Any ideas how this rubber seal no longer surrounds the lock?
And even better, does anyone know how to go about replacing? I expect a whole new locking system might be required
How does this even go missing?
- 9FC56B0B-2226-4451-ACE0-BA20BE8FE3DD.jpeg (275.5 KiB) Viewed 769 times
- 1F027629-C0F2-44B8-ABCD-E1B15A9E8816.jpeg (253.56 KiB) Viewed 769 times
- F442DEAE-555C-4973-919A-4A26181A950F.jpeg (261.07 KiB) Viewed 769 times
Hopefully it's 51247042830 but that might just be the seal, I've not had one off to see what's what.
https://www.realoem.com/bmw/en/showpart ... Id=41_1455
E85 3.0
- buzyg
Weired one. Assume you have checked it has not some how pushed in further could it be still in there.
- ben g
I suspect someone has tried to illegally gain access to your boot
- srhutch
- Moderator
I doubt very much a missing rubber seal will render your entire lock in need of replacement
Checked by removing the planting backing cover from inside the boot, nowhere to be seen.
I would agree someone has probably tried to get in, thank god they failed!
Hmmm that part looks like it sits behind the lock. Had it apart earlier and that piece is in place still.G600 wrote: ↑Sat Jul 13, 2019 3:30 pm Hopefully it's 51247042830 but that might just be the seal, I've not had one off to see what's what.
The part I'm missing is the rubber seal around the lock, can't seem to find one online anywhere!?!?!
- kis
Your lock is 90 degrees the wrong way round. The key hole should be like an “i”not a dash. Someone’s defo been in there and given it a good twist. Need to open up and see what’s been done. Think rubber will be there. But your bracket and screw? Fitting points may be broken...
My E85 Z4 3.0i SMG
1 Series - E87
4 Series - F36, F82 M4
5 Series - E34 (x2), E39
7 Series - E32
X5 - E53, E70
X6 - E71
1 Series - E87
7 Series - E32
X5 - E53, E70
X6 - E71
