Z4C...attempting to go from write-off to race car
Sounds like an interesting project in the making. If it's not rude to ask, how much does a write off coupe cost?
Copart sales are all done as live auctions so there is variability based on the damage type and general interest in the car. This one was a Category N with pretty limited damage & set me back £5.5k. I bid on one car before this with very similar spec and damage and that went for £5.6k.
Got time to give the car a quick wash this week and get the front left wheel off to see what the damage was. The car scrubs up ok on the outside...inside it's definitely not been that well looked after! The drivers seat is fairly worn, but the steering wheel is rank. Not the end of the world as they'll be replaced at some point but shows the car probably wasn't that well looked after.
On taking the wheel off, the damage as suspected was a snapped tie rod - it must've taken quite a knock to do that, but surprisingly the damage on the wheel isn't too bad.
Got a part ordered & fitted in 15 mins with no issues.
Decided to take the car round the block just to see if there were any other issues I couldn't see - it drove surprisingly well. Its been over 12 since I've driven one and definitely felt good to be behind the wheel again. There was a bit of a clonk coming from the rear suspension so that'll need a bit of investigation.
Got back home and the smug feeling I had from fixing it for sub £100 soon evaporated as it refused to start an hour later when I wanted to do an oil change! Not even a crank, just dead.
Car electrics aren't a strong point for me so it'll take a bit of investigating - some initial forum research makes me think it's either the ignition switch so I've got one on order & failing that the starter will be next.
- ph001
Shouldn’t take too much researching...if all the ignition lights come on ok at pos2 it’s unlikely to be the switch.
Get a piece of 2x2 and line it up on the starter motor, then give the other end a tap with a mallet. The starter will usually burst back into life. This isn’t a permanent fix of course but shows where the issue lies.
- BMWZ4MC
As a student, I had a car that needed exactly this every ten or so starts. It brings back fond memoriesph001 wrote: ↑Sat Sep 12, 2020 7:37 am Shouldn’t take too much researching...if all the ignition lights come on ok at pos2 it’s unlikely to be the switch.
S2000 GT - gone
Progress has been slow on the zed, 2 weeks holiday got in the way of doing much more researching. Eventually, I ordered a new ignition switch just to give a cheap fix a try...to no avail.
Decided it must be the starter motor so got one ordered from Germany. Covid seems to have slowed order processing and delivery, so required a 2-week wait. Whilst waiting we decided to tackle the gearbox on the EnduroKA to change for one from an aircon car with a slightly better ratio. Wasn't too tough between 3 of us, but was a grubby day working on a gravel driveway.
Finally, the new starter arrived this week along with a few more tools to help me try and get to the bolts, so got to that this morning with the help of PDB's thread viewtopic.php?f=3&t=97004&p=1774184&hil ... r#p1774184. I can confirm it was a pain in the ass to get it out and definitely required some foul language. The new one went in pretty easy which made up for the grazed arms, and hey presto the car now starts.
With that sorted I got an oil change done and took it out for a quick spin round the block. The engine seems to run sweetly, but the next thing to investigate is a clunk coming from the rear suspension going over speed bumps. Hopefully, it'll just be a knackered bush or loose nut somewhere, any suggestions welcome though!
I was hoping to get it out for a first track day at the end of Oct just with some brake upgrades, but that might be a long shot depending on the suspension issue. Either way, I'll be getting a stud conversion sorted soon and finding a second set of wheels, as well as finding a local body shop to straighten the front wing and repair 2 alloys.
- TheDan
Typically the most common causes of knocking on the rear are (most common first):Toppy wrote: ↑Sat Sep 26, 2020 3:17 pm With that sorted I got an oil change done and took it out for a quick spin round the block. The engine seems to run sweetly, but the next thing to investigate is a clunk coming from the rear suspension going over speed bumps. Hopefully, it'll just be a knackered bush or loose nut somewhere, any suggestions welcome though!
- Rear springs broken
- Play in RTAB
- Damper top mount (only if knackered or changed to versions known to knock)
- Play in stab (drop) link bushes
TheDan you are indeed correct. Had a spare 10 mins today to have a look...both rear springs have snapped...
I was going to leave the suspension for now and just get it out on a track day fairly stock, but I guess that plan's over and I'll get some coilovers on order.
Current top of the list is a set of Gaz Golds with adjustable top mounts, but any other recommendations welcome for track use.
Well, that's been a while since the last post. Most of the time in October went on the EnduroKa getting it prepped then racing in the season finale Indy 500 at Brands Hatch. That was a day/night race in cold and damp conditions but was awesome fun and just nice to get out with friends. We qualified poorly in p31 but dragged it up to p10 at the end which felt a pretty decent result and a nice way to end the year.
With that put to bed, the attention could turn back to the zed. Next on the agenda was to sort the front wing and both driver's side wheels which all took a knock when it was written off. The car went off to Kudos Bodyworks http://www.kudosbodyworks.com/ to get them sorted - not bad at £210 for the wing and £50 for each wheel. Anyone in South London needing work doing, I can highly recommend Marcus...they do a good job and are great value.
That saw the zed now back to a roadworthy condition having been written off as a Cat N - all repairs done for sub £400, not bad really.
With the rear springs snapped I decided I'd get on with getting suspension ordered & making a start. Having spoken to Gaz I decided on a set of their monotubes of the same spec as the BMW 330 challenge cars, but with spring rates and adjustable top mounts for the Z4. They're not cheap at just over £2k, but given I plan to race the car felt like the best option and sure look and feel quality.
Whilst on this I decided it was also worth replacing the front control arms as well as upgrading the bushes. For bushes I decided on superpro, with caster offset for the front as they did these in a kit with some of the rears.
Whilst I was waiting for the coilovers to arrive I set on removing the control arms and replacing the bushes. I don't have any experience with bushes, so borrowed a press of a friend, and promptly failed to remove them despite it having a 6 tonne jack. Smashing them with a club hammer didn't do a great deal either. After a weekend of swearing I decided to replace the jack in the press for a 15 tonne version, and low and behold it worked and I could remove the old bushes and press in the new ones.
With that done, the coilovers arrived so I could start on the install of everything. This was all fairly straight forward but I still managed to make a few cock-ups along the way. The most awkward part was getting the nut tightened on the driver's side control arm where the engine mount is directly above it. But nothing a bit of patience, grazed knuckles and swearing couldn't sort.
Whilst doing this I realised the ARB links wouldn't likely fit, so got some adjustable Roadnutz ones ordered from https://www.spring-loaded.co.uk/. Whilst there I spotted they were selling the H&R ARBs about £100 cheaper than I'd seen anywhere else so decided to get these ordered as well.
With that done I decided to change the driver's side steering tie rod as the passenger side had been done as part of the repair and ensure alignment could be done easily. Annoyingly whilst torquing up the arb brackets I managed to snap one of the studs, so need to come up with a gameplan to sort that.
I dropped the car down today - it's in serious need of both alignment and a geo setup - the steering is completely pissed, and the camber is very different on both sides.
That's where it's got to so far, next I'm planning on sorting the rear bushes and coilovers, then it'll be on to brakes before I take it for a full geo-setup, hopefully in time for some track days in Feb.
Loving the thread and saving this car. Following with interest!
Saw your post about Kudos Bodyworks. How do you rate them? They’ve quoted me for some work and are considerably cheaper than the other two quotes I’ve had, wondered how you found the repair?
I've used Kudos twice now and been really impressed. The work hasn't been major - mainly small dents & scratches as well as wheel refurbs but the quality has been excellent and cost low. He used to work on people's driveways but has a unit with spray booth now which can only have helped on quality.
- Liam22
They're a bugger, aren't they. Mine took 8t of pressure to budge the old bush sleeve.
I'd love to know what the optimum drop link length is for the Gaz monos. I went too short and bent the tabs over.
It's been a frustrating few weeks over Christmas with the weather not playing ball and not having a garage to work in to keep me dry. Finally, it's stopped raining so I've managed to get going with the rear end.
First up, to replace the RTAB for superpro ones. I found the Pelican parts guide the most helpful, but the first side still took me a good while and I managed to break the 12mm bar in my bush kit whilst doing it . Despite all the practice I'm getting at doing bushes at the moment I don't think I'll ever really enjoy it.
Bushing kit setup
Nearly there
Apparently it took me this many tools for one bush!
New one finally in
Fortunately having spent a couple of days on and off doing the first side, the other one was done start to finish in about an hour. After that I set about taking the boot trim apart to get to the rear top mounts ahead of installing the rear coilovers. I've decided not to both putting any back as it'll get fully stripped at some point.
With that done I got onto installing the rear coilovers, definitely one of the easier jobs I've done so far, and finally get the broken rear springs off the car.
With that sorted and bit of time left this weekend I decided to get the H&R rear ARB on there. It was a bit of a pain getting the old one off, and of course required removing and replacing bushes on the links, but the install was surprisingly simple.
Old bushes out of links & new ones pressed in
New ARB on
Next up I'm going to need to have my first go at alignment as its completely out, then I'll be needing a couple of sets of tyres. The car came with completely shagged tyres so these will go for Michelin PS4s for road & wet track use, I'm not decided on dry track tyres yet. I've mainly used Toyo R888s in the past but they cost a fortune in these sizes, so any other recommendations much appreciated.
I'm amazed at the weight of the MV2 wheels, but I'm also not keen on spending £1k+ on a set of lightweight wheels just yet. A bit of research showed the MV1s are a kilo lighter, so I picked up a set of these off ebay for £150 over christmas. I'm not keen on the look, but don't really care too much as they'll only be used on track.
I've also got brakes on order - just some new OEM discs, Pagid RS29 pads, HEL lines and some racing fluid, so once that arrives that'll be up next, followed by an MOT and a geo setup. Hopefully that should keep me on track to get it out when track days are allowed again!
Bushing kit setup
Nearly there
New one finally in
New ARB on
- Z4C_er
I may have asked you this before, but if you have subwoofers and are going to strip out the interior, could you let me know when you'd like to sell the grilles please?
2006.5 E86 Z4C si SE Phoenix Yellow
Sure thing. Are there different audio system specs? There are 2 speakers with round grilles behind the seats...does that sound like what you're after? If so, I reckon I'll be doing full interior strip in 3 - 6 months depending on how the year pans out
