cheap bluetooth option?
- Vijay
Seems the amazon audio interface is a good option. However, before purchasing could someone elaborate on which bit of carpet the connectors are hiding behind? The bit covering the battery (I couldn't see anything) or the luggage partition wall, which seems a lot of hassle to unscrew (No3 in diagram: https://www.newtis.info/tisv2/a/en/e86- ... el/GCsO4Br)
2007 Z4 3.0Si Coupe, Carbon Black, 53K on clock & counting...
Mineral White M240i
Mineral White M240i
yep, it has a coax.
Does this mean I can't use the amazon Bluetooth adaptor?
Have you a link to the DSP one?
thanks
thanks
You need to take the back wall off, but I have only unscrewed the bottom fixings and pulled it up enough to get to the CD changer.Vijay wrote: ↑Mon May 20, 2019 10:00 am Seems the amazon audio interface is a good option. However, before purchasing could someone elaborate on which bit of carpet the connectors are hiding behind? The bit covering the battery (I couldn't see anything) or the luggage partition wall, which seems a lot of hassle to unscrew (No3 in diagram: https://www.newtis.info/tisv2/a/en/e86- ... el/GCsO4Br)
The Bluemusic Amazon one is by far the most integrated option, I just wish my iPhone connected to it automatically (at the moment it picks up the factory BT but I have to manually connect to the dongle)
- Jakg
This is the DSP adaptor. You need this as well as the Bluetooth adaptor if you have the DSP system.
https://www.amazon.co.uk/gp/product/B07 ... UTF8&psc=1
- Vijay
Hi,tadekk wrote: ↑Mon May 20, 2019 10:07 pmYou need to take the back wall off, but I have only unscrewed the bottom fixings and pulled it up enough to get to the CD changer.Vijay wrote: ↑Mon May 20, 2019 10:00 am Seems the amazon audio interface is a good option. However, before purchasing could someone elaborate on which bit of carpet the connectors are hiding behind? The bit covering the battery (I couldn't see anything) or the luggage partition wall, which seems a lot of hassle to unscrew (No3 in diagram: https://www.newtis.info/tisv2/a/en/e86- ... el/GCsO4Br)
Thanks for the steer!
Didn't know there were bottom fixings...?
Mineral White M240i
Mineral White M240i
Thanks for your help Love this forum. Do you know how the 2 bare cables connect?Jakg wrote: ↑Tue May 21, 2019 9:42 amThis is the DSP adaptor. You need this as well as the Bluetooth adaptor if you have the DSP system.
- Jakg
I connected them to the two wires on the 3-pin CD changer plug - one is +12v, one is ground and one is IBUS (the white one).
Why it's not wired up like that in the first place I don't know.
The +12v is a permanent live, the seller says the bluetooth unit turns off after 15 mins. Not sure if the DSP one does the same.
Do I need the other Bluetooth interface as well?Jakg wrote: ↑Tue May 21, 2019 12:52 pmI connected them to the two wires on the 3-pin CD changer plug - one is +12v, one is ground and one is IBUS (the white one).
I'm just. Literally going to throw this out there.
I know it's nowhere near as neat as a proper all in one integrated solution. But it's twenty quid, sounds pretty good and does a job. I know there are better solutions which can be achieved with more effort.
But I'll be honest, I've not really thought about doing anything furhter as an upgrade since I bought it...
E86 | Stratus Grey
- Sidewaze Samm
Delete the factory BT from your phone's connection list? Won't that then allow it to reconnect automatically?
2008 E85 3.0si
Space Grey, Dream Red New England heated Msports.
Xenons, MFSW, cruise, PDC, wind deflector.
ZHP, stubby, gloss black grilles, DLV box, gaptech, no CDV.
- Jakg
You need both units if you have the DSP system.Niallc wrote: ↑Tue May 21, 2019 2:21 pmDo I need the other Bluetooth interface as well?Jakg wrote: ↑Tue May 21, 2019 12:52 pmI connected them to the two wires on the 3-pin CD changer plug - one is +12v, one is ground and one is IBUS (the white one).
- Probocop
I can't speak for ApplePhones, but my Samsung connects automatically to both the factory BT for calls, and BlueMusic for... musicSidewaze Samm wrote: ↑Tue May 21, 2019 3:20 pmDelete the factory BT from your phone's connection list? Won't that then allow it to reconnect automatically?
2007 Z4M Coupé - Midnight Blue
1988 VW Transporter - Slate Blue
2008 E82 123d - Space Grey
2009 Abarth 500 Esseesse - Campovolo Grey
Ok, so I’ve bought one of these amazon blue music things. I found 2 wires behind the boot wall and plugged them into the dongle. My phone and iPad recognise the dongle on bluetooth but I can’t get any sound out of the hifi unit. 2007 coupe with business cd. Am I missing something somewhere?
- 23A4C0A9-1EA5-4E25-99A0-3F6A1758EA1D.jpeg (354.49 KiB) Viewed 705 times
2007 E86 Ruby Black
- Probocop
Which input do you have selected? It replaces the CD changer, so I select CD as the input.
