Forced admission for all Z4 e85/e86 (all engines)
- dougie1142
This is really great work, love seeing people doing this sort of stuff and researching further. Can't wait to see the results, will you be getting the car dyno'd before and after you have installed?
- M1k3yC
Gazzzz, thank you for sharing this. It's really interesting to see what you've done!
2022 Hyundai Kona N - greyhound transport
2018 F56 Mini JCW
2016 MX-5 2.0 Sport Recaro
Gone to a good home: 2007 E86 3.0Si Sport
2018 F56 Mini JCW
- ph001
The M3 CSL runs Alpha N system in conjunction with MAP sensor so it can fuel properly for air-ram effect. None of the Z4 models can. If Z4 intake manifold runs with positive pressure, it could cause some strange fuelling problems.
This is the sensor that could give you problems, it helps ECU determine engine load...
The issue with any dyno testing you do is that it is not going to include hardly any air-ram effect so at best your results will be meaningless, at worst misleading.
Sorry if I sound negative - I love your engineering skills but people need to be aware of potential issues before installing such a mod.
- TomK
It's not a great photo but you can see. It is not completely airtight at the moment but it wouldn't take a lot to make it so, I'll have a look when I'm next with the car.Gazzzz wrote: ↑Thu Aug 06, 2020 7:14 am
Have you got pictures of your link between the CSL air Box and the OEM tube? Is it really impervious (I don't if this is the good word, I mean Air-proof, or without any air-leak)? this may really interest me, I plan to buy one too. Yes, dyno is the right solution to measure the difference, but you have to find one with a fan linked to the speed of the car to simulate wind effect (it must increase in the same time).
Let me know if you are willing to share one of your prototypes and I will put it on a suitable dyno.
Yes, it is the idea but not before the end of the yeardougie1142 wrote: ↑Thu Aug 06, 2020 11:10 am This is really great work, love seeing people doing this sort of stuff and researching further. Can't wait to see the results, will you be getting the car dyno'd before and after you have installed?
You're welcome!
Not realy exact. You can tune your M version with alpha-N gestion using the evolve complete solution here:The M3 CSL runs Alpha N system in conjunction with MAP sensor so it can fuel properly for air-ram effect. None of the Z4 models can. If Z4 intake manifold runs with positive pressure, it could cause some strange fuelling problems.
https://www.evolveautomotive.com/evolve ... w-z4m.html
Or here:
https://power-plus.be/site/?p=3351&lang=en
But this is not the subjet for today
-On an M5 e60, using air ram and an exhaust you optain nearly +30hp...
-You can find many video showing that a sports air filter increases performance.. why?
-why this?
The gain isn't obtain by increase the presure but the flow and the temperature.
Contrary to popular belief though, air is not pushed into this inlet, but the engine is sucking air in... Naturally ASPIRATED.
As you can see in the previous video, the flow up and down during the engine running.
Sometimes there isn't enough air, sometimes it's OK:
https://www.youtube.com/watch?v=nZorW4yfSbc
With this part, it is colder, more constante. That is as easy as it simce to be.
The OEM part here:
is really restrictive to allow our car to run in all conditions possible (in the dust for example), I don't need this.
Thank you for this photoLet me know if you are willing to share one of your prototypes and I will put it on a suitable dyno.
At this moment I only have seven of this piece, there are all for friends. But some of you ask me here or with PM for one, so why not produce a little more.
- Sgr74
I was going to ask about rain getting into the filter. Ive put a ramair cone filter on with a very rudimentary heat shield. I thought about altering the intake scoop but because I’m in Scotland, it’s kinda wet at times and I was a bit worried about water Getting to the filter.
Black 2.5 Roadie.
Hello,
just some new pictures to show you the final product after sanding and painting. It is perfect, it look like OEM part, I'm very happy
Here is a comparison, OEM versus Home made!
Looks awesome, Are you going to be in a position to sell them? Like I said before would be interested in purchasing?
https://www.instagram.com/cdo_cowan/
Current fleet
Porsche 911 996 turbo 6 speed manual
BMW X5 40D M Sport 8 speed auto
BMW E63 630i 6 speed manual
Current fleet
- Sgr74
Again, as above. It may be a silly question, but what about water getting in if it’s raining. Would this not cause problems?
Black 2.5 Roadie.
That looks really good.
As for the benefits, I think the only way to get any meaningful data would be to datalog before and after as a dyno won’t properly simulate the airflow.
RUBYIMOLACARBON
- Z4C_er
As others have asked, when/if you are in a position to sell, I would be interested! Please put my name in to the queue!
2006.5 E86 Z4C si SE Phoenix Yellow
- Ewazix
There are of course a lot of similar products out there, this example has been optimised for maximum flow rates and is fully field tested. It is also available in various colours. My wife has had one fitted for a while and the problem has been occasional leaks around the inlet flange.
Just a bit of British humour, it's a impressively researched project
2018 Cooper S Countryman
Fiesta Ecoboost
Fiesta Ecoboost
- enuff_zed
Ewazix wrote: ↑Mon Nov 02, 2020 10:29 am There are of course a lot of similar products out there, this example has been optimised for maximum flow rates and is fully field tested. It is also available in various colours. My wife has had one fitted for a while and the problem has been occasional leaks around the inlet flange.
Took a few seconds that one!
- BMWZ4MC
Just don’t turn your back on her when she’s feeling frisky!Ewazix wrote: ↑Mon Nov 02, 2020 10:29 am There are of course a lot of similar products out there, this example has been optimised for maximum flow rates and is fully field tested. It is also available in various colours. My wife has had one fitted for a while and the problem has been occasional leaks around the inlet flange.
Very impressive work Gazzzz, I’m watching this thread with interest
S2000 GT - gone
