Harsh suspension
Harsh suspension
Is it possible to soften the harsh suspension on my 3.0si sport on 66K. I have had the car about 3 years but as late the ride feels harsh. where I live there are quite a few speed bumps and as always pot holes. I did think something like oil filled suspension if that's the way to go along with softer springs. I will not be doing track days but sometimes traffic light starts for a 74 year old are okay. I would not carry out the required work myself but it would be nice to be able to get my point across to the mechanic who does my servicing.
- DSC03574.JPG (144.57 KiB) Viewed 655 times
- DSC03577.JPG (89.81 KiB) Viewed 655 times
- enuff_zed
Harsh suspension
I'm assuming you love the wheels on it?
However, slightly smaller wheels, allowing room for a tyre that actually has a sidewall, may well give you the solution you're looking for.
- Jembo
Harsh suspension
I also suggest you check someone hasn’t fitted Eibachs prior to your ownership
On the rear they’re great, on the front IMO they’ll remove your fillings on every manhole cover as they’re shorter & harder
Lifer 54
Lifer 54
- steve_naive
Harsh suspension
You might be able to convert the suspension to SE spec and fit 17's with fatter tyres?
Might be a bit spendy too because the market for used sport springs isn't really there, people tend to go with Eibach and Biltstein for a sporty set up. I did, and it's miles better than the worn out sport spec I was running.
Would you say the car has got stiffer or have you just lost patience? Could be snapped rears and/or busted struts.
I would also ask myself how far I was willing to compromise and perhaps look at a different car without the notoriously harsh ride.
Harsh suspension
The ride has not started to feel more uncomfortable due to the car itself. it has always been a little what I call harsh. I have recently fitted the Michelin pilot 4 tyres which may have some bearing. mainly I think it's just the roads around my area plus I suppose being 75 at Christmas. I don't want to change the car, I have had Range Rover, a V6 Freelander, and various saloon cars. This car is what my wife calls my boyhood car but in my second childhood. My one son has recently bought himself a 4 litre TVR Tuscan and I find that a little harsh so perhaps I need to sit on an air ring
- Sidewaze Samm
Harsh suspension
Think I'm right in saying that 17" rims won't fit over 3.0si calipers; they need to be 18". May be wrong, but if I ever manage to get one I'll know for suresteve_naive wrote: ↑Fri Jun 04, 2021 2:45 pm You might be able to convert the suspension to SE spec and fit 17's with fatter tyres?
2008 E85 3.0si
Space Grey, Dream Red New England heated Msports.
Xenons, MFSW, cruise, PDC, wind deflector.
ZHP, stubby, gloss black grilles, DLV box, gaptech, no CDV.
- Sidewaze Samm
Harsh suspension
What rims are you on? 18" or 19"? If 19" then, as mentioned in another post above, consider reverting to OE spec and fitting 18".
2008 E85 3.0si
Harsh suspension
They are 18". my only problem with the car is that when I hit a pot hole or a speed bump the car feels so rigid. All I want is a little more give in the suspension. If this isn't possible then so be it.
- enuff_zed
Harsh suspension
Well I would have sworn they looked like 19s. Must be the tyres changing the perspective.
What size tyres are they? They look very low profile. Maybe that lack of sidewall is the issue?
- Zulu4
Harsh suspension
I was thinking the same.
2007 3.0si Auto Sport Roadster. Whippy.
Previous:
2003 3.0i SE Roadster. Whippy.
Previous:
Harsh suspension
The tyres are Michelin Sport 4 on 18" wheels. I chose those tyres as most members rated them on the forum. They are on the staggered system without any spacers. I am happy with car as such but just wanted to know if altering the springs and shocks would make for a softer ride. thanks anyway for the input from the forum
- enuff_zed
Harsh suspension
I think the general consensus would be that you could fit softer suspension, but at the expense of handling. I think you may find it would wallow a bit?rogerplum wrote: ↑Sat Jun 05, 2021 4:39 pm The tyres are Michelin Sport 4 on 18" wheels. I chose those tyres as most members rated them on the forum. They are on the staggered system without any spacers. I am happy with car as such but just wanted to know if altering the springs and shocks would make for a softer ride. thanks anyway for the input from the forum
The reason I brought up the tyres was because, possibly due to the black wheels, they look a very low profile, so you'd be losing a lot of the 'give' from the sidewalls.
No-one has suggested that the make of tyre is wrong: in fact they are some of the best.
I think (though may be corrected) that you should have 225/40 on the front and 255/35 on the back.
On the photo you have shown of the fronts, the sidewall looks very narrow. 40% of 225mm is 90mm: allowing a little variance for particular tyre/wheel combinations. The photo seems to suggest a lot less than that. If that is the case then it could well be your tyre size that is accentuating the hard ride.
Mind you, the 'whoopee cushion' idea could work out cheaper.
- abar121
Harsh suspension
Hmm, they really do look like 19s or at least the wrong profile as above.
Goodyear F1s are slightly softer riding, but the PS4s are great tyres also. Worn dampers or snapped springs will affect the ride quite badly too.
'07 Z4M Interlagos Blue. All options except extended leather.
- dhobbs
Harsh suspension
17 inch wheels do fit over the 3.0si calipers. I have them on mine for the winter, keeps the 18inch MV2s nice and clean for the summerSidewaze Samm wrote: ↑Fri Jun 04, 2021 6:16 pmThink I'm right in saying that 17" rims won't fit over 3.0si calipers; they need to be 18". May be wrong, but if I ever manage to get one I'll know for suresteve_naive wrote: ↑Fri Jun 04, 2021 2:45 pm You might be able to convert the suspension to SE spec and fit 17's with fatter tyres?
3.0si roadster. Requisite stubby. Sound gen mod. LED numberplate lights. LED boot strip. Interior lights LED too. ZHP gearknob. Daily drive
Motor in boot. Bilstein B8 dampers. New radio, much better sounds
- Benderloch
Harsh suspension
I would recommend fitting Bilstein B4s with Suplex springs. This is basically back to the original sports setup and at the correct height. How you setup these cars suspension depend totally on how you intend to use the car. For me my car will be used as a GT, so for me the standard setup with new shocks and springs is perfect.
E86 Silver Grey Red leather, Piano Black trim.
