Coolant Warning Light on Dash
- Ratcatcher
Starting to settle down and enjoy the car now after all the work but noticed today the coolant warning lamp doesnt light when i turn the ignition on. Is this normal?
“Rules are for the obedience of fools and the guidance of wise men.” ― Douglas Bader
- bigwinn
Don’t think mine does- will check
EWS Delete PM me
Coding- airbags etc PM me
EWS Delete PM me
- Ratcatcher
- bigwinn
Deffo- no show at ignition
EWS Delete PM me
EWS Delete PM me
- Ratcatcher
Cheers Bigwinn, thats reassuring as i had a water leak when i first picked up the car and was concerned that i wouldnt get a warning if it came back.
But i actually found this today https://www.youtube.com/watch?v=MZY90qwgIEY so i'll check that it works for the belt and braces piece of mind.
- Ratcatcher
Ok, all good and the lamp works with the cluster test as described on utube. But, does anyone know how the relevant sensor is activated? I tried depressing the float indicator all the way down thinking that it would be a reed switch of some sort but no light on the cluster unfortunately.
- Liam22
Try disconnecting the water pump - that'll force it on. If you remove the washer reservoir you might be able to get to it from the top.
- enuff_zed
But won't that put the light on for a different reason?
If the OP wants to test the low level sensor works they need to activate that?
Looking at a spare sensor I have, it doesn't work as a plunger type switch, seems to be totally encased in plastic so must work on resistance or something like that?
I guess you could short across the two pins on the plug to prove the wiring works, but not sure how you'd check the actual sensor?
Unless............. does the dashboard light test just test the bulbs or check out the circuits?
- IMG_1850.JPG (91.74 KiB) Viewed 408 times
The sensor IS activated when the float hits the bottom (no coolant)... mine did it last week on ignition and while driving, luckily only a top up was required.Ratcatcher wrote: ↑Sun Jun 13, 2021 6:17 pm Ok, all good and the lamp works with the cluster test as described on utube. But, does anyone know how the relevant sensor is activated? I tried depressing the float indicator all the way down thinking that it would be a reed switch of some sort but no light on the cluster unfortunately.
Ive previously replaced the reservoir so i was hoping it hadn't cracked again. A common fault.
- enuff_zed
Hmm, I wonder if the float completes a circuit with the sensor then? Or is it coincidental? Sensor to tell you in the car, and float as a visual check?pp1600 wrote: ↑Mon Jun 14, 2021 12:35 pmThe sensor IS activated when the float hits the bottom (no coolant)... mine did it last week on ignition and while driving, luckily only a top up was required.Ratcatcher wrote: ↑Sun Jun 13, 2021 6:17 pm Ok, all good and the lamp works with the cluster test as described on utube. But, does anyone know how the relevant sensor is activated? I tried depressing the float indicator all the way down thinking that it would be a reed switch of some sort but no light on the cluster unfortunately.
Need someone with the light on, to lift the float and see if the light stays on.
- enuff_zed
Right! This was bugging me, so I enlisted Mr Google.
Apparently there IS a reed switch inside the sensor and it is activated by a magnet on the float.
But you have to keep the two in contact for at least 30 seconds before the light comes on.
Try that.
Try that.
- Ratcatcher
Just got back from the beach/beer/chips/dogs. Great day and there was even a couple of z4's spotted! Thanks for all the info guys, this 30 sec sample time might just be key as im guessing there will be fluctuations in the level during normal service. I'll check tomorrow.
- Ratcatcher
Im guessing your thinking of electric water pump on the N52? Mines an early 2.5 so belt driven only im afraid.
- Ratcatcher
Bit more experimenting yesterday and you werent actually a million miles from the 'truth' The sensor is NC and when activated it becomes open circuit so merely unplugging it causes the warning light to activate (after around the 30sec as noted above) It would seem i have a knackered sensor or the magnet is missing from the float. Either way, it looks like ill have to drain the system to investigate.
- enuff_zed
The sensor fits in with a simple twist (bayonet fitting). If you had a replacement to hand and were quick, you could probably replace it without losing much fluid.Ratcatcher wrote: ↑Mon Jun 21, 2021 9:11 amBit more experimenting yesterday and you werent actually a million miles from the 'truth' The sensor is NC and when activated it becomes open circuit so merely unplugging it causes the warning light to activate (after around the 30sec as noted above) It would seem i have a knackered sensor or the magnet is missing from the float. Either way, it looks like ill have to drain the system to investigate.
Of course, due to the position you have to be in, the fluid you do lose will be into your face, so keep your mouth shut!
If you want to try the spare I have, let me know as I'll be passing your way Tuesday.
