Fitting M wishbone bushes to a non M
Has anyone fitted the offset M front wishbone rear bushes to a non M to increase caster? I'd like to know if it's worthwhile.
E85 3.0
- Spriteracer
I'm also considering this as it seems an obvious way to improve the straight line stability on a road car. Simple and relatively cheap.
Is there no-one who has boldly gone before ?
2007 E86 "work in progress"
Done it and I noticed a slight increase in force required for turn in.
- MrPT
Quite a popular mod in the E46 M3 community. Cheap, but best have an alignment done afterwards, in which case you could have a few other changes made that may also have an impact on how the car feels/handles.
2006 Z4 2.5si: gone
2006 Z4 2.5si: gone
- Spriteracer
Many thanks both. That will be next on the list of things to do then. New bushes, dampers, springs (all stock), tyres, pinless camber and 2 alignments already done.
I fitted them on my previous E85 3.0 and what you need to be aware of is that they physically move your front wheels more forward in the wheel arch by 5-10mm, so if you have wider or higher profile tyres there may start to rub. I had winter tyres of 225/40/19 on the front and they just about fitted but rubbed slightly on full lock.
Does anyone know if the z4m wheel arches are a slightly different shape to the standard z4? As the M runs larger 225/45/18 tyres up front, I’m wondering why they don’t run with m bushings? Perhaps the extra forward positioning of the bushings and increased castor is dealt with via different shaped plastic wheel arch covers, or perhaps more likely via the hub geometry?
Z4 Coupe 3.0si - Stratus Grey - M sport seats, headlining, New England, Carver, Cruise, Xenons, sT XTAs, Eisenmann race, 18” 405m
G21 M340i - Tanzanite - Tech Pack, Comfort + Pack, Visibility pack, pan roof.
- srhutch
- Moderator
Liners are the same.DaveD wrote: ↑Thu May 02, 2019 9:24 pm Does anyone know if the z4m wheel arches are a slightly different shape to the standard z4? As the M runs larger 225/45/18 tyres up front, I’m wondering why they don’t run with m bushings? Perhaps the extra forward positioning of the bushings and increased castor is dealt with via different shaped plastic wheel arch covers, or perhaps more likely via the hub geometry?
So the geometry difference must be dealt with perhaps in the steering knuckle? If I recall correctly the top mount in the body shell is the same in M and non-M, so perhaps the hub position is slightly further back in the knuckle on the M to cater for the 10-15mm forward movement in the wishbone?
Sure I’m overthinking this but interesting to know. I’m running 225/45/18 square set up so the M bushing would almost certainly rub, but the idea of increased castor and it’s positive effect on steering is of interest. Perhaps I just need to go camber/castor top plates......
- Limonge
Hello, could you post the ref number? I am interested in them but I wouldn't like to buy the wrong ones... Thanks!
Just had mine delivered from BMW online, turns out that number gets you a set so don't order 2 like I did.
E85 3.0
Let us know what you think of the difference when fitted!
- Limonge
