Front Struts - Replacement Options?
Wookster78
Post by Wookster78 » Sat Jun 27, 2020 12:38 pm
That’s the one, I got them from there too :thumbsup:
2004 E85 3.0i, LCI xenons, red sports interior, backbox delete, twin pipe conversion, diff ratio upgrade, coilovers, clear rear lights, cup holders, Sapphire black
2014 F31 M Performance Pack, Avin headunit, LED headlights
IAmOrion
Post by IAmOrion » Sun Jul 05, 2020 10:59 am
Ok, so I’m doing my rears - the adjuster is supposed to go at the bottom according to venom/stanced but the adjuster thing doesn’t fit over the rubberised centering piece :(
Should I have ordered something else? Did they send me the wrong ones??
NO LONGER OWN A Z4 SO NOT AS ACTIVE HERE ANYMORE (IF AT ALL).
I STILL OFFER FREE CARLY CODING & EWS KEY/TRANSPONDER CODING AT MY HOME
IN CAMBRIDGE CB22
Facebook: https://www.facebook.com/groups/Z4DIYCustomMods/
Wookster78
Post by Wookster78 » Sun Jul 05, 2020 4:00 pm
Think mine was like that a but tight but as soon as you put the car down it goes on fine, see attached mine
JDavis21
Post by JDavis21 » Sun Jul 05, 2020 4:10 pm
IAmOrion wrote: Sun Jul 05, 2020 10:59 am Ok, so I’m doing my rears - the adjuster is supposed to go at the bottom according to venom/stanced but the adjuster thing doesn’t fit over the rubberised centering piece :(
That's odd, all suspension options I've seen on E46's and Z4's have the adjuster mounted at the top.
Image attached for reference, even though it's not the same kit.
IAmOrion
Post by IAmOrion » Sun Jul 05, 2020 4:16 pm
JDavis21 wrote: Sun Jul 05, 2020 4:10 pm That's odd, all suspension options I've seen on E46's and Z4's have the adjuster mounted at the top.
The venom & stance+ websites both state adjuster should be at the BOTTOM - how ever I can see from Wookster78, his too are at the top.
https://www.venommotorsport.com/product ... n/SU55012/
This is so confusing :(
“ Rear height adjuster to be mounted below the rear springs.”
IN CAMBRIDGE CB22
Wookster78
Post by Wookster78 » Sun Jul 05, 2020 5:50 pm
Must admit typical bloke I did not read the installation instructions and just looked at some pictures of adjustable rear springs on z4’s when I put them in. Sits fine and rides ok, are you sure you can’t get it in there, remember it was tight but with a bit of general purpose grease went in ok
IAmOrion
Post by IAmOrion » Sun Jul 05, 2020 5:53 pm
Wookster78 wrote: Sun Jul 05, 2020 5:50 pm Must admit typical bloke I did not read the installation instructions and just looked at some pictures of adjustable rear springs on z4’s when I put them in. Sits fine and rides ok, are you sure you can’t get it in there, remember it was tight but with a bit of general purpose grease went in ok
I’ve done it now, used a hole saw to trim the rubber :rofl:
IN CAMBRIDGE CB22
Wookster78
Post by Wookster78 » Sun Jul 05, 2020 5:59 pm
Good job, maybe I need to be switching mine round the other way :?
Have said that been on there two years and been fine :D
Wookster78
Post by Wookster78 » Sun Jul 05, 2020 6:06 pm
Looks like you have set them in the middle, mine are set fully undone and it’s already pretty low, lower than standard m sport anyway so might be a bit low for you if you are looking for similar to standard ride :thumbsup:
