Seat & doorcard removal question
- oldgitdave
Very soon I'm going to remove the seats & doorcards for refurbishing. I'm going on holiday whilst the work is being done & I want to put the car back in the garage (and get it back out once done). I realise that I'll get the airbag warning light on if I leave the battery connected but I can sort that, I hope . Are there any issues with starting the car & moving it without seats & doorcards in place? It's only a few feet & I think a foot stool will do as a makeshift seat.
On a separate note; what's the best sound deadening material to use in the doors? Might as well do that too, they sound horribly tinny at the moment.
Dave
Dave
Zedless
- philbo909
can you roll it back in with the battery still disconnected, saves having the airbag switch turned off? (edit) why don't you do the removal in the garage?oldgitdave wrote: ↑Fri Mar 15, 2019 5:51 pm Very soon I'm going to remove the seats & doorcards for refurbishing. I'm going on holiday whilst the work is being done & I want to put the car back in the garage (and get it back out once done). I realise that I'll get the airbag warning light on if I leave the battery connected but I can sort that, I hope . Are there any issues with starting the car & moving it without seats & doorcards in place? It's only a few feet & I think a foot stool will do as a makeshift seat.
Dave
not sure on the sound deadening question, I'd imagine silent coat, but not sure which type
Sapphire black z4 coupe 135,000miles young
i used this in my doors
https://www.amazon.co.uk/gp/product/B00 ... UTF8&psc=1
this will do the trick in a pinch.
https://www.screwfix.com/p/bostik-flash ... 25mm/22704
there shouldnt be a smell or anything and with our UK weather there is little chance of it melting in the summer.
- oldgitdave
Yes, I could roll it into the garage but I wouldn't be able to push it back out due to the slope on the drive. Not sure if I can select neutral with the battery disconnected though, is it just a mechanical lock between the ignition switch & auto box?philbo909 wrote: ↑Fri Mar 15, 2019 6:10 pmcan you roll it back in with the battery still disconnected, saves having the airbag switch turned off? (edit) why don't you do the removal in the garage?oldgitdave wrote: ↑Fri Mar 15, 2019 5:51 pm Very soon I'm going to remove the seats & doorcards for refurbishing. I'm going on holiday whilst the work is being done & I want to put the car back in the garage (and get it back out once done). I realise that I'll get the airbag warning light on if I leave the battery connected but I can sort that, I hope . Are there any issues with starting the car & moving it without seats & doorcards in place? It's only a few feet & I think a foot stool will do as a makeshift seat.
Dave
Unfortunately the garage is too small to do it there. It's a pita to get in & out of the car anyway once it's in there .
I'll take a look at silent coat, thanks .
Zedless
- oldgitdave
Thanks for that, the stuff on Amazon looks just the job.rooha wrote: ↑Fri Mar 15, 2019 6:14 pm i used this in my doors
Zedless
- philbo909
ah ok auto... I'm not sure
I'm also not sure how easy the airbag light is to switch off
if you take the doorcards out outside the garage and the seats out with the roof down in the garage maybe?
I'm sure someone will come along with a real answer
- ben g
I drove mine after taking my seats out. It's a very odd feeling but perfectly fine if only moving a few meters. I was able to turn my airbag light off using my inpa software, so that wasn't an issue.
- oldgitdave
looks like it'll be ok. mac27040 (ZedFest) isn't far away from me & has Carly so hopefully will be able to do the reset if needed.
Zedless
- Sidewaze Samm
I may be wrong - probably am - but I seem to remember reading that Carly can't reset airbag lights.oldgitdave wrote: ↑Fri Mar 15, 2019 11:09 pmThanks
2008 E85 3.0si
Space Grey, Dream Red New England heated Msports.
Xenons, MFSW, cruise, PDC, wind deflector.
ZHP, stubby, gloss black grilles, DLV box, gaptech, no CDV.
- IAmOrion
Correct, when I removed my seats and tripped the air bag light, I had to use my K+D can cable with ISTA to clear the airbag light, Carly wouldn't do it on my 2003 E85Sidewaze Samm wrote: ↑Mon Mar 18, 2019 9:31 am I may be wrong - probably am - but I seem to remember reading that Carly can't reset airbag lights.
NO LONGER OWN A Z4 SO NOT AS ACTIVE HERE ANYMORE (IF AT ALL).
I STILL OFFER FREE CARLY CODING & EWS KEY/TRANSPONDER CODING AT MY HOME
IN CAMBRIDGE CB22
Facebook: https://www.facebook.com/groups/Z4DIYCustomMods/
IN CAMBRIDGE CB22
- oldgitdave
Thanks for that chaps. Thought I'd read on here that he could do it, perhaps it's not Carly that he used, or more likely I've got it wrong .IAmOrion wrote: ↑Mon Mar 18, 2019 9:44 amCorrect, when I removed my seats and tripped the air bag light, I had to use my K+D can cable with ISTA to clear the airbag light, Carly wouldn't do it on my 2003 E85Sidewaze Samm wrote: ↑Mon Mar 18, 2019 9:31 am I may be wrong - probably am - but I seem to remember reading that Carly can't reset airbag lights.
Maybe this would do the trick?
https://www.ebay.co.uk/itm/AC808-Memo-S ... ect=mobile
Zedless
- ben g
I thought Mac had INPA, which can reset an airbag light easily.
- Timmyboybunter
Nope - that won't work either, tried it myself before biting the bullet and installing INPA. £12 down the drain.oldgitdave wrote: ↑Mon Mar 18, 2019 2:34 pm Maybe this would do the trick?
2012 VW Passat 1.4 Tsi Estate
2005 Mercedes CLK 55 AMG
2015 E89 BMW Z4 sDrive35iS (sold)
2010 E89 BMW Z4 sDrive30i (sold)
2003 E85 BMW Z4 3.0 (sold)
- oldgitdave
I'll check with him when the time comes. If he hasn't I'm sure there will be someone not too far away that could help if need be .
Thanks for that, saved me wasting £12Timmyboybunter wrote: ↑Mon Mar 18, 2019 3:09 pmNope - that won't work either, tried it myself before biting the bullet and installing INPA. £12 down the drain.oldgitdave wrote: ↑Mon Mar 18, 2019 2:34 pm Maybe this would do the trick?
Zedless
- IAmOrion
I’ve no idea where you’re based, but I’m in Cambridge CB22.oldgitdave wrote: ↑Mon Mar 18, 2019 6:03 pm I'll check with him when the time comes. If he hasn't I'm sure there will be someone not too far away that could help if need be .
I have INPA / ISTA / Carly / X-Diag so I can clear it (free of course)
IN CAMBRIDGE CB22
IN CAMBRIDGE CB22
