Just got my new Carly
Niallc
Gothenburg
Yep, arrived this evening.
Im in Sweden and it was nearly 900 sek from the swedish Carly site but when I bought from the German Carly page it was 800sek.
Any tips for using it?
Also anyone near Gothenburg need to use it just pm me :)
I’m in London but I assume the App is the same. Follow the guides on the App and it’ll all be fine. I’ve done lots with mine and the lady up the road who has a Mini is also enjoying some coding. :rofl:
Does anyone know how you change the indicator to a triple flash when you only click the indicator on for a second?
That's a new one!
I believe the triple flash is default so unless coded for 5 it should be as is. I reset mine to default for all and then recoded as wanted. I have triple flash.
I've no idea how to do it, but a very helpful forum member with Carly did some coding on my car and I now have the 3 flash function. :D
... yep certainly is definitely only one flash ...
Looking to program to 3.
Hey, can you remember who this might have been please?
Look into it mate, could be wrong! But pre/post facelift differences could be the answer?
Yep, early models can't do it (as I've found out). Early models can't open the doors when the engine stops/key out either, which is a bit annoying really.....
Niallc said:
Torpalasse said:
Im south of Varberg and might be in need of some coding.
Låsning, cab upp/ned med nyckel och kanske ngt mer.
Jodå, det ska jag definitivt göra när våren kommer. Stör mig väldigt på att bilen självlåser när man börjar köra bl.a
No problem. Fancy a trip to Kungälv :)
