What should I do behind the bumper?
- skmattwell
The bumper is coming off this weekend so I can fix the wing clips and clean the headlights. Given how much of a PITA it was to get all the clips off, I can't see it coming off for a while afterwards. Any recommendations of what else I could do while it's off? (ie painting the bars behind the grill, it's tempting)
- colb
Makes sense to tart the bits up that you won't be able to get to with the bumper back on.
Z Shed Cymru member
1999 1.8 Z3
2003 2.5 Z4
1998 Honda Deauville 650
1999 1.8 Z3
2003 2.5 Z4
I found the engine splash guards in a rotten state, worth fitting new ones (expensive at £80 each side) or doing some sort of repair).
If you have the facelift model it’s worth taking the fog lights it too and drying them out, they’re notorious for moisture getting inside.
Current cars: 2006 3.0si E85 Sapphire Black, cruise, MFSW.
BMW 535d Touring (F11)
Skoda Fabia 1.2
BMW S1000XR
Skoda Fabia 1.2
BMW S1000XR
- oldgitdave
As above my splash guards were in a sorry state, cracked & bits missing, very expensive new though. It is possible to repair them & there are a couple of threads on here about it. With luck both yours will be OK.
I found only one of the horns were working so I replaced both of those whilst the bumper was off. Worth checking perhaps?
I didn't have any issues getting mine off or back on again. Have fun
Zedless
Good point about the horn, I found that one of mine had the wires severed from the horn, which I’m guessing happened by part of the broken splash guard.oldgitdave wrote: ↑Thu Apr 15, 2021 10:02 am As above my splash guards were in a sorry state, cracked & bits missing, very expensive new though. It is possible to repair them & there are a couple of threads on here about it. With luck both yours will be OK.
Skoda Fabia 1.2
BMW S1000XR
Skoda Fabia 1.2
BMW S1000XR
- patriot66
I have recently had the front bumper off my car whilst looking for a wiring fault. I took the opportunity to give everything a good clean and on the reverse of the bumper also.
The wheel arch liners with their access panels to get at the back of the headlights and foglights/horn are absolutely useless letting sand and mud in behind the lights and running down and gathering on the flat panel under the horn. I bought some 3mm plain rubber matting on Ebay, cut it to shape after making a template from cardboard and cable tied it in position on the reverse side of the wheel arch liners immediately behind the headlights etc. If any muck gets through now I'd be amazed. Also drilled a few strategically placed 5mm holes to aid water egress from under the horns etc.
Access to the headlights now for bulb changing etc will have to be from above by removing the washer reservoir (one 10mm bolt) on the offside with fortunately nothing in the way on the reverse of the nearside headlight. It's also much quicker and easier than going through the silly arch access panels
- Bunnyboileravoider
Bloody smart. I like itpatriot66 wrote: ↑Thu Apr 15, 2021 2:54 pm I have recently had the front bumper off my car whilst looking for a wiring fault. I took the opportunity to give everything a good clean and on the reverse of the bumper also.
Access to the headlights now for bulb changing etc will have to be from above by removing the washer reservoir (one 10mm bolt) on the offside with fortunately nothing in the way on the reverse of the nearside headlight. It's also much quicker and easier than going through the silly arch access panels 20210313_143704.jpg20210321_173709~2.jpg20210324_183923.jpg
Edit: ***addition*** Just put a GoPro behind mine and it’s hysterical as a PoV (I’m going on a solo adventure). Not a sexy install TBH; fixed with brutality and minimal decorum. But it’s now remote controllable from iPhone, and rechargeable without removal
You only live twice. I'm on my 2nd.
Toys: (Audi Q7 2018, BMW Z4 2006, Ferrari 348 Spider 1994, Le Mans Noble 1971)
Onlinebigwinn
That’s inspired Si- great job!patriot66 wrote: ↑Thu Apr 15, 2021 2:54 pm I have recently had the front bumper off my car whilst looking for a wiring fault. I took the opportunity to give everything a good clean and on the reverse of the bumper also.
I was disappointed to see the state of mine when I sorted the headlights- what was evident was how brittle the plastic and rubber was after 18 years
I considered replacing the damaged bits but saw the price from bmw
Decided against it!
EWS Delete PM me
Coding- airbags etc PM me
EWS Delete PM me
