Discuss..enuff_zed wrote: ↑Tue Jun 15, 2021 10:49 amNo!Pbondar wrote: ↑Tue Jun 15, 2021 10:48 amTime to start a tyre pressures disussion I feel?enuff_zed wrote: ↑Tue Jun 15, 2021 10:16 am
Slightly patronising question maybe, but have you checked the tyre pressures, or just reset the system with whatever the fitters put in?
They aren't always very accurate.
Now you've reset the system the car will happily think whatever is in there is correct.
I'd suggest leave it overnight so the tyres are cool, adjust if necessary, then reset the monitor again.
Just..........................NO!
Mixing Run-flats with regular tyres
- Argyll Andy
See there’s none for the 35iS, is that because they know 35iS owners just do what they want regarding tyre size and pressure I am including myself in that btw!
G29 M40i Thundernight with Ivory interior, all option packs (here for a while, hopefully )
E89 23i sDrive, Silver (Gone)
In testing the HPFP,injectors, dampers, waste gates and turbos all failed before they could complete the tests..Argyll Andy wrote: ↑Tue Jun 15, 2021 11:21 amSee there’s none for the 35iS, is that because they know 35iS owners just do what they want regarding tyre size and pressure I am including myself in that btw!
- enuff_zed
Quiet day is it Peter?Pbondar wrote: ↑Tue Jun 15, 2021 12:21 pmIn testing the HPFP,injectors, dampers, waste gates and turbos all failed before they could complete the tests..Argyll Andy wrote: ↑Tue Jun 15, 2021 11:21 amSee there’s none for the 35iS, is that because they know 35iS owners just do what they want regarding tyre size and pressure I am including myself in that btw!
Had two shots of espresso in my cappucinno this morningenuff_zed wrote: ↑Tue Jun 15, 2021 12:27 pmQuiet day is it Peter?Pbondar wrote: ↑Tue Jun 15, 2021 12:21 pmIn testing the HPFP,injectors, dampers, waste gates and turbos all failed before they could complete the tests..Argyll Andy wrote: ↑Tue Jun 15, 2021 11:21 am See there’s none for the 35iS, is that because they know 35iS owners just do what they want regarding tyre size and pressure I am including myself in that btw!
- Flyingfifer
Ooo spicy!
I'm a bit late to the party the OP has been answered
2006 3.0Si Coupé in Monaco Blau with all the optional trimmings
Sorry went off topic..got derailled by others..have you 'surfaced'?Flyingfifer wrote: ↑Tue Jun 15, 2021 12:51 pmOoo spicy!
- Argyll Andy
