup:
Now I'm thinking how it could be modified a little to hold my phone. I want an absolute minimalist holder with no charger or ball joint. (A bit like the one on the thread you referenced above).
That's pretty straightforward. The mount above is in two parts - the dashboard bracket and the charger mount plate. All you need is to design a simple holder for the phone with two 6mm holes spaced 20mm apart horizontally, which are used to attach to the dashboard bracket. The back of the holder would need to be thick enough to accommodate a pair of M4 threaded inserts like these. The inserts are installed by pressing them into the 6mm holes with a hot soldering iron.
The STL file for the bracket part is in the following ZIP file:
View attachment E85 Phone Mount.zip
I recommend using either PETG or PLA+ (basically PLA plus PETG!), or ABS if you can tolerate the fumes!
If required, I could quickly design a holder if you provided me with the internal clearances required for your phone. I'm in the process of assembling a new workstation PC and have moved the graphics card from the PC I currently use for Fusion 360 to the new one - so it would take me a few days until I've completed the new build.
Cheers.
Conrod
Great threat I imagine there are a few people like myself saying that is exactly what I need. I see you come to an arrangement with dhobbs are you willing to make more? As I am interested in the basic bracket
E85 Phone Mount.zip
Cheers.
Thank you for the info and for freely sharing the stl file. That is very generous of you Alan :thumbsup:
Richfarr said:
Conrod
Hi Rich.
I'd be happy to print these for people, and to also look at designing an accompanying generic phone holder to achieve a complete assembled kit (i.e. the bracket, the phone holder with threaded inserts, plus the two bolts). Assuming a universal design approach (i.e. no need for additional CAD work) I would guess the kit price would be around £20 plus postage.
If anyone else would be interested in this, please post a reply below.
No problem - it's what this great forum is all about! :)
Hi Alan/Conrod
I have got the quadlock charging head and have taken a few photos. Seems like it needs a concave ball joint too. I will try and see what size the bolt is too.
Hi Conrod,
I've been following this thread with interest - great design, so neat. Very generous of you to share the STL for the dash mount. I have a 'BMW TomTom' Satnav as occasionally retrofitted by BMW on E89s that didn't originally have iDrive. It's about 6 years old, but works well and maps fully updated. I also have a generic TomTom car mount and I plan on mounting it in my E85 directly to the dash mount. If it's okay with you I going to print the dash mount from your STL. I will of course show the result with photos here. Thanks again.
Sorry for the delay in replying - things have been a bit hectic for me this past week!
@dhobbs: It's certainly possible to add a socket for the balljoint. I can probably extrapolate the measurements I would need to design this from the technical drawing you supplied - so leave that with me and when things have settled down a bit this end I'll pull a design together. I could then print it and send it to you to try.
@Mojito: Thanks - it's what this forum is all about! Feel free to use the STL, and I look forward to seeing the results.
If anyone without a 3D printer is interested in purchasing a pre-printed bracket (the base part that fits around the instrument) then I'd be happy to supply these for £15 including postage. If there's a demand for it, I could also look into designing a small number of corresponding pre-printed cradles for popular phones and offering a complete kit. I have a few mobile phones available for measuring, including an iPhone 6S and an iPhone SE (2020).
Hi Alan,
STL filke worked a treat. A mate printed the mount for me and it fits absolutely perfectly - thank you :thumbsup:
Now, in order to mount the TomTom in the most solid way possible I needed a mounting plate. Rather than go through the process of designing and 3D printing one I came up with a fairly simple solution. Slightly concerned that my Wife might notice that her black plastic chopping board is now 5 inches shorter, but sometimes you have to do what youy have to do. :lol: See photos below. The board wasnt quite thick enough to hide the threaded inserts I had to hand, but I'm very happy with the result, which I think is pretty neat. It's rock solid and I can unclip the Satnav from the mount if I wish.
So pleased with it infact that I've just ordered parts (piggy back fuse and 12volt - 5volt inverter), so I can wire into an ignition switched supply for automatic on/off.
Thanks again Alan - star design and generous of you to share,
Cheers,
Kevin
