Dash lights
Dash lights
Lights came on 5 mins ago what does it mean anyone.
- 86C4C4AA-9F58-445D-9F16-21C3B9F251BE.jpeg (228.29 KiB) Viewed 1094 times
- ph001
Dash lights
You need to put a code reader on it to be sure but that is typically a faulty wheel speed sensor.
Dash lights
The code comes up as the abs hydraulic pump no abs or traction control. BMW want
£2.500 to replace pump independent bmw
Trained mechanic £400 all in booked for
30th September.
30th September.
Dash lights
5FDF0 x 5DF1 hydraulic pump motor.
On line it said fault usually affects 6-cylinder models mine is 4-cylinders??
- ph001
Dash lights
Ok, the handbrake one is normally yellow for the abs pump but you did the right thing in getting the codes read and 5DF1 and 5DF0 are certainly ABS pump related. There is a company called ECU TESTING that will repair that for you for £200 but then you would have to remove and refit yourself. £200 labour from the garage seems a but steep to be honest, should be no more than an hours job really.
Dash lights
Thanks for your input compared to bmw asking £2.500 I’m happy with £400 with lifetime guarantee.
Bloody cars hand brake light is only red while engaged yellow when its not.
- Mr Tidy
Dash lights
I'm pretty sure the handbrake light is red whenever the handbrake is engaged even if you have no faults!
£400 certainly sounds much better than £2,500.
Coupes because stunning!
Gone - Montego Blue
Gone - Ruby Black
Gone - Montego Blue
Gone - Ruby Black
Dash lights
Expensive if it's the pump. .Mine was an ABS sensor with similar lights. This was after having different lights for a wheel speed sensor.
- ph001
Dash lights
The ABS sensors and the wheel speed sensors are the same thing, unless you mean the pressure sensors on the master brake cylinder?spazmochad wrote: ↑Tue Sep 17, 2019 6:57 pm Expensive if it's the pump. .Mine was an ABS sensor with similar lights. This was after having different lights for a wheel speed sensor.
Op- can you confirm what colour lights you have with the handbrake off?
Dash lights
When hand brake is on red when off yellow
Cheers.
Cheers.
- ph001
Dash lights
Ah, that would explain it. Thanks for clarifying. It will be your ABS pump: £200 for repair + cost to remove and refit.
Dash lights
Hi everyone I posted my dashboard lights went off yesterday never came on again today famous last words
I’m beginning to think could it be worn wheel sensors.
It’s intermittent. Has anyone else had this problem.
- ph001
Dash lights
It’s your ABS pump.
Dash lights
- Yeah on of the two pressure sensors. Number 2 here: https://www.realoem.com/bmw/enUS/showpa ... Id=34_1290ph001 wrote: ↑Tue Sep 17, 2019 11:29 pmThe ABS sensors and the wheel speed sensors are the same thing, unless you mean the pressure sensors on the master brake cylinder?spazmochad wrote: ↑Tue Sep 17, 2019 6:57 pm Expensive if it's the pump. .Mine was an ABS sensor with similar lights. This was after having different lights for a wheel speed sensor.
- enzed4
Dash lights
I had the 5DF0 code and it was the ABS/DSC pump (fortunately not the ECU attached to the side of the pump). It's a well known fault where the brushes in the pump get stuck (apparently not using the ABS enough, go figure. More proof you should drive harder ). Instead of replacing the whole unit (at the exorbitant rate mentioned above), the pump can be opened up and the stuck brush sorted. Never had any probs with mine after the (considerably cheaper) repairMr roadster wrote: ↑Mon Sep 16, 2019 5:00 pm 5FDF0 x 5DF1 hydraulic pump motor.
Gone: 2010 35i DCT
Gone: 2008 2.5Si Sport
