Heya,
I'm looking to buy an OBD2 reader which can also do the more advanced bits like resetting airbag fault and service timer (I understand some can't)
I've seen the Carly can enable options which is pretty tempting, I thought I saw they moved to a yearly subscription, I can't see any mention of that on their website, did they revert the decision?
- Can Carly set it so the seats move to a memory setting depending on the key used to unlock the car?
There is a huge selection out there and so I was hoping for some personal recommendations.
OBD2 Reader Recommendations?
- tomrdy
I've got both the C110+ and the PA Soft.
The C110+ is an alright standalone unit (I just keep it in the car) which can do some basic code clearing - not sure on airbags though I've seen it done on Youtube.
The PA Soft is cable + software for Windows XP (yep). This can do a little bit more and can change the service timer iirc (I think I changed mine last time I had it fired up).
Other thing I did with PA Soft was enable comfort access for the roof - so key fob control of the soft top.
You can also add/remove cold and hot checks for lamps which is handy if you run into issues with LEDs.
-SOLD- Nardo grey 2004 Z4 3.0i E85
-SOLD- 2016 Long Beach Blue M2 DCT
-Wishing- Z4MC Interlagos blue...
___
Australia
Cheers, The C110+ looks like a good deal (looking at what the C310 offers for that extra £10 atm).tomrdy wrote: ↑Sun Mar 24, 2019 9:20 am I've got both the C110+ and the PA Soft.
Unfortunately windows based systems aren't an option since my PC is a desktop.
I downloaded the carley app and it is indeed £50 a year which is just too much for the use I'd get out of it.
I’d second the C110. For basic diagnostics it seems pretty good. For coding and the like you’d need something else.
Thanks you two, I went with the C310 in the end, the extra options seemed worth it.
Maybe I need to update the system, but automatic scan seems to be the same as manual i.e. I have to drill down into each sub system to ask if it has a code.
