Vanos/marathon underway
- bigwinn
Final thoughts
X8R kit is top stuff- I wouldn’t buy the stuff needed anywhere else
The only thing I wouldn’t use from the kit is the 9 bolts you resecure the 2 vanos back plates with- they aren’t man enough for the job and I reused the originals
Apart from that- deffo consider doing the vanos when you do water pump and thermostat- just because you are around that area and need to remove stuff
Please feel free to drop me a line with any questions and I’d be happy to help anyone with theirs if needed
Stuart
Stuart
EWS Delete PM me
Coding- airbags etc PM me
EWS Delete PM me
- markplant
Did the oil thermostat need replacing because it pings off broke , or just need refittingbigwinn wrote: ↑Sun May 23, 2021 4:55 pm With most of the vanos work done yesterday, today was all about tidy up, check and a few small bits
Expansion tank- was looking tired, needed doing, I took advice from Enuff Zed who said when he did his, the oil thermostat under it pinged off- which mine predictably did the same! Cheers Martin.
All sorted.
Refilled coolant, checked everything again... put airbox etc back
and started it: ran a bit lumpy but settled quickly and- thats a wrap!
Gave it a blast once i was sure there were no leaks etc; much much better- runs smoothly instead of a grumpy idle before. No oil leaks etc.
I'm sad now there is no pile of parts in the garage- what to do next?
- bigwinn
It broke- which is common I thinkmarkplant wrote: ↑Tue May 25, 2021 7:32 amDid the oil thermostat need replacing because it pings off broke , or just need refittingbigwinn wrote: ↑Sun May 23, 2021 4:55 pm With most of the vanos work done yesterday, today was all about tidy up, check and a few small bits
All sorted.
When I looked at it when the two halves were reunited and all the parts retrieved, it was clear the plastic tabs had broken
For the £9 cost from eBay it was worth getting a new one
EWS Delete PM me
EWS Delete PM me
- enuff_zed
Yup, exactly the same happened to me. Which is why I advisedbigwinn to have a new one to hand. I didn't and had to wait nearly a week to finish the job.bigwinn wrote: ↑Tue May 25, 2021 8:00 amIt broke- which is common I thinkmarkplant wrote: ↑Tue May 25, 2021 7:32 amDid the oil thermostat need replacing because it pings off broke , or just need refittingbigwinn wrote: ↑Sun May 23, 2021 4:55 pm With most of the vanos work done yesterday, today was all about tidy up, check and a few small bits
All sorted.
I believe that this is only on the autos though? Circulates coolant through the transmission oil cooler? (As usual, happy to be corrected on that)
- kis
I wonder where SMG's fall. It's like the Alpina's. Hard to tell what part numbers are. Is there anyway you can quickly do a visual check?
My E85 Z4 3.0i SMG
1 Series - E87
4 Series - F36, F82 M4
5 Series - E34 (x2), E39
7 Series - E32
X5 - E53, E70
X6 - E71
1 Series - E87
7 Series - E32
X5 - E53, E70
X6 - E71
- enuff_zed
What, for the thermostat?
Not sure you can tbh. It is sat inside the block that the expansion tank pushes down onto.
Looking at Realoem doesn't make it 100% clear.
On the auto version it is Item 4 and clearly is fitted (as a few of us can testify)
On the manual version it shows something similar as Item 10, but this is greyed out and doesn't appear in the part number list.
The housing it all fits onto is clearly different for each version.
Guess the only way is to ask a manual M54 owner who's previously fitted a new tank?
- Manual.PNG (79.63 KiB) Viewed 443 times
- Auto.PNG (74.98 KiB) Viewed 443 times
- patriot66
There is no gearbox cooling/intercooler on the SMG gearbox. It is the same 6 speed ZF GS6-37BZ unit fitted to ALL 3.0i, 3.0si and Z4M models and doesn't require any additional cooling. When I replaced my split original expansion tank, part number 7514390 back in Aug'17 it was the same tank and fittings etc as the 'normal' manual
- enuff_zed
In the third photo down, on the auto 2.5i there is a cylindrical thermostat assembly that sits in the bigger hole. I assume yours did not have that? In which case it may well only be applicable to the standard autos?patriot66 wrote: ↑Tue May 25, 2021 9:09 pmThere is no gearbox cooling/intercooler on the SMG gearbox. It is the same 6 speed ZF GS6-37BZ unit fitted to ALL 3.0i, 3.0si and Z4M models and doesn't require any additional cooling. When I replaced my split original expansion tank, part number 7514390 back in Aug'17 it was the same tank and fittings etc as the 'normal' manual 20170819_134619_Richtone(HDR).jpg20170819_134714_Richtone(HDR).jpg20170819_134904_Richtone(HDR).jpg20170819_134642_Richtone(HDR).jpg
- patriot66
Correct, no thermostat in the larger hole. It would serve no purpose on a manual box'd Z4enuff_zed wrote: ↑Wed May 26, 2021 8:13 amIn the third photo down, on the auto 2.5i there is a cylindrical thermostat assembly that sits in the bigger hole. I assume yours did not have that? In which case it may well only be applicable to the standard autos?patriot66 wrote: ↑Tue May 25, 2021 9:09 pmThere is no gearbox cooling/intercooler on the SMG gearbox. It is the same 6 speed ZF GS6-37BZ unit fitted to ALL 3.0i, 3.0si and Z4M models and doesn't require any additional cooling. When I replaced my split original expansion tank, part number 7514390 back in Aug'17 it was the same tank and fittings etc as the 'normal' manual 20170819_134619_Richtone(HDR).jpg20170819_134714_Richtone(HDR).jpg20170819_134904_Richtone(HDR).jpg20170819_134642_Richtone(HDR).jpg
- bigwinn
I am embarrassed to admit- clearly I know the difference between manual and auto boxes- but how does the SMG differ?patriot66 wrote: ↑Wed May 26, 2021 8:23 amCorrect, no thermostat in the larger hole. It would serve no purpose on a manual box'd Z4enuff_zed wrote: ↑Wed May 26, 2021 8:13 amIn the third photo down, on the auto 2.5i there is a cylindrical thermostat assembly that sits in the bigger hole. I assume yours did not have that? In which case it may well only be applicable to the standard autos?patriot66 wrote: ↑Tue May 25, 2021 9:09 pm There is no gearbox cooling/intercooler on the SMG gearbox. It is the same 6 speed ZF GS6-37BZ unit fitted to ALL 3.0i, 3.0si and Z4M models and doesn't require any additional cooling. When I replaced my split original expansion tank, part number 7514390 back in Aug'17 it was the same tank and fittings etc as the 'normal' manual 20170819_134619_Richtone(HDR).jpg20170819_134714_Richtone(HDR).jpg20170819_134904_Richtone(HDR).jpg20170819_134642_Richtone(HDR).jpg
EWS Delete PM me
EWS Delete PM me
- enuff_zed
'tis what I thought.patriot66 wrote: ↑Wed May 26, 2021 8:23 amCorrect, no thermostat in the larger hole. It would serve no purpose on a manual box'd Z4enuff_zed wrote: ↑Wed May 26, 2021 8:13 amIn the third photo down, on the auto 2.5i there is a cylindrical thermostat assembly that sits in the bigger hole. I assume yours did not have that? In which case it may well only be applicable to the standard autos?patriot66 wrote: ↑Tue May 25, 2021 9:09 pm There is no gearbox cooling/intercooler on the SMG gearbox. It is the same 6 speed ZF GS6-37BZ unit fitted to ALL 3.0i, 3.0si and Z4M models and doesn't require any additional cooling. When I replaced my split original expansion tank, part number 7514390 back in Aug'17 it was the same tank and fittings etc as the 'normal' manual 20170819_134619_Richtone(HDR).jpg20170819_134714_Richtone(HDR).jpg20170819_134904_Richtone(HDR).jpg20170819_134642_Richtone(HDR).jpg
Wanted to be 100% clear in order to aid future members doing the expansion tank swap.
If you have an auto and don't buy a new thermostat, it seems very likely the old one will leap out in several pieces and, like me, you'll have to sit and wait for postie to bring a new one.
- enuff_zed
It is light, compact and can fire up to 600 rounds per minute
- Zulu4
An SMG box is identical to a manual box, but instead of you pressing the clutch pedal to disengage the clutch, it is done for you by electro-hydraulically operated servos and a computer. (Like a butler for your clutch foot )
2007 3.0si Auto Sport Roadster. Whippy.
Previous:
2003 3.0i SE Roadster. Whippy.
Previous:
- bigwinn
I can tell you are back from holiday!
EWS Delete PM me
EWS Delete PM me
- bigwinn
Ahhh
Makes sense
That’s cool
EWS Delete PM me
EWS Delete PM me
