Mixing Run-flats with regular tyres
Owned my E85 2.5i now for about 2 months. Previous owner replaced rear run flat tyres with regular radials of the same size to pass MOT. Question is - is it OK to run with mixed tyre types ? I have run flats on the front and regular on the rear and I am concerned as to whether this would cause a handling issue, I assume it's not illegal as it met the MOT requirements. Would tyre pressure be the same for both types, if not, what would be the recommended pressures for front and rear.
- mr wilks
3 ZMRs
3 E89s
5 Si coupes
5 Si roadsters
997 C4
TTRS
F82 M4
MK7 Golf Gti
current Bmw 6 Gran Turismo
3 E89s
5 Si coupes
5 Si roadsters
997 C4
TTRS
F82 M4
MK7 Golf Gti
- skelters
I'll see you're can of worms and raise you some....
2007 Z4 3.0si Sport. Silver Grey Metallic, Brembo Brakes, HEL Braided Brake Hoses, Machine Monkey Exhaust Tips, Stubby, Piano Black trim, Black Leather, Bilstein B12-Pro-Kit, Michelin Pilot Sport 4 on MV2's. Roof Motor in the Boot!
Not answering your question directly, but if you still have the OEM-spec Bridgestone Potenzas on the front, get rid of them; then you’ll be able to drive in a straight line.
I don’t think I’ll be alone on here by saying you should always go for a decent set of matching tyres all round.
2003 Maldives Blue 3.0i auto
- 1536Z4
From what I have read in the past on other forums the consensus is No .
Montego Blue E86 . MILV`s . Simpson Custom Manifold Race Exhaust . xHP transmission stage 3 . VT engine mounts . BC RA coilovers . H&R arbs . Adjustable rear camber arms . Ultra Racing front strut brace . Drexler LSD .
- enuff_zed
If it were me, the fact that I could tell the insurance company that I legally went backwards through the hedge would not quite cut it.
Ditch the runflats before they ditch you.
OnlineOle gits rule
Not illegal but not something I would ever do
M4 Vert in Yas Marina Blue
I'd never ever run that set up. Sell the fronts, add a little more and get some new non-rft fronts.
OnlineMr Tidy
While it may be legal I wouldn't want to go far with that mixture fitted.
As others have said I'd get a pair of decent non-runflats on the front.
Coupes because stunning!
Gone - Montego Blue
Gone - Ruby Black
Gone - Montego Blue
Gone - Ruby Black
Obviously not ideal, but I wouldn't say it's as suicidal as the previous replies seem to make it sound.
I bought my car a couple of months ago and it came with cheapo Jinyu (non RF) on the front and Continental Sport Contact 2 SSR (RF) on the rear. All are about 7 years old as well.
I've even had it up the Buttertubs Pass and The Struggle just a couple of weeks ago and I'm still here!
Plan is only to change when my wallet recovers enough to change the wheels at the same time. 17's on at the moment and I'll be going up to 18's
- sars
As others have said this is a question that’s been asked many times before, ideally you should have the same brand and type/style on each wheel, obviously what you really shouldn’t have is different brands/type/style or significantly different tread depths of an identical tyre on the same axle and what you have is somewhere in between. It’s not really any different than having Goodyear F1 A5’s on the front and Uniroyal Rain Sports on the rear.
Gorgeous SFR Z4 M40i
Gone 2017 Iridium SL400, 2015 435d xDrive Convertible, 2012 E350 CDi Convertible, 2010 DSB Z4 sdrive30i, 2008 Audi A4 Cabriolet, 2006 Phoenix Yellow Z4 2.5Si, 2003 Saab 9-3 Convertible
- Jembo
IMO It’s the small %age when you have an extreme situation - when the motorway comes to a full dead emergency stop… some nob pulls out on you… it’s raining, you’re going somewhere new & take an unfamiliar bend that’s much sharper than expected.
U have proportionally 4 tiny patches of rubber holding +1 ton of car… having used many brands am surprised just how different they are, borne out by all the nay sayers above.
Yes they’ll go round & round, will different types save your bacon in an emergency or will you qualify for a Darwin Award, your call
Lifer 54
Lifer 54
- Zulu4
My feelings too.PeteyZ4 wrote: ↑Sat Jun 12, 2021 10:16 pm Obviously not ideal, but I wouldn't say it's as suicidal as the previous replies seem to make it sound.
If both sets of tyres are from a quality manufacturer with similar grip ratings , you are unlikely to notice any difference, apart from a hard ride at the front.
I found the biggest effect is having a harder compound rubber on the back and a softer (grippier) compound on the front - This makes life very interesting going round a wet roundabout.
2007 3.0si Auto Sport Roadster. Whippy.
Previous:
2003 3.0i SE Roadster. Whippy.
Previous:
4x A5 sized patches of rubber are all that are between you and potential death... better to be a couple of hundred quid poorer.
Gentlemen, enough said,
I think you have all made the point very clear. RFTs out next week to be replaced by the same make model as the back
