CDV- guidance please?
- bigwinn
Hi all
Cars up in the air for a load of stuff tomorrow
While it’s up I think I’m going to remove the CDV
What’s the overall consensus- remove the insert in the CDV OR remove the CDV totally and bolt the pipe up without it?
Cheers in advance
Stuart
Cheers in advance
Stuart
EWS Delete PM me
Coding- airbags etc PM me
EWS Delete PM me
- Silverzedtom
Remove totally, there’s more than enough slack on the line and the fittings are designed to go together. Presumably the car is out of warranty so ‘tampering’ isn’t an issue. Well worth it btw
E85 2.5si
F55 Cooper S
F55 Cooper S
- bigwinn
16 years old so waaaay past thatSilverzedtom wrote: ↑Wed Sep 23, 2020 7:29 pm Remove totally, there’s more than enough slack on the line and the fittings are designed to go together. Presumably the car is out of warranty so ‘tampering’ isn’t an issue. Well worth it btw
Good guidance thank you
EWS Delete PM me
EWS Delete PM me
- Sgr74
- Montegojones41
Remove totally , and some advice if you get air in the system get someone to sit in the driving seat to press the clutch pedal down when bleeding while you undo the bleed Nipple near to the valve
Another vote for remove completely.
This small modification completely transforms the clutch feel. You will love it!
2006 Z4 2.0i Ruby Black
- Jembo
+1 for amputation
Lifer 54
Lifer 54
- bigwinn
Unanimous
Binned tomorrow
Binned tomorrow
EWS Delete PM me
EWS Delete PM me
- Mr Tidy
You really won't miss it!
Coupes because stunning!
Gone - Montego Blue
Gone - Ruby Black
Gone - Montego Blue
Gone - Ruby Black
