Door membrane
Door membrane
Went about fixing my door rattle and adding sound deadening at the weekend.
Found 2 problems, caused by whatever neanderthal last have the door card off.
when I got the door card off, I thought this sound deadening looks easy, I can see right into the door, Then realised, There should be a membrane here, Some lazy *insert swear word at home) has just ripped the membrane right off, Theres remnants of the membrane and the buytl tape that head it there, But they have just taken a knife and could an inch from the outside all the way around. Which explains why my windows like to after heavy rain.
Coincidental the rattle in the door was The vertical bar which the regulator mounts too, The stud from the bar was through the hole but with no nut on it. so it was pushing in and out, They also didnt put the screw back in behind the door handle.
Anyone any ideas what can go in place of the membrane, cant seem to find any, dont really want to pay bmw prices for a bit of foam. Thinking some thick poly sheet or some alternative
Door membrane
They are pretty reasonable from BMW iirc; otherwise try looking on ebay. There really isn't any alternative.
- paulc_bkk
Door membrane
and be extra careful to ensure that there is a completely perfect seal around the edge - especially at the bottom as its a common spot where water can leak in through the exterior of the door, run down the metal window guide/bar, and drip between the door and the door panel, and leave you with wet carpet in the door-sill area......
- kis
Door membrane
I find it interesting that a little membrane is the cause of so much water ingress... if they are damaged!
My E85 Z4 3.0i SMG
1 Series - E87
4 Series - F36, F82 M4
5 Series - E34 (x2), E39
7 Series - E32
X5 - E53, E70
X6 - E71
1 Series - E87
7 Series - E32
X5 - E53, E70
X6 - E71
- LittleZ4
Door membrane
Mine does exactly this!! Passenger side footwell has been like a pool at times.paulc_bkk wrote: ↑Tue Oct 01, 2019 10:25 am and be extra careful to ensure that there is a completely perfect seal around the edge - especially at the bottom as its a common spot where water can leak in through the exterior of the door, run down the metal window guide/bar, and drip between the door and the door panel, and leave you with wet carpet in the door-sill area......
3.0i Maldives blue, Coilovers, Bola B1's, Buckley06 Gear knob, Handbrake & Indicator badges, Backbox delete, CDV delete, cupra r splitter, RAM air filter, Bigger Brakes, M3 ARB, SMF.
- Timmyboybunter
Door membrane
Someone butchered both of my membranes, still present but a knife slash horizontally along the middle of each presumably when fitting new window regulators. Soggy foot wells on both sides.
New membranes and butyl tape a couple of months ago now, pleased to report car is dry and leak free
2012 VW Passat 1.4 Tsi Estate
2005 Mercedes CLK 55 AMG
2015 E89 BMW Z4 sDrive35iS (sold)
2010 E89 BMW Z4 sDrive30i (sold)
2003 E85 BMW Z4 3.0 (sold)
Door membrane
Same as above both mine had been canibalised now replaced and dry as a bone beware damage can be caused to electrical modules if not sorted
2004 z4 30i auto Toledo blue stubby Areo front back sideskirts and rear spoiler M/// MFSW DLV exhaust mod mma tips vanos overhaul 108s refurbed ram air scoop E46 M3 heated seats clear rear lights M/// sport black grills
Door membrane
hi all, I have the same problem as the membrane is ripped and loose at the bottom - i suspect it may be the cause to the water ingress. Does anyone have the part numbers or the product name so I can source a replacement? I am considering using duck tape as a very short term fix - has anyone used this as a short term fix?
- Timmyboybunter
Door membrane
Door membranes (left 51487016655, right 51487016656) - £81.43 for the pair
Door membrane
Yeah I did this until I could replace the membrane with a new one. Worked ok but the tape was completely useless by the time I properly fixed the problem 6 months later. Did help keep out most of the water out the cabin tho.IanDR wrote: ↑Wed Jun 16, 2021 1:54 pm hi all, I have the same problem as the membrane is ripped and loose at the bottom - i suspect it may be the cause to the water ingress. Does anyone have the part numbers or the product name so I can source a replacement? I am considering using duck tape as a very short term fix - has anyone used this as a short term fix?
- tomscott
Door membrane
90% sure the membranes are single use very difficult to get off and reapply without ripping it. They aren't that expensive worth getting new ones.
Door membrane
I have literally just had my drivers door card membrane replaced
Exact problem as I found out in the May wet UK weather & the carpet was properly water logged!
Once the door card was off a previous owner had clearly butchered the mebrane in many places and just left in-situ.
Replaced with an OEM by my Indy all in for approx £85 so not too bad.
Now no water ingress (tested with high power hose)!
Current: E86 Si Sport Coupe | OEM Spec, Saph Black, Red Lthr, Auto <80k, 3 owners
Gone:
G31 530d X M Touring
F31 640d x4 (yes 4!) M GC's
F10 520d M Saloon
F11 525d M Touring
E39 525d M Saloon
E46 330d M Touring
E36 330i M Saloon
F20 118d M Auto
Gone:
F10 520d M Saloon
F11 525d M Touring
E39 525d M Saloon
E46 330d M Touring
E36 330i M Saloon
F20 118d M Auto
- Timmyboybunter
Door membrane
That sounds very reasonable - given my parts were £82 and needed a trip to the dealer to collect, plus a roll of butyl on top - I would have happily paid £170 all in to NOT have had to do the job!
Door membrane
My Passenger door is leaking slightly. So I'm going to purchase a new door membrane. Which one do I order? Left or right. I'm always confused by this. Is it right when looking at the car from the front or left when sitting in the driving seat ??? Where do I purchase the Butyl tape from, I'm guessing it's double sided. What width do I need ? sorry for all the questions but I don't want to purchase the wrong bits.
2004 Black Sapphire 3.0L SE. Red leather. Back box delete. Clutch valve delete. Roof motor relocated. 18" M star spoke style 193. Machine Monkey exhaust tips. Gap Tec. ZHP Gear knob. Clear side repeaters. Zun Sport lower grille.
Door membrane
You need the left one. I think I paid £29 for mine from Rybrook Warwick
