I should know
firebobby
I should know
Post by firebobby » Sat Jun 19, 2021 10:07 pm
oldgitdave wrote: Sat Jun 19, 2021 7:51 pm
firebobby wrote: Sat Jun 19, 2021 7:29 pm Just remember that you have them on before raising the roof, they don't have fly off if you forget.
:wink:
Must be an echo in here :poke: :lol:
Who said that :P :rofl:
Toyota MR2 NA 1995
Triumph GT6 1972 (project)
Mini 1000 1981
bigwinn
I should know
Post by bigwinn » Sat Jun 19, 2021 11:24 pm
:fuelfire:
EWS Delete PM me
Coding- airbags etc PM me
firebobby
I should know
Post by firebobby » Sun Jun 20, 2021 6:57 am
Only the black ones are worth anything.
You could donate them to me as I have a beige interior :poke:
I suppose I could accept them..as a gift :rofl:
Toyota MR2 NA 1995
Mini 1000 1981
bigwinn
I should know
Post by bigwinn » Sun Jun 20, 2021 9:26 am
firebobby wrote: Sun Jun 20, 2021 6:57 am Only the black ones are worth anything.
I like your style
EWS Delete PM me
Jamturbo
I should know
Post by Jamturbo » Sun Jun 20, 2021 7:05 pm
Out of interest, has anyone tried to do a 3- d printed one?
LittleZ4
I should know
Post by LittleZ4 » Thu Jul 08, 2021 6:12 am
Jamturbo wrote: Sun Jun 20, 2021 7:05 pm Out of interest, has anyone tried to do a 3- d printed one?
I think a few have mentioned it before but not had a big enough printer to accommodate the part?
3.0i Maldives blue, Coilovers, Bola B1's, Buckley06 Gear knob, Handbrake & Indicator badges, Backbox delete, CDV delete, cupra r splitter, RAM air filter, Bigger Brakes, M3 ARB, SMF.
Conrod
I should know
Post by Conrod » Thu Jul 08, 2021 8:14 am
I've deisgned and printed loads of car-oriented parts over recent years, and I did have an initial stab at this a while ago.
It would certainly be possible to produce a 3D printed version, but due to their shape and size they would need to be split into various sections in order to reduce printing time and minimise the use of supports. I measured everything up and produced a cardboard template of the overall profile, but realised that it would be a lot of work to produce the three dimensional design, as they curve in all directions.
I had a similar challenge when I was designing a RHD version of the dashboard for my 1:12 scale car (a cheap plastic one off eBay, not a Kyosho!). I got there in the end, but it was a real challenge. There would also be a lot of post processing to do, as no matter how good your printer is and how fine a resolution you use, curved 3D printed surfaces always show the layer lines. In practice, therefore, they would need to be sanded, filled and painted - or alternatively covered in fabric.
As usual, other things then came up and I decided that in this case the effort wouldn't be worthwhile, as with my sensible hat on these things are totally impractical and I'd probably never use them anyway! :wink:
I'm currently in the process of converting one of my printers to a dual print head machine so that I can use one head for the main filament and the other for a water soluble (PVA) filament for the supports - at least then the supports can just be dissolved away rather than having to be broken off, which with PETG filament can be a real PITA! So who knows, I might have another stab at this as a winter project...
Alan
2003 E85 Sterling Grey 3.0i
Zulu4
I should know
Post by Zulu4 » Thu Jul 08, 2021 8:45 am
Conrod wrote: Thu Jul 08, 2021 8:14 am I've deisgned and printed loads of car-oriented parts over recent years, and I did have an initial stab at this a while ago.
Hi Alan.
Glad to hear we've got a 3d printing expert. Would you be able to resize the phone holder shown in this thread to fit a larger phone?
viewtopic.php?f=2&t=129452
2007 3.0si Auto Sport Roadster. Whippy.
Previous:
2003 3.0i SE Roadster. Whippy.
Conrod
I should know
Post by Conrod » Thu Jul 08, 2021 10:16 am
Zulu4 wrote: Thu Jul 08, 2021 8:45 am Hi Alan.
Spookily, one of my current Z4 mods is to make a mount for an Amazon Echo Auto (a Prime Day purchase!), using the speedo housing as per the phone holder you linked to! I've designed the bracket part:
Z4 Phone Bracket.jpg (155.14 KiB) Viewed 263 times
and am finalising the magnetic holder part - so I just need to merge the two together. So yes, if you tell me the dimensions of your phone I could modify my design accordingly.
I have a slight issue at present in that having decided to convert my 300x300 printer to 24v and a Bowden set-up, one of the core printed components of my main printer broke last night (the only part I printed with PLA rather than PETG - d'oh!!!). So I need to print a new, stronger version, but I don't have a working printer. I've managed to repair the part using superglue and epoxy resin, so hopefully once I've put it all back together the part should last long enough to print the proper strengthened part!
All part of the fun of 3D printing! :D
Alan
Zulu4
I should know
Post by Zulu4 » Thu Jul 08, 2021 10:38 am
That sounds ace.
Would you be able to slightly increase the size of that linked phone-holder to around 100mm x 10mm ? (I don't think it needs to be a tight fit round the phone, as per the original design).
Shall we continue this conversation in the linked thread to keep it all relevant ?
Previous:
